967/9 TX XL HF 1
967/9 TX XL HF 1
    WERA(维拉)
    WERA - 967/9 TX XL HF 1 - Key Set, Torx, L Key, Holding Function, Long, T8 - T40, 9 Piece
967/9 TX XL HF 1 数据手册
967/9 TX XL HF 1 L-key set with holding function, long, 9 pieces L-Keys for TORX® Screws EAN: 4013288193513 Size: 245x96x25 mm Part number: 05024450001 Weight: 346 g Article number: 967/9 TX XL HF 1 Country of origin: CZ Customs tariff number: 82054000 Holding function for recessed TORX® screws BlackLaser for high corrosion protection and long service life L-keys are quickly to hand thanks to their size markings Wear-resistant clip material for enhanced durability Zinc phosphate plated High quality L-key set for recessed TORX® screws. Holding function: the wedging forces resulting from the contact pressure between the drive tip and the screw profile securely hold the screw on the tool. Featuring an extra-long arm. The BlackLaser surface treatment provides outstanding surface protection, even against corrosion, and a long service life. The tools are quickly to hand thanks to the laser-engraved and thereby wearresistant size markings on the L-keys. Come in a practical clip fastener out of wear-resistant material, enabling secure storage of the L-keys as well as simple removal. Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_967_9_tx_xl_hf_1.html Wera - 967/9 TX XL HF 1 05024450001 - 4013288193513 Wera Werkzeuge GmbH 02.08.2018 - 1 / 2 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 967/9 TX XL HF 1 L-key set with holding function, long, 9 pieces L-Keys for TORX® Screws Set contents: 967 XL HF TORX® 05024451001 1 x TX 8x90 05024452001 1 x TX 9x101 05024453001 1 x TX 10x112 05024454001 1 x TX 15x123 05024455001 1 x TX 20x137 05024456001 1 x TX 25x154 05024457001 1 x TX 27x172 05024458001 1 x TX 30x195 05024459001 1 x TX 40x224 TORX® HF profile BlackLaser Size identification Secure hold and easy removal In tight assembly or disassembly situations, for example in engine compartments, it is not possible to securely hold the screw with the hand on the screwdriver, and the screw subsequently often gets lost. Lengthy searches or the loss of the screw (with the associated danger that could bring about) are the consequence. The HF tools developed by Wera are ideal because they feature an optimised geometry of the original TORX® profile. The wedging forces resulting from the surface pressure between the drive tip and the screw profile mean that the screw is securely held on the tool! L-keys with BlackLaser surface treatment for outstanding surface protection and long service life. High corrosion protection. The size of each L-keys has been engraved by a laser. In addition SPKL L-keys have a colour coding according to sizes – for simple and rapid accessing of the required tool. Making it easy to find the right tool. The wear-resistant clip material ensures that the L-keys are securely held yet are easy to remove. Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_967_9_tx_xl_hf_1.html Wera - 967/9 TX XL HF 1 05024450001 - 4013288193513 Wera Werkzeuge GmbH 02.08.2018 - 2 / 2 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
967/9 TX XL HF 1 价格&库存
很抱歉,暂时无法提供与“967/9 TX XL HF 1”相匹配的价格&库存,您可以联系我们找货
