1430 MICRO ESD 2,0 - 6,0 NCM
    WERA(维拉)
    WERA - 1430 MICRO ESD 2,0 - 6,0 NCM - Torque, Screwdriver, ESD, 0.157" Drive, 141mm Length, 2N-cm to...
1430 MICRO ESD 2,0 - 6,0 NCM 数据手册
1430 Kraftform Micro ESD adjustable torque screwdrivers with quick-release chuck, 0,02 - 0,06 Nm ESD Series EAN: 4013288179043 Size: 145x23x23 mm Part number: 05074802001 Weight: 41 g Article number: 1430 ESD Country of origin: CZ Customs tariff number: 82054000 Adjustable Kraftform Micro ESD torque screwdriver with quick-release chuck ESD-safe tool thanks to surface resistance of < 10^9 Ohm Distinct audible and perceivable excess load signal when the pre-set torque value is reached Suitable for bits with 4 mm halfmoon and 4 mm HIOS drive Applications e.g. on smartphones, mobile phones, cameras, electronic equipment Web link http://products.wera.de/en/tools_for_the_aerospace_segment_screwdrivers_esd_series_1430_esd.html Wera - 1430 ESD 05074802001 - 4013288179043 Wera Werkzeuge GmbH 02.08.2018 - 1 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 1430 Kraftform Micro ESD adjustable torque screwdrivers with quick-release chuck, 0,02 - 0,06 Nm ESD Series Torque tool with adjustable torque of 2.0 to 6.0 cNm (accuracy +- 10%). Compact handle/interchangeable blade system for torque controlled precision screwdriving. The Kraftform Micro ESD torque screwdriver is ideal for torque controlled jobs on electrostatically-susceptible components. Suitable for the take-up of bits with 4 mm halfmoon drive (Wera series 9) and 4 mm HIOS drive (Wera series 21). Tamperproof. Distinct audible and perceivable excess load signal when the pre-set torque value is reached. Unlimited manual loosening torque. Electrical surface resistance of < 10^9 Ohm for secure protection against electrostatic charge. Manufactured in accordance with DIN EN 61340-5-1. Handle/Interchangeable blade system for rapid blade change. Kaftform Micro handle with twist cap and free-turning zone for rapid twisting, making any time-consuming repositioning of the fingers unnecessary. Power zone with integrated soft zones for the transfer of higher tightening and loosening torque. Precision zone directly above the blade for the right angle for adjustment work. Rapid fixing of the bit: just push the bit into the insert for automatic locking and a secure fit. To change the bit, simply push the sleeve forward and remove. Free-turning sleeve for simple guidance of the tool during the screwdriving process. Bits suitable for manual as well as power tool operations with electric screwdrivers (e.g. HIOS, Delvo, Sehan). Applications for example on smartphones, cell phones, cameras, electrical appliances, in dental labs and dental surgeries. Web link http://products.wera.de/en/tools_for_the_aerospace_segment_screwdrivers_esd_series_1430_esd.html Wera - 1430 ESD 05074802001 - 4013288179043 Wera Werkzeuge GmbH 02.08.2018 - 2 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 1430 Kraftform Micro ESD adjustable torque screwdrivers with quick-release chuck, 0,02 - 0,06 Nm ESD Series Wera ESD Tools High protection For Halfmoon and HIOS Bits Adjustable Torque Screwdrivers The requirements for ESD-safe screwdrivers are specified in the European standard DIN EN 61340-5-1. This standard also includes a handle that has to be out of a defined conductive material. The Wera products in the ESD series satisfy these standards and the even more stringent requirements demanded by some technology companies. The electric surface resistance of the Wera ESD material is ≤ 10^9 ohm. This securely protects components against electrostatic energy and associated damage. Features a combination bitholder for both bits with Halfmoon and bits with HIOS drive. Wera’s adjustable torque screwdrivers allow variable torque settings with maximum precision and ensure that the user gets the very best results in the familiar Wera design with superior ergonomics. Attachable magnifying glass The fast-turning zone The power zone The precision zone Articles 1430 ESD and 1431 ESD, all come with a magnifying glass. This can be easily attached on to the scale, dramatically improving visibility. The fast-turning zone just below the rotating cap allows rapid twisting. The power zone has integrated soft zones near the blade tip to ensure high torque transfer for loosening or tightening screws without losing contact with the screw. The precision zone directly above the blade gives the user a better feel for the right rotation angle during fine adjustment work. Web link http://products.wera.de/en/tools_for_the_aerospace_segment_screwdrivers_esd_series_1430_esd.html Wera - 1430 ESD 05074802001 - 4013288179043 Wera Werkzeuge GmbH 02.08.2018 - 3 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 1430 Kraftform Micro ESD adjustable torque screwdrivers with quick-release chuck, 0,02 - 0,06 Nm ESD Series Further versions in this product family: art. no. nm nm mm inch 1) 1430 ESD 0.02-0.06 0.0025 141 5 7/16 1) 1431 ESD 0.05-0.11 0.005 141 5 7/16 05074802001 05074804001 1) With attachable magnifying glass, dramatically improving visibility. Web link http://products.wera.de/en/tools_for_the_aerospace_segment_screwdrivers_esd_series_1430_esd.html Wera - 1430 ESD 05074802001 - 4013288179043 Wera Werkzeuge GmbH 02.08.2018 - 4 / 4 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
1430 MICRO ESD 2,0 - 6,0 NCM 价格&库存
很抱歉,暂时无法提供与“1430 MICRO ESD 2,0 - 6,0 NCM”相匹配的价格&库存,您可以联系我们找货
