05057433001
05057433001
    WERA(维拉)
    WERA - 05057433001 - Bit Set, Universal Holder, Bit Check, Wood, Phillips, Pozidriv, Torx, 31 Piece
05057433001 数据手册
Bit-Check 30 Wood 1, 30 pieces Bit-Checks Wood EAN: 4013288179807 Size: 145x77x28 mm Part number: 05057433001 Weight: 264 g Article number: Bit-Check 30 Wood 1 Country of origin: CZ Customs tariff number: 82079030 Upright positionable Bit-Checks convince due to their functionality in a minimum of space Particularly for wood applications Rapidaptor holder for rapid bit change Torsion design against premature wear Robust Bit-Check by Wera. Bit-Checks provide a quick overview of the tools available. Bits not needed are simply reinserted into the set and do not get lost. Simple transportation e.g. in the shirt pocket. Includes universal holder with ring magnet – which very securely holds even heavy screws – and Rapidaptor, which allows bits to be attached without any need to actuate the sleeve. Can be inserted in the power screwdriver or for use in the chuck of the electric drill. Multi-component Bit-Check that can be positioned upright for permanently secure bit storage. Web link http://products.wera.de/en/bits_holders_adaptors_bit_sets_bit-checks_wood_bit-check_30_wood_1.html Wera - Bit-Check 30 Wood 1 05057433001 - 4013288179807 Wera Werkzeuge GmbH 02.08.2018 - 1 / 2 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Bit-Check 30 Wood 1, 30 pieces Bit-Checks Wood Set contents: 887/4 RR 05052490001 1 x 1/4"x57 855/1 TH PZ 05056910001 05056915001 05056925001 3 x PZ 1x25 6 x PZ 2x25 2 x PZ 3x25 851/1 TZ PH 05056510001 05056525001 2 x PH 2x25 1 x PH 3x25 867/1 TZ TORX® 05066305001 2 x TX 10x25 05066308001 2 x TX 15x25 05066310001 4 x TX 20x25 05066312001 4 x TX 25x25 05066315001 2 x TX 30x25 05066320001 1 x TX 40x25 At the workplace Torsion bits Rapidaptor with ring magnet Bit Ranges The Bit-Checks can be positioned upright at the workplace so the tool is always quickly to hand. Torsion bits absorb the damaging peak torque loads in the torsion zone. This prevents premature wear and enhances the service life of the bits. The floating, free-turning magnetic sleeve securely holds even large and heavy screws to enable immediate application. There is no need to hold the screw when applying the tool – something which can be dangerous and painful. Also ideal for overhead work. We have had bit ranges in our programme for many years now. In 2016, we put a question mark against everything and came up with a game changer. We wanted bit ranges with bits whose profiles and sizes could be more easily recognised. We wanted bit ranges that were as compact as possible and which were Wera-like at a first glance. We wanted bit ranges with bits that could be removed and reinserted more easily. We wanted bit ranges with as little weight as possible. The new multicomponent Bit-Checks satisfy these requirements; the soft material in the lower section of the Bit-Checks ensures that the bits are firmly held yet easy to remove. Web link http://products.wera.de/en/bits_holders_adaptors_bit_sets_bit-checks_wood_bit-check_30_wood_1.html Wera - Bit-Check 30 Wood 1 05057433001 - 4013288179807 Wera Werkzeuge GmbH 02.08.2018 - 2 / 2 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05057433001 价格&库存
很抱歉,暂时无法提供与“05057433001”相匹配的价格&库存,您可以联系我们找货
