950 PKL/9 BM N
950 PKL/9 BM N
    WERA(维拉)
    WERA - 950 PKL/9 BM N - 9 Piece BlackLaser Metric Hex Key Set in Rubber Clip
950 PKL/9 BM N 数据手册
950 PKL/9 BM N L-key set, metric, BlackLaser, 9 pieces L-Keys for Hexagon Socket Screws EAN: 4013288104809 Size: 229x83x25 mm Part number: 05022086001 Weight: 411 g Article number: 950/9 Hex-Plus 6 Country of origin: CZ Customs tariff number: 82054000 L-keys for hexagonal socket screws Hex-Plus allows socket head screws to live longer BlackLaser for high corrosion protection and long service life L-keys are quickly to hand thanks to their size markings Wear-resistant clip material for enhanced durability High quality L-key set for hexagonal socket screws in a practical clip fastener out of wear-resistant material, enabling secure storage of the L-keys as well as simple removal. L-keys with Hex-Plus profile: offers a larger contact surface within the screw head. This reduces the notching effects to a minimum and almost completely eliminates the risk of destroying the screw recess. The ball-end on the long arm allows for reliable working even in difficult installation situations. The BlackLaser surface treatment provides outstanding surface protection, even against corrosion, and a long service life. The tools are quickly to hand thanks to the laser-engraved and thereby wear-resistant size markings on the L-keys. Web link http://products.wera.de/en/l-keys_l-keys_for_hexagon_socket_screws_950_9_hex-plus_6.html Wera - 950/9 Hex-Plus 6 05022086001 - 4013288104809 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 950 PKL/9 BM N L-key set, metric, BlackLaser, 9 pieces L-Keys for Hexagon Socket Screws Set contents: 950 PKL BM 050271010011) 05027102001 05027103001 05027104001 05027105001 05027106001 05027107001 05027108001 05027109001 1 x 1.5x90 1 x 2.0x100 1 x 2.5x112 1 x 3.0x126 1 x 4.0x140 1 x 5.0x160 1 x 6.0x180 1 x 8.0x200 1 x 10.0x219 1) Regular hexagon L-Keys Hex-Plus Ball tip Surface protection We questioned the classic L-key design, since all too often the screw head recess is rounded out, meaning screws can no longer be tightened or loosened – and so the user finds the L-key slipping out of the recess. Wera Hex-Plus tools have a larger contact surface in the screw head. The notching effects are reduced and thereby the deformation of the screws. At the same time, as much as 20 % more torque can be applied. Hexagon screws can endure a problem because the contact surfaces delivering the power from the conventional tool, is transferred to the screw via very small surface areas. The consequence: the screw can become damaged (rounding out). Hex-Plus tools have a greater contact surface that prevents this from happening! At the same time, as much as 20 % more torque can be applied. Good to know: HexPlus tools fit into every standard hexagon socket screw! The spherical drive profile means that it is possible to swivel the axis of the tool to that of the screw, and therefore enable angled, “around-the-corner” screwdriving jobs. L-keys with BlackLaser surface treatment for outstanding surface protection and long service life. High corrosion protection. Web link http://products.wera.de/en/l-keys_l-keys_for_hexagon_socket_screws_950_9_hex-plus_6.html Wera - 950/9 Hex-Plus 6 05022086001 - 4013288104809 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 950 PKL/9 BM N L-key set, metric, BlackLaser, 9 pieces L-Keys for Hexagon Socket Screws Size identification Secure hold and easy removal The size of each L-keys has been engraved by a laser. In addition SPKL L-keys have a colour coding according to sizes – for simple and rapid accessing of the required tool. Making it easy to find the right tool. The wear-resistant clip material ensures that the L-keys are securely held yet are easy to remove. Web link http://products.wera.de/en/l-keys_l-keys_for_hexagon_socket_screws_950_9_hex-plus_6.html Wera - 950/9 Hex-Plus 6 05022086001 - 4013288104809 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
950 PKL/9 BM N 价格&库存
很抱歉,暂时无法提供与“950 PKL/9 BM N”相匹配的价格&库存,您可以联系我们找货
