1567 TORX® HF Kraftform Micro screwdriver with holding function for TORX®
screws, TX 4 x 40 mm
ESD Series
EAN:
4013288183972
Size:
157x13x13 mm
Part number:
05030400001
Weight:
12 g
Article number:
1567 TORX® HF Micro
Country of origin:
CZ
Customs tariff
number:
82054000
Kraftform Micro screwdriver for TORX® screws
ESD-safe tool thanks to surface resistance of < 10^9 Ohm
Multi-component Kraftform Micro handle for fast and ergonomic screwdriving
Holding function for TORX® screws
The Wera Black Point tip offers an exact fit and optimum corrosion protection
ESD-safe Micro screwdriver. Dependable protection against electrostatic energy and associated damage. Holding function: the wedging forces
resulting from the contact pressure between the drive tip and the screw profile securely hold the screw on the tool. Rapid twisting results from fixing
the hand on the head and using the fast-turning zone just below. This makes time-consuming grip adjustments unnecessary. Power zones with
integrated soft sections ensure the transfer of high loosening and tightening torque; a precision zone for the right rotation angle during fine
adjustment work. The Black Point tip offers optimised corrosion protection and an exact fit.
Web link
http://products.wera.de/en/screwdrivers_esd_series_1567_torx_hf_micro.html
Wera - 1567 TORX® HF Micro
05030400001 - 4013288183972
Wera Werkzeuge GmbH
02.08.2018 - 1 / 3
Korzerter Straße 21-25
D-42349 Wuppertal
Tel: +49 (0)2 02 / 40 45-0
E-Mail: info@wera.de
ESD Series
Wera ESD Tools
High protection
TORX® HF profile
When doing screwdriving jobs on
electronic components (like e.g.
smartphones and tablet PCs),
there should be no electrostatic
discharge as this could cause
malfunctions and a complete
failure. Therefore, tools that are
secure
against
electrostatic
discharge are indispensable.
The requirements for ESD-safe
screwdrivers are specified in the
European standard DIN EN
61340-5-1. This standard also
includes a handle that has to be
out of a defined conductive
material. The Wera products in the
ESD series satisfy these standards
and the even more stringent
requirements demanded by some
technology companies.
The electric surface resistance of
the Wera ESD material is ≤ 10^9
ohm. This securely protects
components against electrostatic
In tight assembly or disassembly
situations, for example in engine
compartments, it is not possible to
securely hold the screw with the
hand on the screwdriver, and the
screw subsequently often gets
lost. Lengthy searches or the loss
of the screw (with the associated
danger that could bring about) are
the consequence. The HF tools
developed by Wera are ideal
because they feature an optimised
geometry of the original TORX®
profile. The wedging forces
resulting from the surface
the screw profile mean that the
screw is securely held on the tool!
Kraftform Micro Handle
The precision zone
The power zone
Rotating cap and fast-turning
zone
Multi-component
screwdriver
handle for ergonomic working.
The precision zone directly above
the blade gives the user a better
feel for the right rotation angle
during fine adjustment work.
The power zone has integrated
soft zones near the blade tip to
ensure high torque transfer for
loosening or tightening screws
without losing contact with the
screw.
The fast-turning zone just below
the rotating cap allow rapid
twisting. This makes timeconsuming grip adjustments as
with other conventional precision
screwdrivers unnecessary.
Web link
Wera Werkzeuge GmbH
02.08.2018 - 2 / 3
D-42349 Wuppertal
ESD Series
Further versions in this product family:
mm
mm
mm
inch
05030400001
TX 4
40
97
2.5
1 9/16
05030401001
TX 5
40
97
3.0
1 9/16
05030402001
TX 6
40
97
3.0
1 9/16
05030403001
TX 7
60
97
3.0
2 3/8
05030404001
TX 8
60
97
3.0
2 3/8
05030405001
TX 9
60
97
4.0
2 3/8
05030406001
TX 10
60
97
4.0
2 3/8
Web link
Wera Werkzeuge GmbH
02.08.2018 - 3 / 3
Powered by TCPDF (www.tcpdf.org)
D-42349 Wuppertal
很抱歉,暂时无法提供与“05030400001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+106.657271+13.86510
- 5+99.964035+12.99500
- 10+89.4460810+11.62770
