05075830001
05075830001
    WERA(维拉)
    WERA - 05075830001 - Torque Wrench Set, A1, 2N-m to 12, 10 Pieces
05075830001 数据手册
Safe-Torque A 1 Set 1, 1/4" square head drive, 2-12 Nm, 10 pieces Safe-Torque torque wrenches EAN: 4013288223005 Size: 275x140x65 mm Part number: 05075830001 Weight: 1023 g Article number: Safe-Torque A 1 Set 1 Country of origin: CZ Customs tariff number: 82079030 Slip-over release mechanism - the set torque can never be overtightened Torque Lock function: The torque function can be deactivated and the tool can then be used as a standard ratchet with high loosening moments and for applications with defined angles of rotation For controlled clockwise and counterclockwise torque operation - tightening and loosening with or without torque Easy setting and saving of the desired torque value with audible and tactile clicks when reaching the scale values After the target torque has been reached, the release angle is only 30° The fine toothing with 72 teeth allows for a low return angle of 5° 1/4" square head drive with socket locking 10-piece 1/4" torque wrench set in a robust textile box; torque wrench with slide-over mechanism. Once the set torque has been reached, the tool cannot be overtightened, so that excessive torque cannot be applied. Setting range of 2 to 12 Nm for controlled clockwise and counterclockwise torque operation. Easy setting and saving of the default value: The audible and tactile clicks on reaching the scale values facilitate the safe setting of the desired torque value. The Torque Lock function allows use as a standard ratchet without torque function. Thus also usable for applications with angles of rotation. Max. breaking torque of the ¼" square head as per DIN 3122. The return angle of only 5° allows the ratchet to be used even in confined spaces. Included are: Safe-Torque A 1 torque wrench, 1/4" square head, 2-12 Nm, 8 sockets with 1/4" drive and one short extension. Web link https://products.wera.de/en/torque_tools_safe-torque_torque_wrenches_and_accessories_safe-torque_torque_wrenches_safe-torque_a_1_set_1.html Wera - Safe-Torque A 1 Set 1 05075830001 - 4013288223005 Wera Werkzeuge GmbH 03.10.2022 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Safe-Torque A 1 Set 1, 1/4" square head drive, 2-12 Nm, 10 pieces Safe-Torque torque wrenches Slide-over mechanism prevents application of excessive torques Torque Lock function For clockwise and counterclockwise operation Safe-Torque The Safe-Torque A 1 torque wrench is equipped with a slideover mechanism. Once the set torque value has been reached, the tool cannot be overtightened, so that excessive torque cannot be applied. The torque function can be deactivated. The Safe-Torque torque wrench can then also be used as a standard ratchet with high loosening moments and for applications with defined angles of rotation. The Safe-Torque torque wrench is suitable for clockwise and counterclockwise operation with a set torque. When the Torque Lock function is deactivated, tightening and loosening is enabled without torque. Easy torque setting Low return angle For 1/4" sockets Space for more tools Easy setting and saving of the required torque with audible and tactile clicks on reaching the scale values. The fine-toothed Safe-Torque torque wrench with 72 teeth has a back-pivoting angle of only 5°. The small stroke offers quick and precise working in all installation positions. The Safe-Torque A 1 torque wrench has 1/4" square head mounting and is suitable for 1/4" sockets. The Wera Belts can be attached to the hook and loop fastener strips in the textile box of the sets SafeTorque A 1 Set 1 and Safe-Torque A 1 Imperial Set 1, so more sockets and/or bit sockets can be stored and transported. Web link https://products.wera.de/en/torque_tools_safe-torque_torque_wrenches_and_accessories_safe-torque_torque_wrenches_safe-torque_a_1_set_1.html Wera - Safe-Torque A 1 Set 1 05075830001 - 4013288223005 Wera Werkzeuge GmbH 03.10.2022 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Safe-Torque A 1 Set 1, 1/4" square head drive, 2-12 Nm, 10 pieces Safe-Torque torque wrenches Set contents: Safe-Torque A 1 torque wrench with 1/4" square head drive, 2-12 Nm, 1/4" x 2-12 Nm 05075800001 1x 1/4" x 2-12 Nm 8790 HMA Zyklop 1/4" socket, 5.5 x 23 mm 05003504001 05003505001 05003506001 05003507001 05003509001 05003510001 05003511001 05003512001 1x 1x 1x 1x 1x 1x 1x 1x 5.5 x 23 mm 6 x 23 mm 7 x 23 mm 8 x 23 mm 10 x 23 mm 11 x 23 mm 12 x 23 mm 13 x 23 mm 8794 SA Zyklop extension with free-turning sleeve, short, 1/4", 1/4" x 75 mm 05003525001 1x 1/4" x 75 mm Hook and Loop Fastener Strip 240, 50 x 240 mm 1x 50 x 240 mm Web link https://products.wera.de/en/torque_tools_safe-torque_torque_wrenches_and_accessories_safe-torque_torque_wrenches_safe-torque_a_1_set_1.html Wera - Safe-Torque A 1 Set 1 05075830001 - 4013288223005 Wera Werkzeuge GmbH 03.10.2022 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05075830001 价格&库存
很抱歉,暂时无法提供与“05075830001”相匹配的价格&库存,您可以联系我们找货
    • 1+4054.31504
    库存:6
