05 003470 001
05 003470 001
    WERA(维拉)
    WERA - 05 003470 001 - Seven Piece Kraftform Kompakt VDE 60 I/7 Pouch Set
05 003470 001 数据手册
Kraftform Kompakt VDE 7 Universal 1, 7 pieces Kraftform Kompakt VDE EAN: 4013288106582 Size: 190x100x50 mm Part number: 05003470001 Weight: 319 g Article number: KK VDE 7 Universal 1 Country of origin: CZ Customs tariff number: 82054000 Kraftform Kompakt VDE 7 Universal 1 Multi-component VDE Kraftform handle with anti-roll feature VDE interchangeable blades 154 mm long In robust pouch Individually tested 6 VDE interchangeable blades with 817 VDE Kraftform handle in a robust belt pouch. Individually tested tools as per IEC 60900. Individual test in water bath at 10,000 volts for secure work at the permissible voltage of 1,000 volts. Web link http://products.wera.de/en/vde_tools_kraftform_kompakt_vde_kk_vde_7_universal_1.html Wera - KK VDE 7 Universal 1 05003470001 - 4013288106582 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Kraftform Kompakt VDE 7 Universal 1, 7 pieces Kraftform Kompakt VDE Set contents: 817 VDE 05003990001 1 x 9x102 KK 60 i 05003400001 05003402001 05003403001 05003404001 1 x 0.4x2.5x154 1 x 0.6x3.5x154 1 x 0.8x4.0x154 1 x 1.0x5.5x154 Why is the right tool so often missing at the workplace? The reason: too many tools and overlyheavy tool bags can make it bothersome to carry keep them with you. So for us it was a clear challenge: to develop a tool that is suitable for a whole host of applications and can be easily taken along to the workplace. Our solution: Kraftform Kompakt tools. A handle into which blades with a range of different profiles can be inserted. Compactly and protectively housed in a light and robust textile pouch – and they are even VDE-tested, too. KK 62 i 05003411001 05003412001 1 x PH 1x154 1 x PH 2x154 Individually tested Handle/interchangeable blade system Easy exchange Each Kraftform Kompakt VDE set has been tested individually at 10,000 volts, in accordance with IEC 60900.This ten-times-higher testing load guarantees safe working at their maximum permitted load of 1,000 volts. The handle/interchangeable blade system allows rapid exchange of the blades required for a wide range of applications. Kraftform Kompakt VDE sets come with an insulated handle and insulated inter-changeable blades, that can be exchanged without any special tools. Web link http://products.wera.de/en/vde_tools_kraftform_kompakt_vde_kk_vde_7_universal_1.html Wera - KK VDE 7 Universal 1 05003470001 - 4013288106582 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Kraftform Kompakt VDE 7 Universal 1, 7 pieces Kraftform Kompakt VDE Kraftform Kompakt VDE Belt pouch Multi-component handle Prevents hand injuries The system “one handle – many interchangeable blades” makes Kraftform Kompakt VDE compact screwdriving sets for in-house as well as mobile electrical applications out of the sets. The belt pouch is practical for tidy storage and transportation. Also available with electrical cabinet keys conforming to the industrial standards. The tools can be stored and carried in a robust belt pouch, keeping them always to hand. Wera produces the Kraftform handle out of several materials with different properties. A resistant plastic is used for the core which ensures that the blade is held securely even under high strain. A softer material is used for the coloured soft zones, which provides high frictional resistance and allows the transfer of high forces – resulting in less required screwdriving effort. The red sections with their hard surfaces prevent any “sticking” of the hand to the handle, making rapid repositioning of the hand possible. The outstanding design of the Kraftform handle that fits perfectly into the hand prevents hand injuries such as blisters and calluses. Web link http://products.wera.de/en/vde_tools_kraftform_kompakt_vde_kk_vde_7_universal_1.html Wera - KK VDE 7 Universal 1 05003470001 - 4013288106582 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05 003470 001 价格&库存
很抱歉,暂时无法提供与“05 003470 001”相匹配的价格&库存,您可以联系我们找货
