05004095001
05004095001
    WERA(维拉)
    WERA - 05004095001 - HYBRID RATCHET SET, 1/2" DRIVE, 2PC
05004095001 数据手册
Zyklop Hybrid Set, 2 pieces The Zyklop Hybrid Ratchet, 1/2" EAN: 4013288184320 Size: 305x115x45 mm Part number: 05004095001 Weight: 967 g Article number: Zyklop Hybrid Set Country of origin: CZ Customs tariff number: 82041100 Zyklop Hybrid ratchet with long overall length (leverage effect) and slim ratchet head Fine-pitched with 72 teeth for a return angle of only 5° Extension with unlocking pin Zyklop Hybrid ratchet set, 1/2" drive, metric. Including Zyklop Hybrid ratchet and Hybrid handle extension, extension and 10 sockets. Web link http://products.wera.de/en/zyklop_ratchets_and_accessories_the_zyklop_ratchets_the_zyklop_ratchets_1_2_the_zyklop_hybrid_ratchet_1_2_zyklop_hybrid_set.html Wera - Zyklop Hybrid Set 05004095001 - 4013288184320 Wera Werkzeuge GmbH 02.08.2018 - 1 / 2 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Zyklop Hybrid Set, 2 pieces The Zyklop Hybrid Ratchet, 1/2" Set contents: 8006 C 05003780001 8797 C 05003781001 1 x 1/2"x281.0 1 x 271.0 The Zyklop Hybrid Ratchet Low return angle Ball lock We wanted to integrate all the mostly-desired ratchet advantages in a single tool. Our idea was to develop a light ratchet with an ergonomic handle, slim design, long lever and an extension option. Since the term “hybrid” refers to a combination from various sectors, it was quite easy to decide on the name. Combines robustness, slim design, and little weight. The reversible ratchet with 72 finepitched teeth has a low return angle of only 5°. This short stroke allows fast and precise work in all types of installation. The ball lock holds the sockets and attachments securely, ensuring safe working. A changeover into any predefined position is completed by simply pressing the release button – this is even the case in the 90° position. Kraftform Higher torque transfer Hybrid extension Ideal for working in confined spaces Multi-component Kraftform handle for optimum pressure and tensile loads. Larger overall length for higher torque transfer. Even more torque can be applied by using the extension. Very slim ratchet head. Web link http://products.wera.de/en/zyklop_ratchets_and_accessories_the_zyklop_ratchets_the_zyklop_ratchets_1_2_the_zyklop_hybrid_ratchet_1_2_zyklop_hybrid_set.html Wera - Zyklop Hybrid Set 05004095001 - 4013288184320 Wera Werkzeuge GmbH 02.08.2018 - 2 / 2 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05004095001 价格&库存
很抱歉,暂时无法提供与“05004095001”相匹配的价格&库存,您可以联系我们找货
  • 1+950.25222
库存:11
