05135918001
05135918001
    WERA(维拉)
    WERA - 05135918001 - Ratchet Set, Socket, 27 Piece
05135918001 数据手册
Kraftform Kompakt Zyklop Mini 2, 27 pieces Zyklop Mini EAN: 4013288182180 Size: 200x105x60 mm Part number: 05135918001 Weight: 566 g Article number: KK Zyklop Mini 2 Country of origin: CZ Customs tariff number: 82041100 Drop-forged, full-steel ratchet design For screwdriving in very confined working situations Zyklop sockets 8790 FA for direct insertion in the Zyklop Mini 2 Bit holder, 9 sockets, 14 bits and 1 adaptor In robust textile box Ratchets and screws in a Kraftform Kompakt format. These drop-forged, full-steel ratchets, Zyklop Mini 1 and 2, combine filigree design with incredible robustness. For particularly rapid screwdriving in confined working situations. Zyklop Mini 1 or Zyklop Mini 2 can be used whenever screwdriving with power tools or conventional hand tools is unfeasible for lack of space. 1 bit ratchet Zyklop Mini 1; suitable for the take-up of bits with ¼” hexagon head drive as per DIN ISO 1173-C 6.3 and E 6.3 and Wera connecting series 1 and 4; also possible to use ¼” sockets by attaching the Wera adaptor 870/1. 1 socket ratchet Zyklop Mini 2; suitable for the direct attachment of Wera Zyklop special sockets 8790 FA. Web link http://products.wera.de/en/zyklop_ratchets_and_accessories_zyklop_mini_kk_zyklop_mini_2.html Wera - KK Zyklop Mini 2 05135918001 - 4013288182180 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Kraftform Kompakt Zyklop Mini 2, 27 pieces Zyklop Mini Set contents: 8001 A 05073999001 05073999001 05073999001 05073999001 05073999001 05073999001 05073999001 05073999001 05073999001 05073999001 05073999001 1 x 1/4"x87.0 1 x 1/4"x87.0 1 x 1/4"x87.0 1 x 1/4"x87.0 1 x 1/4"x87.0 1 x 1/4"x87.0 1 x 1/4"x87.0 1 x 1/4"x87.0 1 x 1/4"x87.0 1 x 1/4"x87.0 1 x 1/4"x87.0 813 05051274001 1 x 1/4"x78 8005 05003660001 1 x 107 870/1 051360000011) 1 x 1/4"x25 1) With friction ball; for manual nut spinner sockets 851/1 Z PH 05072070001 05072072001 1 x PH 1x25 1 x PH 2x25 867/1 TORX® 05066485001 05066486001 05066487001 05066488001 05066490001 05066491001 1 x TX 10x25 1 x TX 15x25 1 x TX 20x25 1 x TX 25x25 1 x TX 30x25 1 x TX 40x25 8790 FA 05003665001 05003667001 05003668001 05003669001 05003670001 05003675001 05003690001 05003684001 05003685001 1 x 4.0 1 x 5.0 1 x 5.5 1 x 6.0 1 x 7.0 1 x 8.0 1 x 10.0 1 x 12.0 1 x 13.0 855/1 Z PZ 05072080001 05072082001 1 x PZ 1x25 1 x PZ 2x25 840/1 Z Hex-Plus 05056315001 1 x 3.0x25 05056320001 1 x 4.0x25 05056325001 1 x 5.0x25 05056330001 1 x 6.0x25 Web link http://products.wera.de/en/zyklop_ratchets_and_accessories_zyklop_mini_kk_zyklop_mini_2.html Wera - KK Zyklop Mini 2 05135918001 - 4013288182180 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Kraftform Kompakt Zyklop Mini 2, 27 pieces Zyklop Mini The Zyklop Mini Ratchets Small return angle Is rapid screwdriving possible with the Zyklop Mini? Combines elegant design with incredible resilience. Suitable for rapid fastening even in confined working situations. The Wera Zyklop Mini is applied whenever fastening with a power tool or conventional tools is impossible due to insufficient space. The Zyklop Mini 1 for the direct attachment of bits; the Zyklop Mini 2 for the direct attachment of the special Wera Zyklop sockets. For all applications. The fine tooth mechanism, with its 60 teeth, allows a small return angle of only 6° – ideal for precision work. High working speeds can be attained with the Zyklop Mini. The thumb wheel is important, enabling more rapid screwdriving, and the Zyklop Mini hande only needs to be used for the final tightening of the screw. Slim design Is such a small tool sufficiently resilient? What parts can be connected to the Zyklop Mini 1? Zyklop Mini 2 Its slim design makes it ideal for all particularly confined working situations. The Zyklop Mini 1 can withstand at least 65 Nm. That is far more power than can normally be transferred to such a small tool. Bits and sockets. Bits can be connected directly. However, a holder can be connected first and then the bit can be attached to this. This then serves as an extension with a free-turning sleeve. An adaptor e.g. Wera 870/1 is needed for sockets – ¼" hexagonal on a square drive (included in the Bit-Check and with the individual Zyklop Mini 1 in the set). The Zyklop Mini 2 is suitable for the direct attachment of the special Wera Zyklop sockets 8790 FA. These sockets feature a very low height, ideal for confined working spaces. difficult-to-access Web link http://products.wera.de/en/zyklop_ratchets_and_accessories_zyklop_mini_kk_zyklop_mini_2.html Wera - KK Zyklop Mini 2 05135918001 - 4013288182180 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05135918001 价格&库存
很抱歉,暂时无法提供与“05135918001”相匹配的价格&库存,您可以联系我们找货
库存:28
