118024
118024
    WERA(维拉)
118024 数据手册
2050 PH Screwdriver for Phillips screws for electronic applications, PH 1 x 80 mm Series Kraftform Micro EAN: 4013288031983 Size: 177x13x13 mm Part number: 05118024001 Weight: 20 g Article number: 2050 PH Micro Country of origin: CZ Customs tariff number: 82054000 Kraftform Micro screwdriver for cross-recess Phillips screws Multi-component Kraftform Micro handle for fast and ergonomic screwdriving Anti-roll feature and swivel cap for rapid twisting The Wera Black Point tip offers an exact fit and optimum corrosion protection E.g. for electricians, opticians, precision mechanics, jewellers or IT hardware fitters High quality Wera Micro screwdriver for precision mechanical jobs. Rapid twisting results from fixing the hand on the head and using the fast-turning zone just below. This makes time-consuming grip adjustments unnecessary. Power zones with integrated soft sections ensure the transfer of high loosening and tightening torque; a precision zone for the right rotation angle during fine adjustment work. The Black Point tip offers optimised corrosion protection and an exact fit. Web link http://products.wera.de/en/screwdrivers_series_kraftform_micro_2050_ph_micro.html Wera - 2050 PH Micro 05118024001 - 4013288031983 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 2050 PH Screwdriver for Phillips screws for electronic applications, PH 1 x 80 mm Series Kraftform Micro Kraftform Micro Handle The refined screwdriver for electronics technicians The precision zone Screwdriving jobs in electrical and precision engineering applications are often tedious and timeconsuming. We learned from users what is important for them: working speeds, torque, precision – and we then focused particularly on these issues. Multi-component screwdriver handle for ergonomic working. The Kraftform Micro, with its three zones and their specific arrangement, satisfies these requirements perfectly. The freeturning cap that provides support for the hand works with these advantages, enabling quick and easy precision work. The precision zone directly above the blade gives the user a better feel for the right rotation angle during fine adjustment work. The power zone The fast-turning zone Wera Black Point tip Applications The power zone has integrated soft zones near the blade tip to ensure high torque transfer for loosening or tightening screws without losing contact with the screw. The fast-turning zone just below the rotating cap allows rapid twisting. The Wera Black Point tip and a refined hardening process ensure long service life of the tip, improved corrosion protection and an exact fit. Indispensable for many users, including electronics technicians, opticians, precision engineers, jewellers, EDP hardware fitters and model-makers. Web link http://products.wera.de/en/screwdrivers_series_kraftform_micro_2050_ph_micro.html Wera - 2050 PH Micro 05118024001 - 4013288031983 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 2050 PH Screwdriver for Phillips screws for electronic applications, PH 1 x 80 mm Series Kraftform Micro Further versions in this product family: mm mm mm inch PH 000 40 97 1.5/2.5 1 9/16 PH 00 40 97 1.8/2.5 1 9/16 PH 00 60 97 2.5 2 3/8 PH 0 40 97 3.0 1 9/16 05118022001 PH 0 60 97 3.0 2 3/8 05118023001 PH 1 60 97 4.0 2 3/8 05118024001 PH 1 80 97 4.0 3 1/8 1),2) 1),2) 1) 3) 3) 05345290001 05118019001 05118020001 05118026001 1) Optimised for Asian PH screws 2) On the output side, the blade is turned to a nominal length of 10 mm. 3) Size 0 modificated according to JCIS 0 (Japanese Camera Industrial Standard) Web link http://products.wera.de/en/screwdrivers_series_kraftform_micro_2050_ph_micro.html Wera - 2050 PH Micro 05118024001 - 4013288031983 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
118024 价格&库存
很抱歉,暂时无法提供与“118024”相匹配的价格&库存,您可以联系我们找货
