05057412001
05057412001
    WERA(维拉)
    WERA - 05057412001 - BIT-CHECK SET W/UNIVERSAL HOLDER, 8PC
05057412001 数据手册
Bit-Check 7 PZ Diamond 1, 7 pieces Bit-Checks Diamond EAN: 4013288180001 Size: 72x65x12 mm Part number: 05057412001 Weight: 71 g Article number: Bit-Check 7 PZ Diamond 1 Country of origin: Customs tariff number: CZ 82079030 Upright positionable Bit-Checks convince due to their functionality in a minimum of space BiTorsion bits for long service life Diamond coating for a secure fit in the screw, literally bites into the screwhead to prevent cam-out Rapidaptor holder for rapid bit change Take it easy tool finder: colour coding according to profile and size Bits with tiny diamond particles on the bit tip. This ensures a secure fit in the screw head, reduces the contact pressure required and lowers the risk of slipping. BiTorsion bits with an elastic torsion zone – where kinetic energy is diverted from peak loads – and softer BiTorsion zone to prevent the bit tip from twisting under high strain. This greatly extends the product service life. Comes with Rapidaptor technology, which allows bits to be attached without any need to actuate the sleeve. The removal of the bit is simple, just by pushing the sleeve forward – for rapid bit change with just one hand. For insertion in the power screwdriver or into the chuck of the power drill. The multi-component Bit-Check is convincing on account of its low weight and the maximum possible degree of compactness. In this respect, the soft material in the lower section of the Bit-Check ensures that the bits are securely held whilst being simple to remove at the same time. The profile and size of the bits are easy to recognise thanks to the Wera "Take it easy" Tool Finder with its colour coding and clearly visible imprint. Web link http://products.wera.de/en/bits_holders_adaptors_bit_sets_bit-checks_diamond_bit-check_7_pz_diamond_1.html Wera - Bit-Check 7 PZ Diamond 1 05057412001 - 4013288180001 Wera Werkzeuge GmbH 02.08.2018 - 1 / 2 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Bit-Check 7 PZ Diamond 1, 7 pieces Bit-Checks Diamond Set contents: 889/4/1 K 05052502001 855/1 BDC PZ 05056700001 05056702001 05056704001 1 x 1/4"x50 2 x PZ 1x25 3 x PZ 2x25 1 x PZ 3x25 At the workplace Bits with diamond coating Bits with diamond coating Secure fit in the screw head The Bit-Checks can be positioned upright at the workplace so the tool is always quickly to hand. The diamond coating of the DC bits lowers the danger of slipping as the minute diamond particles literally “bite” themselves into the screw head. The diamond coating of the DC bits lowers the danger of slipping as the minute diamond particles literally “bite” themselves into the screw head. Today, the Wera diamond bit – manufactured with the technology specifically developed by Wera for this application – still sets the standard in terms of resilience and functionality. Wera bits with a diamond coating ensure a secure fit of the bit in the screw head. Rapid-in and self-lock Rapid-out Rapid-spin Rapidaptor holder The bit can be pushed into the adaptor without moving the sleeve. The lock is activated automatically as soon as the bit is applied to the screw. Bits are held securely and wobble-free. Simply push the sleeve forward to change the bit. The spring mechanism lifts the bit off the magnet and unlocks the tool. The bit can be easily removed. The rapid-out function makes it easy to remove even the smallest bits without extra tools. The free-turning sleeve allows screw steadying at the start of the screwdriving process. This makes it easier to apply the tool to the screw and prevents slipping. It can also be used as a short extension for ¼" applications e.g. in combination with the Wera Zyklop Ratchets. Rapid bit change without needing any additional tools. One-hand operation with a freely spinning sleeve for simplified guidance of the tool. Also available in a BiTorsion design. Web link http://products.wera.de/en/bits_holders_adaptors_bit_sets_bit-checks_diamond_bit-check_7_pz_diamond_1.html Wera - Bit-Check 7 PZ Diamond 1 05057412001 - 4013288180001 Wera Werkzeuge GmbH 02.08.2018 - 2 / 2 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05057412001 价格&库存
很抱歉,暂时无法提供与“05057412001”相匹配的价格&库存,您可以联系我们找货
