05057434001
05057434001
    WERA(维拉)
    WERA - 05057434001 - Bit Set, Universal Holder, Bit Check, Pozidrive, Phillips, Torx, Slotted, Hex, ...
05057434001 数据手册
Bit-Check 30 Metal 1, 30 pieces Bit-Checks Metal EAN: 4013288179838 Size: 135x60x20 mm Part number: 05057434001 Weight: 226 g Article number: Bit-Check 30 Metal 1 Country of origin: CZ Customs tariff number: 82079030 Hex-Plus allows socket head screws to live longer Upright positionable Bit-Checks convince due to their functionality in a minimum of space Particularly for metal applications Tough viscous bits for universal use Universal holder with stainless sleeve Robust Bit-Check by Wera. Bit-Checks provide a quick overview of the tools available. Bits not needed are simply reinserted into the set and do not get lost. Simple transportation e.g. in the shirt pocket. Includes universal holder with strong permanent magnet for the take-up of bits with ¼” hexagon head drive. Can be inserted in the power screwdriver or for use in the chuck of the electric drill. Multi-component Bit-Check that can be positioned upright for permanently secure bit storage. Web link http://products.wera.de/en/bits_holders_adaptors_bit_sets_bit-checks_metal_bit-check_30_metal_1.html Wera - Bit-Check 30 Metal 1 05057434001 - 4013288179838 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Bit-Check 30 Metal 1, 30 pieces Bit-Checks Metal Set contents: 899/4/1 05053457001 1 x 899/4/1 Kx1/4"x50 855/1 Z PZ 05072080001 05072082001 05072084001 3 x PZ 1x25 3 x PZ 2x25 3 x PZ 3x25 800/1 Z 05072055001 05072059001 05072061001 1 x 0.6x4.5x25 1 x 1.0x5.5x25 1 x 1.2x6.5x25 851/1 Z PH 05072070001 05072072001 05072074001 3 x PH 1x25 3 x PH 2x25 2 x PH 3x25 867/1 TORX® 05066485001 05066486001 05066487001 05066488001 05066490001 05066491001 1 x TX 10x25 1 x TX 15x25 1 x TX 20x25 1 x TX 25x25 1 x TX 30x25 1 x TX 40x25 840/1 Z Hex-Plus 05056320001 1 x 4.0x25 05056325001 1 x 5.0x25 05056330001 1 x 6.0x25 At the workplace Universal holder with stainless steel sleeve Bit Ranges The Bit-Checks can be positioned upright at the workplace so the tool is always quickly to hand. The retaining ring and the strong permanent magnet ensure a particularly secure fitting of the bit in the holder. We have had bit ranges in our programme for many years now. In 2016, we put a question mark against everything and came up with a game changer. We wanted bit ranges with bits whose profiles and sizes could be more easily recognised. We wanted bit ranges that were as compact as possible and which were Wera-like at a first glance. We wanted bit ranges with bits that could be removed and reinserted more easily. We wanted bit ranges with as little weight as possible. The new multicomponent Bit-Checks satisfy these requirements; the soft material in the lower section of the Bit-Checks ensures that the bits are firmly held yet easy to remove. Web link http://products.wera.de/en/bits_holders_adaptors_bit_sets_bit-checks_metal_bit-check_30_metal_1.html Wera - Bit-Check 30 Metal 1 05057434001 - 4013288179838 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Bit-Check 30 Metal 1, 30 pieces Bit-Checks Metal Web link http://products.wera.de/en/bits_holders_adaptors_bit_sets_bit-checks_metal_bit-check_30_metal_1.html Wera - Bit-Check 30 Metal 1 05057434001 - 4013288179838 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05057434001 价格&库存
很抱歉,暂时无法提供与“05057434001”相匹配的价格&库存,您可以联系我们找货
  • 1+205.74618
库存:50
