05051017001
05051017001
    WERA(维拉)
    WERA - 05051017001 - HEX BIT SET, 13PC
05051017001 数据手册
Kraftform Kompakt 20 Tool Finder 2 with pouch, 13 pieces Innovations and Autumn/Winter Campaign 2019/2020 EAN: 4013288211224 Size: 173x80x73 mm Part number: 05051017001 Weight: 403 g Article number: Kraftform Kompakt 20 Tool Country of origin: Finder 2 Customs tariff number: CZ 82079030 Kraftform bit hand-holder with bayonet blade and Rapidaptor quick-change chuck Kraftform handle with anti-roll feature, multi-component and integrated magazine Retractable bayonet blade 6x25mm bits with “Take it easy" tool finder: colour coding by profile and size stamping and 6x89mm bits Bits with high corrosion protection due to nickel chemical coating 13-piece Kraftform Kompakt set with 6x 25mm long and 6x 89mm long bits. Wera’s compact tools allow the simultaneous use of both types of screw connections; „hand“ or „machine“. The handle blade-change system in a compact design with different compact blade tips makes the user mobile and flexible. Suitable for bits with 1/4“ hexagonal drive as per DIN ISO 1173-C 6.3 and E 6.3 (ISO 1173) and Wera connection series 1 and 4. With connecting adapter, bayonet, Rapidaptor technology, Kraftform handle with anti-roll protection, multi-components allow for particularly ergonomic screwdriving. Integrated magazine for storing 25mm long bits. This set replaces a 12-piece screwdriver set and reduces the necessary equipment to a minimum. Profile and size of the bits are easily recognizable due to the Wera “Take it easy" tool finder with its colour coding and easily visible labels. Bits with high corrosion protection due to nickel chemical coating. Web link Wera - Kraftform Kompakt 20 Tool Finder 2 05051017001 - 4013288211224 Wera Werkzeuge GmbH 16.08.2019 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Kraftform Kompakt 20 Tool Finder 2 with pouch, 13 pieces Innovations and Autumn/Winter Campaign 2019/2020 Set contents: 889/4 R 05052504001 1 x 1/4" x 100 mm 851/1 BTZ PH 05056420001 05056422001 855/1 BTZ PZ 05056720001 05056722001 1 x PZ 1 x 25 mm 1 x PZ 2 x 25 mm 867/1 TORX® BTZ 05066124001 1 x TX 20 x 25 mm 05066126001 1 x TX 25 x 25 mm 851/4 Z PH 05059760001 05059775001 1 x PH 1 x 89 mm 1 x PH 2 x 89 mm 855/4 Z PZ 05060029001 05060035001 1 x PH 1 x 25 mm 1 x PH 2 x 25 mm 1 x PZ 1 x 89 mm 1 x PZ 2 x 89 mm 867/4 Z TORX® 05060188001 1 x TX 20 x 89 mm 05060189001 1 x TX 25 x 89 mm Telescopic blade, integrated bit magazine, Rapidaptor technology Handle/interchangeable blade system The telescopic blade I The telescopic blade II The sets in the series Kraftform Kompakt 20 are really something. A 2 position telescopic blade can be retracted into the handle for confined space operation or extended for more reach. It can also be removed and used as a 100mm bit holder in the power tool. Six bits are conveniently integrated into a push-button opening bit magazine. The Rapidaptor technology ensures rapid one hand bit changes, pressin auto bit lock and a secure positioning when used in power tools thanks to the free-turning sleeve. The handle/interchangeable blade system allows rapid exchange of the blades required for a wide range of applications. When the unique telescopic blade is lowered into the handle, fast, easy screw-driving action is possible, even in the tightest spots! By pushing the clamping sleeve, the telescopic blade can be extended out of the handle and the compact tool becomes a full-sized screwdriver. Web link Wera - Kraftform Kompakt 20 Tool Finder 2 05051017001 - 4013288211224 Wera Werkzeuge GmbH 16.08.2019 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Kraftform Kompakt 20 Tool Finder 2 with pouch, 13 pieces Innovations and Autumn/Winter Campaign 2019/2020 The telescopic blade III “Take it easy” tool finder Prevents hand injuries Kraftform If the clamping sleeve is pushed again the telescopic blade can be taken out of the handle, and be used as a machine bit adaptor. “Take it easy" tool finder with colour coding according to profiles and size stamp – for simple and rapid accessing of the required tool. The outstanding design of the Kraftform handle that fits perfectly into the hand prevents hand injuries such as blisters and calluses. The basic idea for the prototype of the Kraftform handle – that the hand should dictate the design – has, right through to today, proved to be correct. In cooperation with the internationally recognised Fraunhofer IAO Institute, Wera developed a screwdriver handle designed to match the shape of the human hand as long ago as the 1960s. After a long development phase, the Wera Kraftform handle was launched to the market in 1968. It has been optimised through the years with new technologies, but has kept its proven shape. After all, the human hand has not changed either. Web link Wera - Kraftform Kompakt 20 Tool Finder 2 05051017001 - 4013288211224 Wera Werkzeuge GmbH 16.08.2019 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05051017001 价格&库存
很抱歉,暂时无法提供与“05051017001”相匹配的价格&库存,您可以联系我们找货
    • 1+838.07437
    库存:24
