160 i VDE Insulated screwdriver for slotted screws, 1.6 x 10.0 x 200 mm
Kraftform Plus – Series 100 VDE
EAN:
4013288028877
Size:
312x40x40 mm
Part number:
05006140001
Weight:
180 g
Article number:
160 i VDE
Country of origin:
CZ
Customs tariff
number:
82054000
Insulated VDE blades for secure work at 1,000 volts
Smooth hard zones for high speed turning, soft grip zones for high torque transfer
Take it easy tool finder: colour coding according to profile and size
Hexagonal anti-roll feature against rolling away
Conical blade, Lasertip
Wera VDE screwdrivers with multi-component Kraftform Plus handle for fast and low-fatigue working: hard gripping zones for high working speeds
whereas soft zones ensure high torque transfer. Individually tested in water bath at 10,000 volts for secure work at the permissible voltage of 1,000
volts. The tips of the Wera Lasertip screwdrivers are microscopically roughened by laser beams. This rough surface literally bites into the head of the
screw. Any unintentional slipping out is therefore a thing of the past. “Take it easy” tool finder with colour coding according to profiles and size stamp
– for simple and rapid accessing of the required tool. The hexagonal anti-roll feature prevents any bothersome rolling away at the workplace.
Web link
http://products.wera.de/en/vde_tools_kraftform_plus__series_100_vde_160_i_vde.html
Wera - 160 i VDE
05006140001 - 4013288028877
Wera Werkzeuge GmbH
02.08.2018 - 1 / 3
Korzerter Straße 21-25
D-42349 Wuppertal
Tel: +49 (0)2 02 / 40 45-0
E-Mail: info@wera.de
Individually tested
Impact strength test
Lasertip prevents slipping out
Our screwdrivers are tested for
dielectric strength under a 10,000
volt load to make sure that their
most important property, their
insulation, has been exhaustively
tested. Each individual Wera VDE
screwdriver is subjected to this
test to guarantee safe working up
to 1,000 volts.
The individual testing at 10,000
volts, in accordance with IEC
60900, ensures safe working with
loads up to 1,000 volts.
Impact strength tested at −40°C,
guaranteeing safety even under
extreme conditions.
It happens time and time again
that the tip slips out of the screw
head
when
screwdriving,
sometimes damaging valuable
surfaces or even causing injury.
roughened by means of a laser.
This rough surface literally “bites”
itself firmly into the screw head.
Slipping out becomes a thing of
the past.
Reduced contact pressure
Prevents hand injuries
Rapid hand repositioning
“Take it easy” Toolfinder
Wera Lasertip reduces the contact
pressure required and enhances
force transfer – meaning less
screwdriving effort is required.
Screwdriving becomes safer and
easier.
The outstanding design of the
Kraftform handle that fits perfectly
into the hand prevents hand
injuries such as blisters and
calluses.
The hard materials used for the
handle ensure rapid hand
repositioning without any danger of
the skin “sticking” to the handle.
The surrounding hard zones with
large diameters glide like wheels
across the hand.
Screwdrivers with “Take it easy”
stamp.
Web link
Wera - 160 i VDE
Wera Werkzeuge GmbH
02.08.2018 - 2 / 3
D-42349 Wuppertal
Further versions in this product family:
mm
mm
mm
mm
inch
inch
1)
0.4
2.5
80
81
3/32
3 1/8
05006105001
1)
0.5
3.0
100
81
1/8
4
05006110001
0.6
3.5
100
81
9/64
4
05006115001
0.8
4.0
100
98
5/32
4
05006116001
0.8
4.0
150
98
5/32
6
05006120001
1.0
5.5
125
98
7/32
5
05006121001
1.0
5.5
200
98
7/32
8
05006125001
1.2
6.5
150
105
1/4
6
05006126001
1.2
6.5
200
105
1/4
8
05006130001
1.2
8.0
175
112
5/16
7
05006135001
1.6
8.0
200
112
5/16
8
05006140001
1.6
10.0
200
112
3/8
8
05006100001
1) without Lasertip
Web link
Wera - 160 i VDE
Wera Werkzeuge GmbH
02.08.2018 - 3 / 3
Powered by TCPDF (www.tcpdf.org)
D-42349 Wuppertal
很抱歉,暂时无法提供与“05006140001”相匹配的价格&库存,您可以联系我们找货
