05003433001
05003433001
    WERA(维拉)
    WERA - 05003433001 - Screwdriver, Interchangeable, Torx, T20, 154 mm Overall, Kraftform Kompakt
05003433001 数据手册
Kraftform Kompakt VDE 67 i TORX®, TX 20 x 154 mm Kraftform Kompakt VDE EAN: 4013288104274 Size: 154x13x13 mm Part number: 05003433001 Weight: 22 g Article number: KK 67 i TORX® Country of origin: CZ Customs tariff number: 82054000 Kraftform Kompakt VDE interchangeable blade for TORX® screws Insulated, individually tested as per IEC 60900 9 mm hex drive with lead-in chamfer The Wera Black Point tip offers an exact fit and optimum corrosion protection Individually tested VDE blades for Kraftform Kompakt handle/interchangeable blade system for rapid exchange of the blades without any special tools. Individually tested as per IEC 60900. Individual testing in a water bath at 10,000 volts so as to ensure safe working at the permitted voltage of 1,000 volts. Web link http://products.wera.de/en/vde_tools_kraftform_kompakt_vde_kk_67_i_torx.html Wera - KK 67 i TORX® 05003433001 - 4013288104274 Wera Werkzeuge GmbH 02.08.2018 - 1 / 2 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Kraftform Kompakt VDE 67 i TORX®, TX 20 x 154 mm Kraftform Kompakt VDE Why is the right tool so often missing at the workplace? The reason: too many tools and overlyheavy tool bags can make it bothersome to carry keep them with you. So for us it was a clear challenge: to develop a tool that is suitable for a whole host of applications and can be easily taken along to the workplace. Our solution: Kraftform Kompakt tools. A handle into which blades with a range of different profiles can be inserted. Compactly and protectively housed in a light and robust textile pouch – and they are even VDE-tested, too. Individually tested Handle/interchangeable blade system – Kraftform Kompakt VDE Handle/interchangeable blade system – Kraftform Kompakt VDE Our screwdrivers are tested for dielectric strength under a 10,000 volt load to make sure that their most important property, their insulation, has been exhaustively tested. Each individual Wera VDE screwdriver is subjected to this test to guarantee safe working up to 1,000 volts. Suitable for Kraftform handles 7400 VDE and 817 VDE . The handle/interchangeable blade system allows rapid exchange of the blades required for a wide range of applications. Further versions in this product family: mm inch 05003429001 TX 8 154 6 1/16 05003430001 TX 9 154 6 1/16 05003431001 TX 10 154 6 1/16 05003432001 TX 15 154 6 1/16 05003433001 TX 20 154 6 1/16 05003434001 TX 25 154 6 1/16 05003435001 TX 27 154 6 1/16 05003436001 TX 30 154 6 1/16 Web link http://products.wera.de/en/vde_tools_kraftform_kompakt_vde_kk_67_i_torx.html Wera - KK 67 i TORX® 05003433001 - 4013288104274 Wera Werkzeuge GmbH 02.08.2018 - 2 / 2 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05003433001 价格&库存
很抱歉,暂时无法提供与“05003433001”相匹配的价格&库存,您可以联系我们找货
  • 1+56.165781+7.26590
  • 3+52.584443+6.80260
  • 5+47.343475+6.12460
库存:1
05003433001
库存:1
