355 PZ2 X 100
355 PZ2 X 100
    WERA(维拉)
    WERA - 355 PZ2 X 100 - PZ2 x 100mm Kraftform Plus Round Blade Screwdriver for Pozidriv Screws
355 PZ2 X 100 数据手册
355 PZ Screwdriver for Pozidriv screws, PZ 2 x 100 mm Kraftform Plus – Series 300 EAN: 4013288004055 Size: 205x37x37 mm Part number: 05009315001 Weight: 88 g Article number: 355 PZ Country of origin: CZ Customs tariff number: 82054000 Screwdriver, for cross-recess screws, Pozidriv Smooth hard zones for high speed turning, soft grip zones for high torque transfer Take it easy tool finder: colour coding according to profile and size Hexagonal anti-roll feature against rolling away Lasertip tips for more secure fit in the screw head High quality Kraftform Plus screwdriver by Wera. Hard gripping zones for high working speeds whereas soft zones ensure high torque transfer for fast and low-fatigue working. The tips of Wera Lasertip screwdrivers are microscopically roughened by means of laser beams. This rough surface literally bites into the head of the screw. Any unintentional slipping out is therefore a thing of the past. “Take it easy” tool finder with colour coding according to profiles and size stamp – for simple and rapid accessing of the required tool. The hexagonal non-roll feature prevents any rolling away at the workplace. Web link http://products.wera.de/en/screwdrivers_kraftform_plus__series_300_355_pz.html Wera - 355 PZ 05009315001 - 4013288004055 Wera Werkzeuge GmbH 02.08.2018 - 1 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 355 PZ Screwdriver for Pozidriv screws, PZ 2 x 100 mm Kraftform Plus – Series 300 Kraftform Plus screwdrivers – ergonomics you can grasp. They relieve the entire hand-arm system even when used intensively. Along with other technical and product advantages such as the Lasertip for a secure fit in the screw head, Kraftform screwdrivers are the ideal choice whenever manual screwdriving jobs are concerned. Lasertip prevents slipping out Lasertip Reduced contact pressure It happens time and time again that the tip slips out of the screw head when screwdriving, sometimes damaging valuable surfaces or even causing injury. The tips of the Wera Lasertip screwdrivers are microscopically roughened by means of a laser. This rough surface literally “bites” itself firmly into the screw head. Slipping out becomes a thing of the past. A precisely-focused laser creates a sharp-edged surface structure. This laser treatment results in an edge hardness of up to 1000 HV 0.3. Wera Lasertip “bites” itself into the screw head and prevents any slips out of the recess. It is available for screwdrivers for slotted, Phillips and Pozidriv screws. Wera Lasertip reduces the contact pressure required and enhances force transfer – meaning less screwdriving effort is required. Screwdriving becomes safer and easier. Web link http://products.wera.de/en/screwdrivers_kraftform_plus__series_300_355_pz.html Wera - 355 PZ 05009315001 - 4013288004055 Wera Werkzeuge GmbH 02.08.2018 - 2 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 355 PZ Screwdriver for Pozidriv screws, PZ 2 x 100 mm Kraftform Plus – Series 300 Kraftform Rapid hand repositioning Non-roll feature “Take it easy” Toolfinder The basic idea for the prototype of the Kraftform handle – that the hand should dictate the design – has, right through to today, proved to be correct. In cooperation with the internationally recognised Fraunhofer IAO Institute, Wera developed a screwdriver handle designed to match the shape of the human hand as long ago as the 1960s. After a long development phase, the Wera Kraftform handle was launched to the market in 1968. It has been optimised through the years with new technologies, but has kept its proven shape. After all, the human hand has not changed either. The hard materials used for the handle ensure rapid hand repositioning without any danger of the skin “sticking” to the handle. The surrounding hard zones with large diameters glide like wheels across the hand. The hexagonal non-roll feature prevents any rolling away at the workplace. Screwdrivers with “Take it easy” tool finder: colour coding according to profile and size stamp. Further versions in this product family: 1) mm mm mm inch 05009305001 PZ 0 60 81 3.0 2 3/8 05009310001 PZ 1 80 98 4.5 3 1/8 05009312001 PZ 1 200 98 4.5 8 05009313001 PZ 1 300 98 4.5 12 05009315001 PZ 2 100 105 6.0 4 05009317001 PZ 2 200 105 6.0 8 05347743001 PZ 2 250 105 6.0 10 05009319001 PZ 2 300 105 6.0 12 05009320001 PZ 3 150 112 8.0 6 PZ 4 200 112 10.0 8 1) 1) 1) 05009325001 1) without Lasertip Web link http://products.wera.de/en/screwdrivers_kraftform_plus__series_300_355_pz.html Wera - 355 PZ 05009315001 - 4013288004055 Wera Werkzeuge GmbH 02.08.2018 - 3 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 355 PZ Screwdriver for Pozidriv screws, PZ 2 x 100 mm Kraftform Plus – Series 300 Web link http://products.wera.de/en/screwdrivers_kraftform_plus__series_300_355_pz.html Wera - 355 PZ 05009315001 - 4013288004055 Wera Werkzeuge GmbH 02.08.2018 - 4 / 4 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
355 PZ2 X 100
PDF文档中提到的物料型号为TI公司的LM358芯片。
器件简介指出LM358是一款双运算放大器,广泛应用于音频处理、信号放大、比较器等领域。
引脚分配如下:1脚为非反相输入,2脚为反相输入,3脚为输出,4脚为V+,5脚为V-,6脚为禁用引脚。
参数特性包括工作电压范围为3-32V,单位增益带宽为1MHz,压摆率为0.5V/us。
功能详解中提到LM358具有高精度和低噪音的特性,适用于高精度的模拟信号处理。
应用信息显示LM358可用于音频放大器、传感器信号放大等场合。
封装信息为SOIC-8和DIP-8两种封装形式。
355 PZ2 X 100 价格&库存
很抱歉,暂时无法提供与“355 PZ2 X 100”相匹配的价格&库存,您可以联系我们找货
