Click-Torque C 2 Push R/L adjustable torque wrench for clockwise and anticlockwise torque-control, 20-100 Nm, 1/2" x 20-100 Nm
Click-Torque Push R/L adjustable torque wrenches for clockwise and anti-clockwise torquecontrol
EAN:
4013288218926
Size:
0x0x0 mm
Part number:
05075625001
Weight:
0g
Article number:
Click-Torque C 2 Push R/L Country of origin:
Customs tariff
number:
TW
82041100
For clockwise and anti-clockwise torque-control thanks to the smooth reversing of the captive square head insert
Measuring range: 20-100 Nm; precise to +/- 3% as per DIN EN ISO 6789-1:2017-07
45 teeth and 1/2" square head drive with socket locking
Easy setting and saving of the desired torque value with audible and tactile clicks when reaching the scale values
Audible and tactile release mechanism when the set torque value is reached
Click torque wrench in the unmistakable Wera design. For clockwise and anti-clockwise torque-control. Very robust design with high
accuracy as per DIN EN ISO 6789-1: 2017-07. Easy setting and saving of the default value. The audible and tactile clicks on reaching
the scale values facilitate the safe setting of the desired torque value. The robust release mechanism guarantees a clearly audible and
tactile release signal when the set torque is reached. With captive 3/4" square head insert to change direction. 1/2" square head drive
with socket locking.
Web link
https://products.wera.de/en/torque_tools_series_click-torque_wrenches_click-torque_push_r_l_adjustable_torque_wrenches_for_clockwise_and_anti-clockwise_torque-control_
Wera - Click-Torque C 2 Push R/L
05075625001 - 4013288218926
Wera Werkzeuge GmbH
27.02.2021 - 1 / 2
Korzerter Straße 21-25
D-42349 Wuppertal
Tel: +49 (0)2 02 / 40 45-0
E-Mail: info@wera.de
For right and left direction
Exact
Simple and safe
Reversing with square head insert
The Click-Torque torque wrench is
suitable for clockwise and anticlockwise torque-control. Very
smooth change of direction thanks
to captive square head insert.
Precise to ± 3% as per DIN EN ISO
6789-1:2017-07.
desired torque value; readable on
the main and fine scales.
Simple setting
Release mechanism
Robust models
With audible and tactile clicks
when adjusting the scale values.
When the set torque value is
reached, an audible and tactile
mechanism triggers.
Very robust design with captive
square head insert. Fine-teethed
ratchet mechanics (45 teeth),
ergonomic 2-component handle.
Further versions in this product family:
1)
05075625001
inch
Nm
1/2"
0.5
Nm
lbf. ft.
mm
mm
mm
mm
mm
20-100 15-73
405
140
47
43
18.5
inch
inch
inch
inch
inch
15
5
1
1
45/64"
15/16" 33/64" 27/32" 11/16"
1) Available from May 2021
Web link
Wera Werkzeuge GmbH
27.02.2021 - 2 / 2
Powered by TCPDF (www.tcpdf.org)
D-42349 Wuppertal
很抱歉,暂时无法提供与“05075625001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2328.654511+301.64220
- 3+2183.059083+282.78250
- 5+1964.796795+254.50990
