7440 VDE Kraftform adjustable torque handle, 9 mm Hex, 0,3 - 3,5 Nm
Kraftform Kompakt VDE
EAN:
4013288179111
Size:
200x70x40 mm
Part number:
05074752001
Weight:
220 g
Article number:
7400 VDE
Country of origin:
CZ
Customs tariff
number:
82054000
Adjustable Kraftform VDE torque holder
Adjustable torque from 0.3-1.2
Distinct audible and perceivable excess load signal when the pre-set torque value is reached
Suitable for Kraftform Kompakt VDE blades
Rapid exchange of the interchangeable blades
Torque VDE holder for safe work up to 1,000 volts. Adjustable torque value from 0.3-1.2 Nm. Distinct audible and perceivable excess load signal
when the pre-set torque value is reached. Unlimited manual loosening torque. For Kraftform Kompakt VDE blades: the handle/interchangeable blade
system allows a rapid exchange of the blade and thereby diverse applications.
Web link
http://products.wera.de/en/vde_tools_kraftform_kompakt_vde_7400_vde.html
Wera - 7400 VDE
05074752001 - 4013288179111
Wera Werkzeuge GmbH
02.08.2018 - 1 / 2
Korzerter Straße 21-25
D-42349 Wuppertal
Tel: +49 (0)2 02 / 40 45-0
E-Mail: info@wera.de
Individually tested
Kraftform VDE adjustable torque
handle
handle
handle
The individual testing at 10,000
volts, in accordance with IEC
60900, ensures safe working with
loads up to 1,000 volts.
Simple setting of the required
torque by hand.
Easy-to-read
scale
value.
Measurement accuracy is ± 6 %
in accordance with the standard
EN ISO 6789.
Excess-load signal
Unlimited loosening torque
Inserting the blade
Taking out the blade
Distinctly audible and noticeable
excess-load signal when the preset torque is reached.
Unlimited torque for loosening
seized screws.
According to the job, the insulated
inter-changeable blade with the
required tipstyle, or a switch
cabinet key is inserted into the
clamping mechanism.
By pulling and holding down the
clamping
sleeve
the
interchangeable screwdriver blade,
or the switch cabinet key, is
unlocked and can easily be taken
out of the handle.
Further versions in this product family:
art. no.
mm
nm
nm
mm
inch
05074752001
7440 VDE
9 mm
0.3-1.2
0.05
192
7 9/16
05074750001
7441 VDE
9 mm
1.2-3.0
0.10
192
7 9/16
05074757001
7444 VDE
9 mm
1.7-3.5
0.10
192
7 9/16
Web link
Wera - 7400 VDE
Wera Werkzeuge GmbH
02.08.2018 - 2 / 2
Powered by TCPDF (www.tcpdf.org)
D-42349 Wuppertal
很抱歉,暂时无法提供与“05074752001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1454.382471+187.95290
- 3+1354.526483+175.04830
- 5+1227.214455+158.59550
