8007 B VDE
8007 B VDE
    WERA(维拉)
    WERA - 8007 B VDE - Ratchet, Insulated, Switch Lever, 3/8" Drive, 222 mm Length, Zyklop Series - Rat...
8007 B VDE 数据手册
8007 B VDE Zyklop ratchet, insulated, with switch lever, with 3/8"drive, 222.0 mm Zyklop VDE ratchet and accessories EAN: 4013288190963 Size: 290x60x35 mm Part number: 05004966001 Weight: 352 g Article number: 8007 B VDE Country of origin: CZ Customs tariff number: 82041200 Insulated and 100% individually tested Zyklop VDE ratchet for safe working up to 1,000 volts Fine toothing with 80 teeth for a short return angle of only 4.5° Extremely slim design with a soft, ergonomic grip zone for easy work even in very confined spaces Safe socket lock via push button, convenient direction change thanks to the reversing lever Zyklop ratchet VDE with switch lever with the unmistakable Wera design. Slim design for working even in very confined spaces. Due to the finely spaced 80 teeth, a low return angle of only 4.5° is possible. With a reversing lever for a comfortable change of direction. With secure socket locking function by push button. Individually tested tool as per IEC 60900 at 10,000V for safe working at the approved voltage of 1,000V. Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_8007_b_vde.html Wera - 8007 B VDE 05004966001 - 4013288190963 Wera Werkzeuge GmbH 02.08.2018 - 1 / 2 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 8007 B VDE Zyklop ratchet, insulated, with switch lever, with 3/8"drive, 222.0 mm Zyklop VDE ratchet and accessories Zyklop VDE accessories ratchet and Individually tested Fine-tooth design For tight spaces The individual testing of the Zyklop VDE tools at 10,000 volts, in accordance with IEC 60900, guarantees safe working under voltages up to 1,000 volts. The Zyklop VDE ratchet allows a short return angle of only 4.5 ° thanks to its 80 teeth. The extremely slim design of the Zyklop VDE ratchet makes it easy to work, even in confined spaces. Ball lock Switch lever he ball lock ensures sockets and accessories are securely fitted, providing increased safety during operation. A short press on the release button allows the tool to be changed quickly. Switch lever for convenient change of direction. Further versions in this product family: mm 05004966001 3/8" 222.0 Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_8007_b_vde.html Wera - 8007 B VDE 05004966001 - 4013288190963 Wera Werkzeuge GmbH 02.08.2018 - 2 / 2 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
8007 B VDE 价格&库存
很抱歉,暂时无法提供与“8007 B VDE”相匹配的价格&库存,您可以联系我们找货
