BELT B 3
BELT B 3
    WERA(维拉)
    WERA - BELT B 3 - Socket Set, Bit, Hex, TORX HF Zyklop Series, Belt B3, 9 Piece
BELT B 3 数据手册
Belt B 3 TORX® HF Zyklop bit socket set with holding function, 3/8" drive, 9 pieces Zyklop Accessories, 3/8" EAN: 4013288194961 Size: 320x80x50 mm Part number: 05003972001 Weight: 470 g Article number: Belt B 3 Country of origin: TW Customs tariff number: 82042000 9-piece bit-socket set on a robust textile belt, 3/8" In-hex sockets with all the advantages of the Wera bit technology In-hex sockets with holding function for screws/bolts Smooth Twist to Unlock mechanism for a secure fit and simple removal of the sockets Suitable for attachment to a wall, shelf, tool trolley and to the Wera 2go System Typically Wera designed robust textile belt with 9 sockets taking up minimal space. A smooth Twist to Unlock mechanism ensures a secure fit and simple removal of the sockets. Comes with „Take it easy“ Tool Finder with colour coding according to size to enable the right tool to be selected easily and quickly. Includes a snap hook for secure fastening to a belt loop or pocket. Especially short, stable bit-sockets with all the advantages of the Wera bit technology. Bit sockets with holding function for particularly convenient screwdriving with reduced risk of losing the screw when approaching the workpiece. Supplied with a nonwoven reverse side and hook and loop strips for simple attachment e.g. to a wall, shelf, tool trolley and to the Wera 2go tool transport system. Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_belt_b_3.html Wera - Belt B 3 05003972001 - 4013288194961 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Belt B 3 TORX® HF Zyklop bit socket set with holding function, 3/8" drive, 9 pieces Zyklop Accessories, 3/8" Set contents: 8767 B HF 05003059001 05003060001 05003061001 05003062001 05003064001 05003066001 05003068001 05003070001 05003072001 1 x TX 10x35.0 1 x TX 15x35.0 1 x TX 20x35.0 1 x TX 25x35.0 1 x TX 27x35.0 1 x TX 30x35.0 1 x TX 40x35.0 1 x TX 45x38.5 1 x TX 50x38.5 Klettstreifen 30 0511990181 0511990181 0511990181 0511990181 0511990181 0511990181 0511990181 0511990181 0511990181 0511990181 0511990181 0511990181 0511990181 0511990181 1 x 30.0x200.0 1 x 30.0x200.0 1 x 30.0x200.0 1 x 30.0x200.0 1 x 30.0x200.0 1 x 30.0x200.0 1 x 30.0x200.0 1 x 30.0x200.0 1 x 30.0x200.0 1 x 30.0x200.0 1 x 30.0x200.0 1 x 30.0x200.0 1 x 30.0x200.0 1 x 30.0x200.0 Belt B 0/9 05681326001 05681326001 05681326001 05681326001 1 x 45.0x310.0 1 x 45.0x310.0 1 x 45.0x310.0 1 x 45.0x310.0 Wera Belts Practical nonwoven strips Comes with convenient snap hook Bit sockets with holding function for TORX® screws Whoever would have thought that the storage of sockets could be completely revolutionised and that someone could come up with a stylish belt with securely attached sockets that can still be easily removed. The textile belt can be attached by means of the nonwoven reverse side and the hook and loop strips e.g. to a wall, shelf, tool trolley and to the Wera 2go tool transport system. The robust textile belt can be secured to a belt loop or pocket by means of the snap hook. The HF tools developed by Wera are ideal because they feature an optimised geometry of the original TORX® profile. The wedging forces resulting from the surface pressure between the drive tip and the screw profile mean that TORX® screws made according to Acument Intellectual Properties specifications are securely held on the tool! Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_belt_b_3.html Wera - Belt B 3 05003972001 - 4013288194961 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Belt B 3 TORX® HF Zyklop bit socket set with holding function, 3/8" drive, 9 pieces Zyklop Accessories, 3/8" Take it easy tool finder system Secure hold and easy removal Manual and machine sockets Zyklop Accessories Take it easy tool finder system with profile and size colour-coding for quick and easy tool selection. Colour-coded system for hexagon drive screws (L-Keys, Zyklop bit sockets), external hex drive screws and nuts (Joker wrenches, Zyklop sockets and Zyklop bit sockets with holding function), and TORX® drive screws (L-Keys, Zyklop bit sockets). The all new smooth turning mechanism guarantees both secure and rattle-free storage, yet allows easy removal of the tool. The manual and machine sockets can be used both for hand and power tools use (non-impact). Users need just one socket set for all applications. We did not just want our creativity to end with the ratchets themselves so we also occupied ourselves intensively with ratchet accessories. That is why our users are now provided with an extension with freely spinning sleeve and flexible lock to enable more secure and more rapid screwdriving. The sockets have been completely redesigned: we wanted to spare the user the need of having two different series – one for manual and the other for power tool applications. And: we wanted to enormous simplify the task of finding the right sizes. Technically, our own ambitious goals represented a real challenge: to endow sockets with the advantage of the holding function on screwdrivers and bits. We succeeded in this! Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_belt_b_3.html Wera - Belt B 3 05003972001 - 4013288194961 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
BELT B 3 价格&库存
很抱歉,暂时无法提供与“BELT B 3”相匹配的价格&库存,您可以联系我们找货
