05022640001
05022640001
    WERA(维拉)
    WERA - 05022640001 - HEX-PLUS IMPERIAL 2 L-KEY SET, 9PC
05022640001 数据手册
950/9 Hex-Plus Multicolour Imperial 2 L-key set, imperial, BlackLaser, 9 pieces L-Keys for Hexagon Socket Screws EAN: 4013288219107 Size: 245x95x30 mm Part number: 05022640001 Weight: 380 g Article number: 950/9 Hex-Plus Multicolour Country of origin: Imperial 2 Customs tariff number: CZ 82041100 L-keys for hexagonal socket screws Hex-Plus allows socket head screws to live longer L-keys are quickly to hand thanks to their size markings Wear-resistant size marking Wear-resistant clip material for enhanced durability 9 L-keys with plastic sleeve (SPKL) made from circular, grippable material. The sleeve makes working comfortable even at low temperatures and is easy on the fingers. All L-keys are easily accessible due to their colour coding and size markings. The wear-free material of the clip guarantees easy removal and a secure hold of the L-key. For hexagonal socket screws. Web link https://products.wera.de/en/l-keys_l-keys_for_hexagon_socket_screws_950_9_hex-plus_multicolour_imperial_2.html Wera - 950/9 Hex-Plus Multicolour Imperial 2 05022640001 - 4013288219107 Wera Werkzeuge GmbH 27.02.2021 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 950/9 Hex-Plus Multicolour Imperial 2 L-key set, imperial, BlackLaser, 9 pieces L-Keys for Hexagon Socket Screws Set contents: 950 SPKL inch 05022631001 05022638001 05022636001 05022634001 05022632001 05022630001 05022637001 05022635001 05022633001 We questioned the classic L-key design, since all too often the screw head recess is rounded out, meaning screws can no longer be tightened or loosened – and so the user finds the L-key slipping out of the recess. Wera Hex-Plus tools have a larger contact surface in the screw head. The notching effects are reduced and thereby the deformation of the screws. At the same time, as much as 20 % more torque can be applied. 1 x 3/32" x 112 mm 1 x 3/8" x 224 mm 1 x 1/4" x 185 mm 1 x 3/16" x 154 mm 1 x 1/8" x 123 mm 1 x 5/64" x 101 mm 1 x 5/16" x 195 mm 1 x 7/32" x 172 mm 1 x 5/32" x 137 mm L-keys with a thermoplastic sleeve Hex-Plus Ball tip L-keys made from circular material fit into the hand better and allow less strenuous work over a longer period. Additionally, the rubber sleeve provides a pleasant grip, particularly in applications at low temperatures. Colour coding and large stamp enable the desired Lkey to be easily located. Moreover, the round material keys are more robust, particularly where smaller sizes are concerned. Hexagon screws can endure a problem because the contact surfaces delivering the power from the conventional tool, is transferred to the screw via very small surface areas. The consequence: the screw can become damaged (rounding out). Hex-Plus tools have a greater contact surface that prevents this from happening! At the same time, as much as 20 % more torque can be applied. Good to know: HexPlus tools fit into every standard hexagon socket screw! The spherical drive profile means that it is possible to swivel the axis of the tool to that of the screw, and therefore enable angled, "around-the-corner" screwdriving jobs. Web link https://products.wera.de/en/l-keys_l-keys_for_hexagon_socket_screws_950_9_hex-plus_multicolour_imperial_2.html Wera - 950/9 Hex-Plus Multicolour Imperial 2 05022640001 - 4013288219107 Wera Werkzeuge GmbH 27.02.2021 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 950/9 Hex-Plus Multicolour Imperial 2 L-key set, imperial, BlackLaser, 9 pieces L-Keys for Hexagon Socket Screws Take it easy tool finder system Secure hold and easy removal Take it easy tool finder system with profile and size colour-coding for quick and easy tool selection. Colour-coded system for hexagon drive screws (L-Keys, Zyklop bit sockets), external hex drive screws and nuts (Joker wrenches, Zyklop sockets and Zyklop bit sockets with holding function), and TORX® drive screws (L-Keys, Zyklop bit sockets). The wear-resistant clip material ensures that the L-keys are securely held yet are easy to remove. Web link https://products.wera.de/en/l-keys_l-keys_for_hexagon_socket_screws_950_9_hex-plus_multicolour_imperial_2.html Wera - 950/9 Hex-Plus Multicolour Imperial 2 05022640001 - 4013288219107 Wera Werkzeuge GmbH 27.02.2021 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05022640001 价格&库存
很抱歉,暂时无法提供与“05022640001”相匹配的价格&库存,您可以联系我们找货
  • 1+405.55647
库存:29
