BELT 2
BELT 2
    WERA(维拉)
    WERA - BELT 2 - Bit Set, 1/4" Drive, 8 Piece
BELT 2 数据手册
Belt 2 Zyklop bit socket set with holding function, 1/4" drive, 8 pieces Innovations and Autumn/Winter Campaign 2017/2018 EAN: 4013288190765 Size: 266x70x45 mm Part number: 05003881001 Weight: 251 g Article number: Belt A 2 Country of origin: CZ Customs tariff number: 82079030 8-piece bit socket set on a robust textile belt, ¼" In-hex sockets with all the advantages of the Wera bit technology In-hex sockets with holding function for screws/bolts Smooth Twist to Unlock mechanism for a secure fit and simple removal of the sockets Suitable for attachment to a wall, shelf, tool trolley and to the Wera 2go System Typically Wera designed robust textile belt with 8 in-hex bit-sockets taking up minimal space. A smooth Twist to Unlock mechanism ensures a secure fit and simple removal of the sockets. Comes with „Take it easy“ Tool Finder with colour coding according to size to enable the right tool to be selected easily and quickly. Includes a snap hook for secure fastening to a belt loop or pocket. Supplied with a nonwoven reverse side and hook and loop strips for simple attachment e.g. to a wall, shelf, tool trolley and to the Wera 2go tool transport system. Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_belt_a_2.html Wera - Belt A 2 05003881001 - 4013288190765 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Belt 2 Zyklop bit socket set with holding function, 1/4" drive, 8 pieces Innovations and Autumn/Winter Campaign 2017/2018 Set contents: 8740 A 05003330001 05003331001 1 x 2.0x28.0 1 x 2.5x28.0 Belt A 0/8 05681315001 05681315001 05681315001 1 x 39.0x220.0 1 x 39.0x220.0 1 x 39.0x220.0 8740 A HF 05003332001 05003333001 05003335001 05003337001 05003341001 05003339001 1 x 3.0x28.0 1 x 4.0x28.0 1 x 5.0x28.0 1 x 6.0x28.0 1 x 7.0x28.0 1 x 8.0x28.0 Klettstreifen 30 0511990181 0511990181 0511990181 0511990181 0511990181 0511990181 0511990181 0511990181 0511990181 0511990181 0511990181 0511990181 0511990181 0511990181 1 x 30.0x200.0 1 x 30.0x200.0 1 x 30.0x200.0 1 x 30.0x200.0 1 x 30.0x200.0 1 x 30.0x200.0 1 x 30.0x200.0 1 x 30.0x200.0 1 x 30.0x200.0 1 x 30.0x200.0 1 x 30.0x200.0 1 x 30.0x200.0 1 x 30.0x200.0 1 x 30.0x200.0 Wera Belts Practical nonwoven strips Comes with convenient snap hook Bit sockets with retaining function for hexagon socket screws Whoever would have thought that the storage of sockets could be completely revolutionised and that someone could come up with a stylish belt with securely attached sockets that can still be easily removed. The textile belt can be attached by means of the nonwoven reverse side and the hook and loop strips e.g. to a wall, shelf, tool trolley and to the Wera 2go tool transport system. The robust textile belt can be secured to a belt loop or pocket by means of the snap hook. The clamping of the screw is achieved by a flexible locking ball. The holding function is especially helpful in confined, hard-to-reach spaces, where there is no room for a second hand to secure the screw. Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_belt_a_2.html Wera - Belt A 2 05003881001 - 4013288190765 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Belt 2 Zyklop bit socket set with holding function, 1/4" drive, 8 pieces Innovations and Autumn/Winter Campaign 2017/2018 Take it easy tool finder system Secure hold and easy removal Zyklop Accessories Take it easy tool finder system with profile and size colour-coding for quick and easy tool selection. Colour-coded system for hexagon drive screws (L-Keys, Zyklop bit sockets), external hex drive screws and nuts (Joker wrenches, Zyklop sockets and Zyklop bit sockets with holding function), and TORX® drive screws (L-Keys, Zyklop bit sockets). The all new smooth turning mechanism guarantees both secure and rattle-free storage, yet allows easy removal of the tool. We did not just want our creativity to end with the ratchets themselves so we also occupied ourselves intensively with ratchet accessories. That is why our users are now provided with an extension with freely spinning sleeve and flexible lock to enable more secure and more rapid screwdriving. The sockets have been completely redesigned: we wanted to spare the user the need of having two different series – one for manual and the other for power tool applications. And: we wanted to enormous simplify the task of finding the right sizes. Technically, our own ambitious goals represented a real challenge: to endow sockets with the advantage of the holding function on screwdrivers and bits. We succeeded in this! Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_belt_a_2.html Wera - Belt A 2 05003881001 - 4013288190765 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
BELT 2
文档中提到的物料型号为“Belt 2 Zyklop bit socket set with holding function, 1/4" drive, 8 pieces”。
这是一个8件套的1/4英寸驱动力的Zyklop六角位头套组,具有保持功能。
该套组包括8个不同尺寸的位头,从2.0x28.0到8.0x28.0,以及一个39.0x220.0的长位头,还有一个30.0x200.0的钩带。
每个位头都具有保持功能,特别适合在狭窄或难以触及的空间中使用,因为那里没有空间用另一只手固定螺丝。
该套组设计为可以轻松地固定到墙上、架子上、工具车或Wera 2go系统上。
此外,还提供了一个方便的快扣钩,可以安全地固定到腰带环或口袋上。
产品由Wera Werkzeuge GmbH制造,位于德国Wuppertal。
BELT 2 价格&库存
很抱歉,暂时无法提供与“BELT 2”相匹配的价格&库存,您可以联系我们找货
