05134019001
05134019001
    WERA(维拉)
    WERA - 05134019001 - Screwdriver Set, 25 Piece, Phillips/TORX/TORX PLUS/Pentalobe/Slotted/Hex, Kraft...
05134019001 数据手册
Kraftform Micro ESD Big Pack 1 Screwdriver set for electronic applications, 25 pieces ESD Series EAN: 4013288219459 Size: 235x105x80 mm Part number: 05134019001 Weight: 556 g Article number: Kraftform Micro ESD Big Pack 1 Country of origin: CZ Customs tariff number: 82054000 ESD-safe tool thanks to surface resistance of ≤ 10^9 Ohm The fast-turning zone just below the rotating cap allows rapid twisting The Wera Black Point tip offers an exact fit and optimum corrosion protection Multi-component Kraftform Micro handles for fast and ergonomic screwdriving Included profiles especially suitable for servicing mobile phones, tablets and laptops/desktops Electrostatically secured Wera Micro screwdriver 25-piece set. The included screw profiles are especially suitable for the use on mobile phones and tablets. Safe protection against electrostatic energy and associated damage. By supporting the hand on the rotating cap, and by the fast rotating zone below the rotating cap, lightning fast turning is possible. Time-consuming hand switching is eliminated. The power zone with integrated soft zones ensures the transmission of high tightening and loosening moments. Precision zone for correct rotation angles whilst adjusting. The Black Point tip provides fitting accuracy and optimum corrosion protection. Take it easy tool finder with size stamping and colour coding by profile to find the required tool quickly and easily. Storage and transport in a robust textile bag, so the tool is well protected and always close at hand. Web link https://products.wera.de/en/screwdrivers_esd_series_kraftform_micro_esd_big_pack_1.html Wera - Kraftform Micro ESD Big Pack 1 05134019001 - 4013288219459 Wera Werkzeuge GmbH 01.03.2021 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Kraftform Micro ESD Big Pack 1 Screwdriver set for electronic applications, 25 pieces ESD Series Set contents: 1550 PH ESD Micro 050301170011),2) 1 x PH 000 x 40 mm 050301180011),2) 1 x PH 00 x 40 mm 050301190013) 1 x PH 0 x 40 mm 05030112001 1 x PH 1 x 80 mm 1550 PH S ESD Micro 05030109001 1 x # 1 x 40 mm 1) Optimised for Asian PH screws 2) On the output side, the blade is turned to a nominal length of 10 mm 3) Size 0 modificated according to JCIS 0 (Japanese Camera Industrial Standard) 1567 TORX® HF ESD Micro 05030404001 1 x TX 8 x 60 mm 05030406001 1 x TX 10 x 60 mm 1567 TORX® ESD Micro 05030158001 1 x TX 2 x 40 mm 05030159001 1 x TX 3 x 40 mm 05030120001 1 x TX 4 x 40 mm 05030121001 1 x TX 5 x 40 mm 05030122001 1 x TX 6 x 40 mm 1567 TORX® BO ESD Micro 05030113001 1 x TX 6 BO x 60 mm 05030114001 1 x TX 8 BO x 60 mm 1567 TORX PLUS® IPR ESD 050301350011) 1 x 1 IPR x 40 mm 1572 ESD 05030080001 05030081001 05030082001 05030083001 1 x m x 40 mm 1 x 00 x 40 mm 1 x F x 40 mm 1 x 0 x 40 mm 1573 Pentalobe ESD 05030330001 1 x PL 1.1 x 40 mm 05030331001 1 x PL 1.4 x 40 mm 1569 ESD 05030414001 1 x 3 x 60 mm 1529 ESD 05027450001 1 x 1 x 3.5 x 50 mm 1) Without bore hole 1578 A ESD Micro 05030099001 1 x 0.16 x 0.8 x 40 mm 05030101001 1 x 0.23 x 1.5 x 40 mm Web link https://products.wera.de/en/screwdrivers_esd_series_kraftform_micro_esd_big_pack_1.html Wera - Kraftform Micro ESD Big Pack 1 05134019001 - 4013288219459 Wera Werkzeuge GmbH 01.03.2021 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Kraftform Micro ESD Big Pack 1 Screwdriver set for electronic applications, 25 pieces ESD Series For mobile phones, tablets and laptops/desktops. High protection Kraftform Micro handle For mobile phones, tablets and laptops/desktops. The screwdriver profiles included in this set are especially suitable for service works on mobile phones, tablets and laptops/desktops. The electric surface resistance of the Wera ESD material is ≤ 10^9 ohm. This securely protects components against electrostatic energy and associated damage. Multi-component screwdriver handle for ergonomic working. The precision zone The power zone The fast-turning zone “Take it easy” Tool Finder The precision zone directly above the blade gives the user a better feel for the right rotation angle during fine adjustment work. The power zone has integrated soft zones near the blade tip to ensure high torque transfer for loosening or tightening screws without losing contact with the screw. The fast-turning zone just below the rotating cap allows rapid twisting Screwdrivers with "Take it easy" tool finder: colour coding according to profile and size stamp. Web link https://products.wera.de/en/screwdrivers_esd_series_kraftform_micro_esd_big_pack_1.html Wera - Kraftform Micro ESD Big Pack 1 05134019001 - 4013288219459 Wera Werkzeuge GmbH 01.03.2021 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05134019001 价格&库存
很抱歉,暂时无法提供与“05134019001”相匹配的价格&库存,您可以联系我们找货
  • 1+1963.40401
库存:11
