05021406001
05021406001
    WERA(维拉)
    WERA - 05021406001 - Hex Key Set, With Black Holder, 1.5 mm x 45 mm - 10 mm x 112 mm, 10 Piece
05021406001 数据手册
950/9 SM N L-key set, metric, chrome-plated, 9 pieces L-Keys for Hexagon Socket Screws EAN: 4013288111890 Size: 122x83x25 mm Part number: 05021406001 Weight: 254 g Article number: 950/9 Hex-Plus 5 Country of origin: CZ Customs tariff number: 82054000 L-keys for hexagonal socket screws Hex-Plus allows socket head screws to live longer High corrosion protection thanks to chrome-plating L-keys are quickly to hand thanks to their size markings Wear-resistant clip material for enhanced durability High quality L-key set for hexagonal socket screws. Hex-Plus offers a larger contact surface within the screw head. This reduces the notching effects to a minimum and almost completely eliminates the risk of destroying the screw recess. The precise chrome-plated design ensures high corrosion protection. All L-keys are quickly to hand thanks to the laser-engraved size markings. Come in a practical clip fastener out of wear-resistant material enabling the L-keys to be quickly accessed. Web link http://products.wera.de/en/l-keys_l-keys_for_hexagon_socket_screws_950_9_hex-plus_5.html Wera - 950/9 Hex-Plus 5 05021406001 - 4013288111890 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 950/9 SM N L-key set, metric, chrome-plated, 9 pieces L-Keys for Hexagon Socket Screws Set contents: 950 050210050011) 05021010001 05021015001 05021020001 05021030001 05021040001 05021045001 05021055001 05021065001 1 x 1.5x45 1 x 2.0x50 1 x 2.5x56 1 x 3.0x63 1 x 4.0x70 1 x 5.0x80 1 x 6.0x90 1 x 8.0x100 1 x 10.0x112 1) Regular hexagon. L-Keys Hex-Plus Surface protection Size identification We questioned the classic L-key design, since all too often the screw head recess is rounded out, meaning screws can no longer be tightened or loosened – and so the user finds the L-key slipping out of the recess. Wera Hex-Plus tools have a larger contact surface in the screw head. The notching effects are reduced and thereby the deformation of the screws. At the same time, as much as 20 % more torque can be applied. Hexagon screws can endure a problem because the contact surfaces delivering the power from the conventional tool, is transferred to the screw via very small surface areas. The consequence: the screw can become damaged (rounding out). Hex-Plus tools have a greater contact surface that prevents this from happening! At the same time, as much as 20 % more torque can be applied. Good to know: HexPlus tools fit into every standard hexagon socket screw! Chrome-plated hexagon L-keys for outstanding surface protection and long service life. High corrosion protection. The size of each L-keys has been engraved by a laser. In addition SPKL L-keys have a colour coding according to sizes – for simple and rapid accessing of the required tool. Making it easy to find the right tool. Web link http://products.wera.de/en/l-keys_l-keys_for_hexagon_socket_screws_950_9_hex-plus_5.html Wera - 950/9 Hex-Plus 5 05021406001 - 4013288111890 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 950/9 SM N L-key set, metric, chrome-plated, 9 pieces L-Keys for Hexagon Socket Screws Secure hold and easy removal The wear-resistant clip material ensures that the L-keys are securely held yet are easy to remove. Web link http://products.wera.de/en/l-keys_l-keys_for_hexagon_socket_screws_950_9_hex-plus_5.html Wera - 950/9 Hex-Plus 5 05021406001 - 4013288111890 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05021406001 价格&库存
很抱歉,暂时无法提供与“05021406001”相匹配的价格&库存,您可以联系我们找货
