05075631001
05075631001
    WERA(维拉)
    WERA - 05075631001 - Torque Tool, Wrench, 0.75", 200 Nm to 1000 Nm, 1.25 m
05075631001 数据手册
Click-Torque E 1 Push R/L adjustable torque wrench for clockwise and anticlockwise torque-control, 200-1000 Nm, 3/4" x 200-1000 Nm Click-Torque Push R/L adjustable torque wrenches for clockwise and anti-clockwise torquecontrol EAN: 4013288219053 Size: 0x0x0 mm Part number: 05075631001 Weight: 0g Article number: Click-Torque E 1 Push R/L Country of origin: TW Customs tariff number: 82041100 For clockwise and anti-clockwise torque-control thanks to smooth reversing of the captive square head insert Measuring range: 200-1000 Nm; precise to +/- 3% as per DIN EN ISO 6789-1:2017-07 45 teeth and 3/4" square head drive Easy setting and saving of the desired torque value with audible and tactile clicks when reaching the scale values Audible and tactile release mechanism when the set torque value is reached Click torque wrench in the unmistakable Wera design. For clockwise and anti-clockwise torque-control. Very robust design with high accuracy as per DIN EN ISO 6789-1: 2017-07. Easy setting and saving of the default value. The audible and tactile clicks on reaching the scale values facilitate the safe setting of the desired torque value. The robust release mechanism guarantees a clearly audible and tactile release signal when the set torque is reached. With captive 3/4" square head insert to change direction. Web link https://products.wera.de/en/torque_tools_series_click-torque_wrenches_click-torque_push_r_l_adjustable_torque_wrenches_for_clockwise_and_anti-clockwise_torque-control_ Wera - Click-Torque E 1 Push R/L 05075631001 - 4013288219053 Wera Werkzeuge GmbH 27.02.2021 - 1 / 2 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Click-Torque E 1 Push R/L adjustable torque wrench for clockwise and anticlockwise torque-control, 200-1000 Nm, 3/4" x 200-1000 Nm Click-Torque Push R/L adjustable torque wrenches for clockwise and anti-clockwise torquecontrol For right and left direction Exact Simple and safe Reversing with square head insert The Click-Torque torque wrench is suitable for clockwise and anticlockwise torque-control. Very smooth change of direction thanks to captive square head insert. Precise to ± 3% as per DIN EN ISO 6789-1:2017-07. Easy setting and saving of the desired torque value; readable on the main and fine scales. Simple setting Release mechanism Robust models With audible and tactile clicks when adjusting the scale values. When the set torque value is reached, an audible and tactile mechanism triggers. Very robust design with captive square head insert. Fine-teethed ratchet mechanics (45 teeth), ergonomic 2-component handle. Further versions in this product family: 1) 05075631001 inch Nm 3/4" 1.0 Nm lbf. ft. mm mm mm mm mm 200-10 148-73 1250 00 7 140 47 63 30 inch inch inch inch inch 49 5 1 2 1 7/32" 33/64" 27/32" 31/64" 3/16" 1) Available from May 2021 Web link https://products.wera.de/en/torque_tools_series_click-torque_wrenches_click-torque_push_r_l_adjustable_torque_wrenches_for_clockwise_and_anti-clockwise_torque-control_ Wera - Click-Torque E 1 Push R/L 05075631001 - 4013288219053 Wera Werkzeuge GmbH 27.02.2021 - 2 / 2 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05075631001 价格&库存
很抱歉,暂时无法提供与“05075631001”相匹配的价格&库存,您可以联系我们找货
