950/9 HEX-PLUS 1 SB
950/9 HEX-PLUS 1 SB
    WERA(维拉)
    WERA - 950/9 HEX-PLUS 1 SB - Hex Key Set, L Key, Metric, 1.5 mm - 10 mm, Chrome Plated, 9 Piece
950/9 HEX-PLUS 1 SB 数据手册
950 PKL/9 SM N SB L-key set, metric, chrome-plated, 9 pieces L-Keys for Hexagon Socket Screws Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_950_9_hex-plus_1_sb_sis.html Wera - 950 PKL/9 SB 05073391001 - 4013288030160 Wera Werkzeuge GmbH 02.08.2018 - 1 / 5 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 950 PKL/9 SM N SB L-key set, metric, chrome-plated, 9 pieces L-Keys for Hexagon Socket Screws Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_950_9_hex-plus_1_sb_sis.html Wera - 950 PKL/9 SB 05073391001 - 4013288030160 Wera Werkzeuge GmbH 02.08.2018 - 2 / 5 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 950 PKL/9 SM N SB L-key set, metric, chrome-plated, 9 pieces L-Keys for Hexagon Socket Screws EAN: 4013288030160 Size: 245x95x25 mm Part number: 05073391001 Weight: 480 g Article number: 950 PKL/9 SB Country of origin: CZ Customs tariff number: 82054000 L-keys for hexagonal socket screws Hex-Plus allows socket head screws to live longer High corrosion protection thanks to chrome-plating L-keys are quickly to hand thanks to their size markings Wear-resistant clip material for enhanced durability High quality L-key set for hexagonal socket screws in a practical clip fastener out of wear-resistant material, enabling secure storage of the L-keys as well as simple removal. L-keys with Hex-Plus profile: offers a larger contact surface within the screw head. This reduces the notching effects to a minimum and almost completely eliminates the risk of destroying the screw recess. The ball-end on the long arm allows for reliable working even in difficult installation situations. The precise chrome-plated design ensures high corrosion protection. The tools are quickly to hand thanks to the laserengraved and thereby wear-resistant size markings on the L-keys. Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_950_9_hex-plus_1_sb_sis.html Wera - 950 PKL/9 SB 05073391001 - 4013288030160 Wera Werkzeuge GmbH 02.08.2018 - 3 / 5 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 950 PKL/9 SM N SB L-key set, metric, chrome-plated, 9 pieces L-Keys for Hexagon Socket Screws Set contents: 950 PKL 050220500011) 05022052001 05022054001 05022056001 05022058001 05022060001 05022062001 05022064001 05022066001 1 x 1.5x90 1 x 2.0x100 1 x 2.5x112 1 x 3.0x126 1 x 4.0x140 1 x 5.0x160 1 x 6.0x180 1 x 8.0x200 1 x 10.0x219 1) Regular hexagon L-Keys Hex-Plus Ball tip Surface protection We questioned the classic L-key design, since all too often the screw head recess is rounded out, meaning screws can no longer be tightened or loosened – and so the user finds the L-key slipping out of the recess. Wera Hex-Plus tools have a larger contact surface in the screw head. The notching effects are reduced and thereby the deformation of the screws. At the same time, as much as 20 % more torque can be applied. Hexagon screws can endure a problem because the contact surfaces delivering the power from the conventional tool, is transferred to the screw via very small surface areas. The consequence: the screw can become damaged (rounding out). Hex-Plus tools have a greater contact surface that prevents this from happening! At the same time, as much as 20 % more torque can be applied. Good to know: HexPlus tools fit into every standard hexagon socket screw! The spherical drive profile means that it is possible to swivel the axis of the tool to that of the screw, and therefore enable angled, “around-the-corner” screwdriving jobs. Chrome-plated hexagon L-keys for outstanding surface protection and long service life. High corrosion protection. Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_950_9_hex-plus_1_sb_sis.html Wera - 950 PKL/9 SB 05073391001 - 4013288030160 Wera Werkzeuge GmbH 02.08.2018 - 4 / 5 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 950 PKL/9 SM N SB L-key set, metric, chrome-plated, 9 pieces L-Keys for Hexagon Socket Screws Size identification Secure hold and easy removal The size of each L-keys has been engraved by a laser. In addition SPKL L-keys have a colour coding according to sizes – for simple and rapid accessing of the required tool. Making it easy to find the right tool. The wear-resistant clip material ensures that the L-keys are securely held yet are easy to remove. Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_950_9_hex-plus_1_sb_sis.html Wera - 950 PKL/9 SB 05073391001 - 4013288030160 Wera Werkzeuge GmbH 02.08.2018 - 5 / 5 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
950/9 HEX-PLUS 1 SB 价格&库存
很抱歉,暂时无法提供与“950/9 HEX-PLUS 1 SB”相匹配的价格&库存,您可以联系我们找货
