05057422001
05057422001
    WERA(维拉)
    WERA - 05057422001 - BIT-CHECK SET W/UNIVERSAL HOLDER, 13PC
05057422001 数据手册
Bit-Check 12 Wood 2, 12 pieces Bit-Checks Wood EAN: 4013288179890 Size: 69x20x65 mm Part number: 05057422001 Weight: 107 g Article number: Bit-Check 12 Wood 2 Country of origin: CZ Customs tariff number: 82079030 Upright positionable Bit-Checks convince due to their functionality in a minimum of space Particularly for wood applications Universal holder with stainless sleeve Robust Bit-Check by Wera. Bit-Checks provide a quick overview of the tools available. Bits not needed are simply reinserted into the set and do not get lost. Simple transportation e.g. in the shirt pocket. Includes universal holder with strong permanent magnet for the take-up of bits with ¼” hexagon head drive. Can be inserted in the power screwdriver or for use in the chuck of the electric drill. Multi-component Bit-Check that can be positioned upright for permanently secure bit storage. Web link http://products.wera.de/en/bits_holders_adaptors_bit_sets_bit-checks_wood_bit-check_12_wood_2.html Wera - Bit-Check 12 Wood 2 05057422001 - 4013288179890 Wera Werkzeuge GmbH 02.08.2018 - 1 / 2 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Bit-Check 12 Wood 2, 12 pieces Bit-Checks Wood Set contents: 899/4/1 05053457001 1 x 899/4/1 Kx1/4"x50 855/1 Z PZ 05072080001 05072082001 05072084001 1 x PZ 1x25 2 x PZ 2x25 1 x PZ 3x25 851/1 Z PH 05072072001 1 x PH 2x25 867/1 TORX® 05066485001 05066486001 05066487001 05066488001 05066490001 05066491001 1 x TX 10x25 1 x TX 15x25 1 x TX 20x25 1 x TX 25x25 1 x TX 30x25 1 x TX 40x25 At the workplace Universal holder with stainless steel sleeve Bit Ranges The Bit-Checks can be positioned upright at the workplace so the tool is always quickly to hand. The retaining ring and the strong permanent magnet ensure a particularly secure fitting of the bit in the holder. We have had bit ranges in our programme for many years now. In 2016, we put a question mark against everything and came up with a game changer. We wanted bit ranges with bits whose profiles and sizes could be more easily recognised. We wanted bit ranges that were as compact as possible and which were Wera-like at a first glance. We wanted bit ranges with bits that could be removed and reinserted more easily. We wanted bit ranges with as little weight as possible. The new multicomponent Bit-Checks satisfy these requirements; the soft material in the lower section of the Bit-Checks ensures that the bits are firmly held yet easy to remove. Web link http://products.wera.de/en/bits_holders_adaptors_bit_sets_bit-checks_wood_bit-check_12_wood_2.html Wera - Bit-Check 12 Wood 2 05057422001 - 4013288179890 Wera Werkzeuge GmbH 02.08.2018 - 2 / 2 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05057422001
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件支持多种信号路径配置,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为4x4mm,共有24个引脚。
05057422001 价格&库存
很抱歉,暂时无法提供与“05057422001”相匹配的价格&库存,您可以联系我们找货
