05134011001
05134011001
    WERA(维拉)
    WERA - 05134011001 - Tool Kit, Wood Application, 134 Pieces
05134011001 数据手册
Wera 2go H 1 tool set for wood applications, 19 pieces Tool sets for wood applications EAN: 4013288217677 Size: 370x345x140 mm Part number: 05134011001 Weight: 7490 g Article number: Wera 2go H 1 Country of origin: CZ Customs tariff number: 82060000 Extensive 134-piece tool set in compact Wera 2go tool container for carpenters on the go Premium brand tools by Wera, BESSEY®, "KIRSCHEN"®, KNIPEX®, Lyra®, PICARD® and Stabila® Wera Kraftform Kompakt H 1 Wood (41-piece set) and Wera Bit-Safe 61 Wood 1 (61-piece set) 393 S extra slim bit hand holder with flexible shaft for applications in hard-to-reach work spaces Wera L-key with holding function: 967/9 TX XL Multicolour HF 1 (9-piece set) and 950/9 Hex-Plus Multicolour HF 1 (9-piece set) Web link https://products.wera.de/en/tools_by_trade_tool_sets_for_wood_applications_wera_2go_h_1.html Wera - Wera 2go H 1 05134011001 - 4013288217677 Wera Werkzeuge GmbH 05.03.2021 - 1 / 5 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Wera 2go H 1 tool set for wood applications, 19 pieces Tool sets for wood applications Compact tool set with the 134 most important tools for woodwork with products by Wera, BESSEY®, "KIRSCHEN"®, KNIPEX®, Lyra®, PICARD® and Stabila®. Mobility is made considerably easy thanks to the compact tool container from the Wera 2go system. 05134011001 1x Wera 2go 2 Tool Container 1x Bit-Safe 61 Wood 1 1x Kraftform Kompakt H 1 Woodcraft 1x 967/9 TX XL Multicolour HF 1 L-key set with holding function, long 1x 950/9 Hex-Plus Multicolour HF 1 L-key set, metric, BlackLaser, with holding function 1x 393 S bits hand holder extra slim with flexible shaft 1x KNIPEX® multigrip pliers COBRA® 250mm 87 11 250 1x KNIPEX® combination pliers 160mm 03 01 160 1x KNIPEX® carpenters' pincers 210mm 50 00 210 1x Stabila® spirit level type 81 25cm 02500 Torpedo 1x Carpenters' mallet 105mm 52-1 P 1x "KIRSCHEN"® bevelled-edge chisel 10mm 1001010 1x "KIRSCHEN"® bevelled-edge chisel 16mm 1001016 1x "KIRSCHEN"® bevelled-edge chisel 20mm 1001020 1x "KIRSCHEN"® bevelled-edge chisel 26mm 1001026 1x BESSEY® Folding utility knife DBKPHEU 1x Lyra® deep hole marker 4494102 1x Stabila® folding wooden yardstick type 601 N-S 2m 18206 1x PICARD® claw hammer 0008501-28 Web link https://products.wera.de/en/tools_by_trade_tool_sets_for_wood_applications_wera_2go_h_1.html Wera - Wera 2go H 1 05134011001 - 4013288217677 Wera Werkzeuge GmbH 05.03.2021 - 2 / 5 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Wera 2go H 1 tool set for wood applications, 19 pieces Tool sets for wood applications Set contents: Wera 2go 2 05004351001 Bit-Safe 61 Wood 1 05057442001 1 x 61 pieces 05057442001 1 x 61 pieces 05057442001 1 x 61 pieces 05057442001 1 x 61 pieces 1 x 3 pieces Kraftform Kompakt H1 Holz 051359390011) 1 x 41 pieces 051359390011) 1 x 41 pieces 051359390011) 1 x 41 pieces 051359390011) 1 x 41 pieces 051359390011) 1 x 41 pieces 051359390011) 1 x 41 pieces 051359390011) 1 x 41 pieces 051359390011) 1 x 41 pieces 051359390011) 1 x 41 pieces 051359390011) 1 x 41 pieces 967/9 TX XL Multicolour HF 1 05024470001 1 x 9 pieces 1) Product not available in the USA and Canada. 950/9 Hex-Plus Multicolour HF 1 05022210001 1 x 9 pieces Web link https://products.wera.de/en/tools_by_trade_tool_sets_for_wood_applications_wera_2go_h_1.html Wera - Wera 2go H 1 05134011001 - 4013288217677 Wera Werkzeuge GmbH 05.03.2021 - 3 / 5 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Wera 2go H 1 tool set for wood applications, 19 pieces Tool sets for wood applications Wera 2go 2 – The outside and inside packer L-keys with retaining function for hexagon socket screws Hex-Plus Wera 2go Tool Container with inner and outer hook and loop fastener system Individually configurable for greater mobility Ideal also for the docking of Wera textile boxes and pouches equipped with hook and loop fastener zones Easy insertion and removal Hands remain free during transport The clamping of the screw is achieved by a flexible locking ball. The holding function is especially helpful in confined, hard-to-reach spaces, where there is no room for a second hand to secure the screw on the tool. Hexagon screws can endure a problem because the contact surfaces delivering the power from the conventional tool, is transferred to the screw via very small surface areas. The consequence: the screw can become damaged (rounding out). Hex-Plus tools have a greater contact surface that prevents this from happening! At the same time, as much as 20 % more torque can be applied. Good to know: HexPlus tools fit into every standard hexagon socket screw! Web link https://products.wera.de/en/tools_by_trade_tool_sets_for_wood_applications_wera_2go_h_1.html Wera - Wera 2go H 1 05134011001 - 4013288217677 Wera Werkzeuge GmbH 05.03.2021 - 4 / 5 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Wera 2go H 1 tool set for wood applications, 19 pieces Tool sets for wood applications TORX® HF profile L-keys with a thermoplastic sleeve Flexible shaft Slim bit holder In tight assembly or disassembly situations, for example in engine compartments, it is not possible to securely hold the screw with the hand on the screwdriver, and the screw subsequently often gets lost. Lengthy searches or the loss of the screw (with the associated danger that could bring about) are the consequence. The HF tools developed by Wera are ideal because they feature an optimised geometry of the original TORX® profile. The wedging forces resulting from the surface pressure between the drive tip and the screw profile mean that the screw is securely held on the tool! L-keys with a thermoplastic sleeve are manufactured out of easy-togrip, circular material. The sleeve ensures that work is safe and comfortable even at low temperatures. High corrosion protection features thanks to the special BlackLaser surface treatment. Colour coding and large stamp to enable the desired L-key to be easily located. Around the corner screwdriving with the 393 S screwdriver. The flexible shaft allows to reach fixing screws in unfavourable positions. The ideal tool for srewdriving situations that are difficult to reach. The particularly slim bit holder allows working in very tight work spaces. Web link https://products.wera.de/en/tools_by_trade_tool_sets_for_wood_applications_wera_2go_h_1.html Wera - Wera 2go H 1 05134011001 - 4013288217677 Wera Werkzeuge GmbH 05.03.2021 - 5 / 5 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05134011001 价格&库存
很抱歉,暂时无法提供与“05134011001”相匹配的价格&库存,您可以联系我们找货
