05056680001
05056680001
    WERA(维拉)
    WERA - 05056680001 - Hex Driver Bit, Hex, 1.5mm Bit, 25 mm Overall
05056680001 数据手册
840/1 BTZ bits, 1,5 x 25 mm Bits for Hexagon Socket Screws EAN: 4013288182418 Size: 25x7x7 mm Part number: 05056680001 Weight: 3g Article number: 840/1 BTZ Hex-Plus Country of origin: CZ Customs tariff number: 82079030 Suitable for hexagonal socket screws Ductile and tough for hard materials BiTorsion zone to absorb peak loads 1/4" hexagon drive (Wera connecting series 1) Take it easy tool finder: colour coding according to profile and size BiTorsion bits for hexagon screws with elastic Torsion zone – where kinetic energy is diverted from peak loads – and softer BiTorsion zone to prevent the bit tip from twisting under peak loads. This greatly extends the product service life. Extra-hard; ¼” hexagon, suitable for holders as per DIN ISO 1173-D 6.3. Web link http://products.wera.de/en/bits_holders_adaptors_the_range_of_bits_bits_for_hexagon_socket_screws_840_1_btz_hex-plus.html Wera - 840/1 BTZ Hex-Plus 05056680001 - 4013288182418 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 840/1 BTZ bits, 1,5 x 25 mm Bits for Hexagon Socket Screws BiTorsion Bits Two cushioning torsion zones BiTorsion phase 1 Peak forces that occur in power tool applications often result in premature wear of bits or damage to the screw head. This usually occurs during initial power-up and the when the screw comes to a standstill. Screwdriving could become more productive and safer if these peak loads could be minimised. The Wera BiTorsion system prevents premature wear. The service life of the tool is extended and the productivity of power tool applications significantly increased. The effectiveness of the BiTorsion system comes from a combination of two shock-absorbing spring elements. Both bits as well as holders have a cushioning torsion zone that diverts the kinetic energy away from the drive tip during peak loads. The torsion spring integrated into the unique BiTorsion holder absorbs lower levels of peak loads (Phase 1). Any overloading of this spring is effectively prevented by means of a supporting mechanism. BiTorsion phase 2 Above-average service life BiTorsion and conventional tools “Take it easy” tool finder Higher peak loads are minimised through the torsion effect of the bit shaft (Phase 2). This effect is achieved with a specific heat treatment after the hardening process of the bits. This reduces the hardness of the shaft in comparison to the drive tip. Even the service life of conventional bits is enhanced with the use of the BiTorsion holder and the BiTorsion bit also functions in a normal holder. The BiTorsion holder and the BiTorsion bit can, of course, be used independently of one another. “Take it easy” tool finder with colour coding according to profiles and size stamp – for simple and rapid accessing of the required tool. Web link http://products.wera.de/en/bits_holders_adaptors_the_range_of_bits_bits_for_hexagon_socket_screws_840_1_btz_hex-plus.html Wera - 840/1 BTZ Hex-Plus 05056680001 - 4013288182418 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 840/1 BTZ bits, 1,5 x 25 mm Bits for Hexagon Socket Screws Further versions in this product family: mm mm 05056680001 1.5 25 1 05056681001 2.0 25 1 05056682001 2.5 25 1 05056683001 3.0 25 1 05056684001 4.0 25 1 05056685001 5.0 25 1 05056686001 5.5 25 1 05056687001 6.0 25 1 Web link http://products.wera.de/en/bits_holders_adaptors_the_range_of_bits_bits_for_hexagon_socket_screws_840_1_btz_hex-plus.html Wera - 840/1 BTZ Hex-Plus 05056680001 - 4013288182418 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05056680001 价格&库存
很抱歉,暂时无法提供与“05056680001”相匹配的价格&库存,您可以联系我们找货
  • 1+28.732861+3.72900
  • 3+26.991473+3.50300
  • 5+24.292335+3.15270
库存:32
