967L/9 HF TORX
967L/9 HF TORX
    WERA(维拉)
    WERA - 967L/9 HF TORX - 9 Piece BlackLaser TORX HF L-Key Set with Holding Function in Two Component ...
967L/9 HF TORX 数据手册
967 L/9 TORX® HF L-key set with holding function, BlackLaser, 9 pieces L-Keys for TORX® Screws EAN: 4013288104953 Size: 139x72x25 mm Part number: 05024244001 Weight: 195 g Article number: 967/9 TX HF 1 Country of origin: CZ Customs tariff number: 82054000 L-keys for recessed TORX® screws Holding function for recessed TORX® screws BlackLaser for high corrosion protection and long service life L-keys are quickly to hand thanks to their size markings Wear-resistant clip material for enhanced durability High quality L-key set for recessed TORX® screws. Holding function: the wedging forces resulting from the contact pressure between the drive tip and the screw profile securely hold the screw on the tool. Featuring an extra-long arm. The BlackLaser surface treatment provides outstanding surface protection, even against corrosion, and a long service life. The tools are quickly to hand thanks to the laser-engraved and thereby wearresistant size markings on the L-keys. Come in a practical clip fastener out of wear-resistant material, enabling secure storage of the L-keys as well as simple removal. Web link http://products.wera.de/en/l-keys_l-keys_for_torx_screws_967_9_tx_hf_1.html Wera - 967/9 TX HF 1 05024244001 - 4013288104953 Wera Werkzeuge GmbH 02.08.2018 - 1 / 2 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 967 L/9 TORX® HF L-key set with holding function, BlackLaser, 9 pieces L-Keys for TORX® Screws Set contents: 967 L TORX® HF 05024160001 1 x TX 8x76 05024161001 1 x TX 9x79 05024162001 1 x TX 10x85 05024163001 1 x TX 15x90 05024164001 1 x TX 20x96 05024165001 1 x TX 25x104 05024166001 1 x TX 27x112 05024167001 1 x TX 30x122 05024168001 1 x TX 40x132 TORX® HF profile Surface protection Size identification Secure hold and easy removal In tight assembly or disassembly situations, for example in engine compartments, it is not possible to securely hold the screw with the hand on the screwdriver, and the screw subsequently often gets lost. Lengthy searches or the loss of the screw (with the associated danger that could bring about) are the consequence. The HF tools developed by Wera are ideal because they feature an optimised geometry of the original TORX® profile. The wedging forces resulting from the surface pressure between the drive tip and the screw profile mean that the screw is securely held on the tool! L-keys with BlackLaser surface treatment for outstanding surface protection and long service life. High corrosion protection. The size of each L-keys has been engraved by a laser. In addition SPKL L-keys have a colour coding according to sizes – for simple and rapid accessing of the required tool. Making it easy to find the right tool. The wear-resistant clip material ensures that the L-keys are securely held yet are easy to remove. Web link http://products.wera.de/en/l-keys_l-keys_for_torx_screws_967_9_tx_hf_1.html Wera - 967/9 TX HF 1 05024244001 - 4013288104953 Wera Werkzeuge GmbH 02.08.2018 - 2 / 2 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
967L/9 HF TORX 价格&库存
很抱歉,暂时无法提供与“967L/9 HF TORX”相匹配的价格&库存,您可以联系我们找货
