05030402001
05030402001
    WERA(维拉)
    WERA - 05030402001 - Screwdriver, Torx, T6, 40 mm Blade, 157 mm Overall
05030402001 数据手册
1567 TORX® HF Kraftform Micro screwdriver with holding function for TORX® screws, TX 6 x 40 mm ESD Series EAN: 4013288183996 Size: 157x13x13 mm Part number: 05030402001 Weight: 14 g Article number: 1567 TORX® HF Micro Country of origin: CZ Customs tariff number: 82054000 Kraftform Micro screwdriver for TORX® screws ESD-safe tool thanks to surface resistance of < 10^9 Ohm Multi-component Kraftform Micro handle for fast and ergonomic screwdriving Holding function for TORX® screws The Wera Black Point tip offers an exact fit and optimum corrosion protection ESD-safe Micro screwdriver. Dependable protection against electrostatic energy and associated damage. Holding function: the wedging forces resulting from the contact pressure between the drive tip and the screw profile securely hold the screw on the tool. Rapid twisting results from fixing the hand on the head and using the fast-turning zone just below. This makes time-consuming grip adjustments unnecessary. Power zones with integrated soft sections ensure the transfer of high loosening and tightening torque; a precision zone for the right rotation angle during fine adjustment work. The Black Point tip offers optimised corrosion protection and an exact fit. Web link http://products.wera.de/en/screwdrivers_esd_series_1567_torx_hf_micro.html Wera - 1567 TORX® HF Micro 05030402001 - 4013288183996 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 1567 TORX® HF Kraftform Micro screwdriver with holding function for TORX® screws, TX 6 x 40 mm ESD Series Wera ESD Tools High protection TORX® HF profile When doing screwdriving jobs on electronic components (like e.g. smartphones and tablet PCs), there should be no electrostatic discharge as this could cause malfunctions and a complete failure. Therefore, tools that are secure against electrostatic discharge are indispensable. The requirements for ESD-safe screwdrivers are specified in the European standard DIN EN 61340-5-1. This standard also includes a handle that has to be out of a defined conductive material. The Wera products in the ESD series satisfy these standards and the even more stringent requirements demanded by some technology companies. The electric surface resistance of the Wera ESD material is ≤ 10^9 ohm. This securely protects components against electrostatic energy and associated damage. In tight assembly or disassembly situations, for example in engine compartments, it is not possible to securely hold the screw with the hand on the screwdriver, and the screw subsequently often gets lost. Lengthy searches or the loss of the screw (with the associated danger that could bring about) are the consequence. The HF tools developed by Wera are ideal because they feature an optimised geometry of the original TORX® profile. The wedging forces resulting from the surface pressure between the drive tip and the screw profile mean that the screw is securely held on the tool! Kraftform Micro Handle The precision zone The power zone Rotating cap and fast-turning zone Multi-component screwdriver handle for ergonomic working. The precision zone directly above the blade gives the user a better feel for the right rotation angle during fine adjustment work. The power zone has integrated soft zones near the blade tip to ensure high torque transfer for loosening or tightening screws without losing contact with the screw. The fast-turning zone just below the rotating cap allow rapid twisting. This makes timeconsuming grip adjustments as with other conventional precision screwdrivers unnecessary. Web link http://products.wera.de/en/screwdrivers_esd_series_1567_torx_hf_micro.html Wera - 1567 TORX® HF Micro 05030402001 - 4013288183996 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 1567 TORX® HF Kraftform Micro screwdriver with holding function for TORX® screws, TX 6 x 40 mm ESD Series Further versions in this product family: mm mm mm inch 05030400001 TX 4 40 97 2.5 1 9/16 05030401001 TX 5 40 97 3.0 1 9/16 05030402001 TX 6 40 97 3.0 1 9/16 05030403001 TX 7 60 97 3.0 2 3/8 05030404001 TX 8 60 97 3.0 2 3/8 05030405001 TX 9 60 97 4.0 2 3/8 05030406001 TX 10 60 97 4.0 2 3/8 Web link http://products.wera.de/en/screwdrivers_esd_series_1567_torx_hf_micro.html Wera - 1567 TORX® HF Micro 05030402001 - 4013288183996 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05030402001 价格&库存
很抱歉,暂时无法提供与“05030402001”相匹配的价格&库存,您可以联系我们找货
  • 1+79.732911+10.32820
  • 5+74.760515+9.68410
  • 10+67.3455210+8.72360
库存:18
