110004
110004
    WERA(维拉)
110004 数据手册
335 Screwdriver for slotted screws, 0.8 x 4.0 x 100 mm Kraftform Plus – Series 300 EAN: 4013288003294 Size: 198x33x33 mm Part number: 05110004001 Weight: 54 g Article number: 335 Country of origin: CZ Customs tariff number: 82054000 Slotted screwdriver -electrician’s blade Multi-component Kraftform handle for fast and ergonomic screwdriving Take it easy tool finder: colour coding according to profile and size Hexagonal anti-roll feature against rolling away Lasertip tips for more secure fit in the screw head High quality Kraftform Plus screwdriver with electrician’s blade. Multi-component Kraftform Plus handle for pleasant, ergonomic working that makes blisters and calluses a thing of the past. Hard gripping zones for high working speeds whereas soft zones ensure high torque transfer. The tips of Wera Lasertip screwdrivers are microscopically roughened by means of laser beams. This rough surface literally bites into the head of the screw. Any unintentional slipping out is therefore prevented. “Take it easy” tool finder with colour coding according to profiles and size stamp – for simple and rapid accessing of the required tool. The hexagonal anti-roll feature prevents any bothersome rolling away at the workplace and handle markings make for simplified finding and sorting of the tool. Web link http://products.wera.de/en/screwdrivers_kraftform_plus__series_300_335.html Wera - 335 05110004001 - 4013288003294 Wera Werkzeuge GmbH 02.08.2018 - 1 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 335 Screwdriver for slotted screws, 0.8 x 4.0 x 100 mm Kraftform Plus – Series 300 Kraftform Plus screwdrivers – ergonomics you can grasp. They relieve the entire hand-arm system even when used intensively. Along with other technical and product advantages such as the Lasertip for a secure fit in the screw head, Kraftform screwdrivers are the ideal choice whenever manual screwdriving jobs are concerned. Lasertip prevents slipping out Lasertip Reduced contact pressure It happens time and time again that the tip slips out of the screw head when screwdriving, sometimes damaging valuable surfaces or even causing injury. The tips of the Wera Lasertip screwdrivers are microscopically roughened by means of a laser. This rough surface literally “bites” itself firmly into the screw head. Slipping out becomes a thing of the past. A precisely-focused laser creates a sharp-edged surface structure. This laser treatment results in an edge hardness of up to 1000 HV 0.3. Wera Lasertip “bites” itself into the screw head and prevents any slips out of the recess. It is available for screwdrivers for slotted, Phillips and Pozidriv screws. Wera Lasertip reduces the contact pressure required and enhances force transfer – meaning less screwdriving effort is required. Screwdriving becomes safer and easier. Web link http://products.wera.de/en/screwdrivers_kraftform_plus__series_300_335.html Wera - 335 05110004001 - 4013288003294 Wera Werkzeuge GmbH 02.08.2018 - 2 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 335 Screwdriver for slotted screws, 0.8 x 4.0 x 100 mm Kraftform Plus – Series 300 “Take it easy” Toolfinder Kraftform Prevents hand injuries Rapid hand repositioning Screwdrivers with “Take it easy” tool finder: colour coding according to profile and size stamp. The basic idea for the prototype of the Kraftform handle – that the hand should dictate the design – has, right through to today, proved to be correct. In cooperation with the internationally recognised Fraunhofer IAO Institute, Wera developed a screwdriver handle designed to match the shape of the human hand as long ago as the 1960s. After a long development phase, the Wera Kraftform handle was launched to the market in 1968. It has been optimised through the years with new technologies, but has kept its proven shape. After all, the human hand has not changed either. The outstanding design of the Kraftform handle that fits perfectly into the hand prevents hand injuries such as blisters and calluses. The hard materials used for the handle ensure rapid hand repositioning without any danger of the skin “sticking” to the handle. The surrounding hard zones with large diameters glide like wheels across the hand. Web link http://products.wera.de/en/screwdrivers_kraftform_plus__series_300_335.html Wera - 335 05110004001 - 4013288003294 Wera Werkzeuge GmbH 02.08.2018 - 3 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 335 Screwdriver for slotted screws, 0.8 x 4.0 x 100 mm Kraftform Plus – Series 300 Further versions in this product family: mm mm mm mm mm inch inch 1) 0.4 2.0 60 70 2.5 5/64 2 3/8 1) 0.4 2.5 60 70 2.5 3/32 2 3/8 1) 0.4 2.5 75 70 2.5 3/32 3 1) 0.5 3.0 150 81 4.0 1/8 6 05008009001 1) 0.5 3.0 200 81 4.0 1/8 8 051100010011) 0.5 3.0 80 81 3.0 1/8 3 1/8 05008015001 0.6 3.5 100 81 3.5 9/64 4 05110002001 0.6 3.5 125 81 3.5 9/64 5 05110003001 0.6 3.5 200 81 3.5 9/64 8 05110004001 0.8 4.0 100 98 4.0 5/32 4 05110005001 0.8 4.0 150 98 4.0 5/32 6 05110006001 0.8 4.0 200 98 4.0 5/32 8 05008027001 0.8 4.0 300 98 4.0 5/32 12 05110007001 1.0 5.5 125 98 5.5 7/32 5 05008055001 1.0 5.5 150 98 5.5 7/32 6 05110008001 1.0 5.5 200 98 5.5 7/32 8 05008060001 1.0 5.5 300 98 5.5 7/32 12 05008061001 1.2 6.0 100 105 6.0 5/16 4 05008006001 05110000001 05008007001 05008008001 1) 1) 1) without Lasertip Web link http://products.wera.de/en/screwdrivers_kraftform_plus__series_300_335.html Wera - 335 05110004001 - 4013288003294 Wera Werkzeuge GmbH 02.08.2018 - 4 / 4 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
110004 价格&库存
很抱歉,暂时无法提供与“110004”相匹配的价格&库存,您可以联系我们找货
