367 TORX® HF Screwdriver with holding function for TORX® screws, TX 30 x 115
mm
Screwdrivers Kraftform Plus – Series 300
EAN:
4013288100740
Size:
220x37x37 mm
Part number:
05028055001
Weight:
89 g
Article number:
367 TORX® HF
Country of origin:
CZ
Customs tariff
number:
82054000
Screwdriver for recessed TORX® screws
Holding function for TORX® screws
Multi-component Kraftform handle for fast and ergonomic screwdriving
Handle markings simplify finding and sorting of tools
Hexagonal anti-roll feature against rolling away
High quality Kraftform Plus screwdriver. Multi-component Kraftform handle for fast and low-fatigue working. Kraftform Plus: hard gripping zones for
high working speeds whereas soft zones ensure high torque transfer. Holding function: the wedging forces resulting from the contact pressure
between the drive tip and the screw profile securely hold the screw on the tool. The hexagonal anti-roll feature prevents any bothersome rolling away
at the workplace. Handle markings for simplified finding and sorting of the tool.
Web link
http://products.wera.de/en/tools_for_the_aerospace_segment_screwdrivers_screwdrivers_kraftform_plus__series_300_367_torx_hf.html
Wera - 367 TORX® HF
05028055001 - 4013288100740
Wera Werkzeuge GmbH
02.08.2018 - 1 / 3
Korzerter Straße 21-25
D-42349 Wuppertal
Tel: +49 (0)2 02 / 40 45-0
E-Mail: info@wera.de
mm
TORX® HF profile
Kraftform
Rapid hand repositioning
Kraftform Plus screwdrivers –
ergonomics you can grasp. They
relieve the entire hand-arm system
even when used intensively. Along
with other technical and product
advantages such as the Lasertip
for a secure fit in the screw head,
Kraftform screwdrivers are the
ideal choice whenever manual
screwdriving jobs are concerned.
In tight assembly or disassembly
situations, for example in engine
compartments, it is not possible to
securely hold the screw with the
hand on the screwdriver, and the
screw subsequently often gets
lost. Lengthy searches or the loss
of the screw (with the associated
danger that could bring about) are
the consequence. The HF tools
developed by Wera are ideal
because they feature an optimised
geometry of the original TORX®
profile. The wedging forces
resulting from the surface
pressure between the drive tip and
the screw profile mean that the
screw is securely held on the tool!
The basic idea for the prototype of
the Kraftform handle – that the
hand should dictate the design –
has, right through to today, proved
to be correct. In cooperation with
the internationally recognised
Fraunhofer IAO Institute, Wera
developed a screwdriver handle
designed to match the shape of
the human hand as long ago as
the 1960s. After a long
development phase, the Wera
Kraftform handle was launched to
the market in 1968. It has been
optimised through the years with
new technologies, but has kept its
proven shape. After all, the human
hand has not changed either.
The hard materials used for the
handle ensure rapid hand
repositioning without any danger of
the skin “sticking” to the handle.
The surrounding hard zones with
large diameters glide like wheels
across the hand.
Large contact area
Non-roll feature
Identification marking
The large contact area – with
particularly high friction to the soft
zones – results in high torque
transfer without any bruising from
the edges.
The hexagonal non-roll feature
prevents any rolling away at the
workplace.
The screw symbol and tip size
identification markings on the
handle make it easier to find the
right screwdriver in the tool case
or at the workplace.
Web link
Wera - 367 TORX® HF
Wera Werkzeuge GmbH
02.08.2018 - 2 / 3
D-42349 Wuppertal
mm
Further versions in this product family:
mm
mm
mm
inch
05028048001
TX 8
60
81
3.5
2 3/8
05028049001
TX 9
60
81
4.0
2 3/8
05028050001
TX 10
80
81
4.0
3 1/8
05028051001
TX 15
80
98
4.0
3 1/8
05028052001
TX 20
100
98
4.5
4
05028070001
TX 20
300
98
4.5
12
05028053001
TX 25
100
105
5.0
4
05028071001
TX 25
300
105
6.0
12
05028054001
TX 27
115
105
5.5
4 9/16
05028072001
TX 27
300
105
6.0
12
05028055001
TX 30
115
105
6.0
4 9/16
05028073001
TX 30
300
105
6.0
12
05028056001
TX 40
130
112
7.0
5 3/16
Web link
Wera - 367 TORX® HF
Wera Werkzeuge GmbH
02.08.2018 - 3 / 3
Powered by TCPDF (www.tcpdf.org)
D-42349 Wuppertal
很抱歉,暂时无法提供与“05028055001”相匹配的价格&库存,您可以联系我们找货
