05057115001
05057115001
    WERA(维拉)
    WERA - 05057115001 - Bit Set, Universal Holder, Bit Check, Torx, 11 Piece
05057115001 数据手册
Bit-Check 10 TX Universal 2, 10 pieces Bit-Checks / Bit-Safes Universal EAN: 4013288127747 Size: 118x63x15 mm Part number: 05057115001 Weight: 104 g Article number: Bit-Check 10 TX Universal 2 Country of origin: CZ Customs tariff number: 82079030 Upright positionable, multi-component Bit-Check Rapidaptor holder for rapid bit change Tough viscous bits for universal use In handy and robust Bit-Check For use with power tools Robust Bit-Check by Wera. Bit-Checks provide a quick overview of the tools available. Bits not needed are simply reinserted into the set and do not get lost. Simple transportation e.g. in the shirt pocket. Includes universal holder with quick-release chuck: the Rapidaptor technology allows bits to be attached without any need to actuate the sleeve. The removal of the bit is simple, just by pushing the sleeve forward – for rapid bit change with just one hand. For the take-up of bits with ¼” hexagon head drive as per DIN ISO 1173-C 6.3. Can be inserted in the power screwdriver or for use in the chuck of the electric drill. Comes with tough viscous TORX bits for universal use. Web link http://products.wera.de/en/bits_holders_adaptors_bit_sets_bit-checks__bit-safes_universal_bit-check_10_tx_universal_2.html Wera - Bit-Check 10 TX Universal 2 05057115001 - 4013288127747 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Bit-Check 10 TX Universal 2, 10 pieces Bit-Checks / Bit-Safes Universal Set contents: 888/4/1 K 05052500001 867/1 TORX® 05066485001 05066486001 05066487001 05066488001 05066490001 05066491001 05066493001 05066495001 05066496001 1 x 1/4"x50 1 x TX 10x25 1 x TX 15x25 1 x TX 20x25 1 x TX 25x25 1 x TX 30x25 1 x TX 40x25 1 x TX 6x25 1 x TX 8x25 1 x TX 9x25 At the workplace Rapidaptor holder Rapid-in and self-lock Rapid-out The Bit-Checks can be positioned upright at the workplace so the tool is always quickly to hand. Rapid bit change without needing any additional tools. One-hand operation with a freely spinning sleeve for simplified guidance of the tool. Also available in a BiTorsion design. The bit can be pushed into the adaptor without moving the sleeve. The lock is activated automatically as soon as the bit is applied to the screw. Bits are held securely and wobble-free. Simply push the sleeve forward to change the bit. The spring mechanism lifts the bit off the magnet and unlocks the tool. The bit can be easily removed. The rapid-out function makes it easy to remove even the smallest bits without extra tools. Web link http://products.wera.de/en/bits_holders_adaptors_bit_sets_bit-checks__bit-safes_universal_bit-check_10_tx_universal_2.html Wera - Bit-Check 10 TX Universal 2 05057115001 - 4013288127747 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Bit-Check 10 TX Universal 2, 10 pieces Bit-Checks / Bit-Safes Universal Non-magnetic design Chuck-all Single-hand function Rapid-spin Non-magnetic bitholders that do not attract metal filings. The Rapidaptor quick-release chucks hold ¼" DIN ISO 1173-C 6,3 and E 6,3 as well as Wera series 1 and 4 bits. Every function of the Rapidator quick-release chuck, such as inserting or releasing bits, can be carried out with one hand. This is faster, more economical and more ergonomic. There are no unnecessary manoeuvres. The free-turning sleeve allows screw steadying at the start of the screwdriving process. This makes it easier to apply the tool to the screw and prevents slipping. It can also be used as a short extension for ¼" applications e.g. in combination with the Wera Zyklop Ratchets. Web link http://products.wera.de/en/bits_holders_adaptors_bit_sets_bit-checks__bit-safes_universal_bit-check_10_tx_universal_2.html Wera - Bit-Check 10 TX Universal 2 05057115001 - 4013288127747 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05057115001 价格&库存
很抱歉,暂时无法提供与“05057115001”相匹配的价格&库存,您可以联系我们找货
