3334/3355/6
3334/3355/6
    WERA(维拉)
3334/3355/6 数据手册
3334/3355/6 Screwdriver set, stainless and rack, 6 pieces Series Kraftform Screwdrivers Stainless Steel EAN: 4013288111395 Size: 285x210x55 mm Part number: 05032061001 Weight: 658 g Article number: 3334/3355/6 Country of origin: CZ Customs tariff number: 82054000 Stainless screwdriver for slotted and cross-recess screws, Pozidriv Multi-component Kraftform handle for fast and ergonomic screwdriving Take it easy tool finder: colour coding according to profile and size Hexagonal anti-roll feature against rolling away Lasertip tip, stainless to prevent extraneous rust High quality Kraftform Plus screwdriver set out of stainless steel. The stainless tools from Wera are vacuum ice-hardened and have the hardness and strength needed for screw connections. They can be used for industrial application without hesitation. The Lasertip tip literally bites into the head of the screw and thereby prevents any slipping out of the screw head. Multi-component Kraftform handle for fast and low-fatigue working. “Take it easy” tool finder with colour coding according to profiles and size stamp – for simple and rapid accessing of the required tool. The hexagonal anti-roll feature prevents any bothersome rolling away at the workplace. Includes a practical rack for tidy storage of the screwdrivers. Web link http://products.wera.de/en/screwdrivers_series_kraftform_screwdrivers_stainless_steel_3334_3355_6.html Wera - 3334/3355/6 05032061001 - 4013288111395 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 3334/3355/6 Screwdriver set, stainless and rack, 6 pieces Series Kraftform Screwdrivers Stainless Steel Set contents: 3355 PZ 05032031001 05032032001 3335 050320010011),1),1) 1 x 0.5x3.0x80 05032003001 1 x 0.8x4.0x100 050320040011) 1 x 1.0x5.5x125 1 x PZ 1x80 1 x PZ 2x100 1) without Lasertip 3334 05032005001 Screw stainless steel together with stainless steel! 1 x 1.2x6.5x150 Screw stainless steel together with stainless steel! Vacuum ice-hardened Lasertip prevents slipping out Solution to the rust problem: screw stainless steel together with stainless steel! Wera stainless steel tools are manufactured out of stainless steel so unsightly rust can be avoided. The stainless steel tools from Wera are vacuum ice-hardened and have the hardness and strength needed for screw connections. There are no limitations to the industrial applications they are suitable for. It happens time and time again that the tip slips out of the screw head when screwdriving, sometimes damaging valuable surfaces or even causing injury. The tips of the Wera Lasertip screwdrivers are microscopically roughened by means of a laser. This rough surface literally “bites” itself firmly into the screw head. Slipping out becomes a thing of the past. Web link http://products.wera.de/en/screwdrivers_series_kraftform_screwdrivers_stainless_steel_3334_3355_6.html Wera - 3334/3355/6 05032061001 - 4013288111395 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 3334/3355/6 Screwdriver set, stainless and rack, 6 pieces Series Kraftform Screwdrivers Stainless Steel Lasertip “Take it easy” Toolfinder Kraftform Prevents hand injuries A precisely-focused laser creates a sharp-edged surface structure. This laser treatment results in an edge hardness of up to 1000 HV 0.3. Wera Lasertip “bites” itself into the screw head and prevents any slips out of the recess. It is available for screwdrivers for slotted, Phillips and Pozidriv screws. Screwdrivers with “Take it easy” tool finder: colour coding according to profile and size stamp. The basic idea for the prototype of the Kraftform handle – that the hand should dictate the design – has, right through to today, proved to be correct. In cooperation with the internationally recognised Fraunhofer IAO Institute, Wera developed a screwdriver handle designed to match the shape of the human hand as long ago as the 1960s. After a long development phase, the Wera Kraftform handle was launched to the market in 1968. It has been optimised through the years with new technologies, but has kept its proven shape. After all, the human hand has not changed either. The outstanding design of the Kraftform handle that fits perfectly into the hand prevents hand injuries such as blisters and calluses. Web link http://products.wera.de/en/screwdrivers_series_kraftform_screwdrivers_stainless_steel_3334_3355_6.html Wera - 3334/3355/6 05032061001 - 4013288111395 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
3334/3355/6 价格&库存
很抱歉,暂时无法提供与“3334/3355/6”相匹配的价格&库存,您可以联系我们找货
