05105623001
05105623001
    WERA(维拉)
    WERA - 05105623001 - Screwdriver Set, Kraftform Plus, 7 Pc
05105623001 数据手册
Kraftform 300/7 set 1 screwdriver set Kraftform Plus, 7 pieces News and Promotional Products Autumn/Winter 2020/2021 EAN: 4013288217608 Size: 275x175x60 mm Part number: 05105623001 Weight: 921 g Article number: Kraftform 300/7 Set 1 Country of origin: CZ Customs tariff number: 82054000 7-piece set in compact, textile box with Wera 2go compatibility Take it easy tool finder: colour coding according to profile and size Lasertip tips for more secure fit in the screw head Multi-component Kraftform handle for fast and ergonomic screwdriving Smooth hard zones for high speed turning, soft grip zones for high torque transfer 7-piece screwdriver set with Kraftform Plus handle for comfortable ergonomic screwdriving, which avoids blisters and calluses. Hard handle zones for high working speeds, while soft handle zones guarantee a high torque transfer. Includes some tools with Lasertip blades: The tip clings to the screw head and prevents it slipping out. Take it easy tool finder with colour coding and size stamping - for easy and fast location of the required tool. The anti-roll protection avoids bits from annoying rolling away in the workplace. Web link https://products.wera.de/en/screwdrivers_kraftform_plus__series_300_kraftform_300_7_set_1.html Wera - Kraftform 300/7 Set 1 05105623001 - 4013288217608 Wera Werkzeuge GmbH 03.09.2020 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Kraftform 300/7 set 1 screwdriver set Kraftform Plus, 7 pieces News and Promotional Products Autumn/Winter 2020/2021 Set contents: 350 PH 05008710001 05008720001 1 x PH 1 x 80 mm 1 x PH 2 x 100 mm 367 TORX® 05028008001 05028010001 05028012001 1 x TX 15 x 80 mm 1 x TX 20 x 100 mm 1 x TX 25 x 100 mm K240 11990178 1 x 240 x 50 mm Kraftform Plus screwdrivers – ergonomics you can grasp. They relieve the entire hand-arm system even when used intensively. Along with other technical and product advantages such as the Lasertip for a secure fit in the screw head, Kraftform screwdrivers are the ideal choice whenever manual screwdriving jobs are concerned. 355 PZ 05009315001 1 x PZ 2 x 100 mm 335 05110004001 1 x 0.8 x 4 x 100 mm Suitable for Wera 2go Lasertip prevents slipping out Lasertip Suitable for docking with the Wera 2go system. It happens time and time again that the tip slips out of the screw head when screwdriving, sometimes damaging valuable surfaces or even causing injury. The tips of the Wera Lasertip screwdrivers are microscopically roughened by means of a laser. This rough surface literally "bites" itself firmly into the screw head. Slipping out becomes a thing of the past. A precisely-focused laser creates a sharp-edged surface structure. This laser treatment results in an edge hardness of up to 1000 HV 0.3. Wera Lasertip "bites" itself into the screw head and prevents any slips out of the recess. It is available for screwdrivers for slotted, Phillips and Pozidriv screws. Web link https://products.wera.de/en/screwdrivers_kraftform_plus__series_300_kraftform_300_7_set_1.html Wera - Kraftform 300/7 Set 1 05105623001 - 4013288217608 Wera Werkzeuge GmbH 03.09.2020 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Kraftform 300/7 set 1 screwdriver set Kraftform Plus, 7 pieces News and Promotional Products Autumn/Winter 2020/2021 Reduced contact pressure Prevents hand injuries Rapid hand repositioning “Take it easy” Tool Finder Wera Lasertip reduces the contact pressure required and enhances force transfer – meaning less screwdriving effort is required. Screwdriving becomes safer and easier. The outstanding design of the Kraftform handle that fits perfectly into the hand prevents hand injuries such as blisters and calluses. The hard materials used for the handle ensure rapid hand repositioning without any danger of the skin "sticking" to the handle. The surrounding hard zones with large diameters glide like wheels across the hand. Screwdrivers with "Take it easy" tool finder: colour coding according to profile and size stamp. Web link https://products.wera.de/en/screwdrivers_kraftform_plus__series_300_kraftform_300_7_set_1.html Wera - Kraftform 300/7 Set 1 05105623001 - 4013288217608 Wera Werkzeuge GmbH 03.09.2020 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05105623001 价格&库存
很抱歉,暂时无法提供与“05105623001”相匹配的价格&库存,您可以联系我们找货
