05347108001
05347108001
    WERA(维拉)
    WERA - 05347108001 - Bit Set, Interchangeable Blades, 18 Pieces
05347108001 数据手册
Kraftform Kompakt VDE 18 Imperial 1, 18 pieces Kraftform Kompakt VDE EAN: 4013288182401 Size: 200x120x80 mm Part number: 05347108001 Weight: 686 g Article number: KK VDE 18 Imperial 1 Country of origin: CZ Customs tariff number: 82054000 Kraftform Kompakt VDE 18 Imperial 1 Multi-component VDE Kraftform handle with anti-roll feature VDE interchangeable blades 154 mm long In robust pouch Individually tested 16 VDE interchangeable blades with 2 817 VDE Kraftform holders in a robust belt pouch. Individually tested tools as per IEC 60900. Individual testing in a water bath at 10,000 volts so as to ensure safe working at the permitted voltage of 1,000 volts. Web link http://products.wera.de/en/vde_tools_kraftform_kompakt_vde_kk_vde_18_imperial_1.html Wera - KK VDE 18 Imperial 1 05347108001 - 4013288182401 Wera Werkzeuge GmbH 02.08.2018 - 1 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Kraftform Kompakt VDE 18 Imperial 1, 18 pieces Kraftform Kompakt VDE Set contents: 817 VDE 05003990001 2 x 9x102 KK 62 i 05003411001 05003412001 1 x PH 1x154 1 x PH 2x154 KK 62 i PH/S 05003440001 05003441001 1 x # 1x154 1 x # 2x154 KK 65 i PZ/S 05003445001 05003446001 1 x # 1x154 1 x # 2x154 KK 60 i 05003400001 05003402001 05003403001 05003404001 1 x 0.4x2.5x154 1 x 0.6x3.5x154 1 x 0.8x4.0x154 1 x 1.0x5.5x154 KK 68 i 05003415001 05003416001 1 x # 1x154 1 x # 2x154 KK 96 VK 6,3 05003460001 1 x 6.3x89 KK 97 VK 8,1 05003461001 1 x 8.1x89 KK 98 DK 05003462001 1 x 89 KK 99 FL 05003463001 1 x 89 Web link http://products.wera.de/en/vde_tools_kraftform_kompakt_vde_kk_vde_18_imperial_1.html Wera - KK VDE 18 Imperial 1 05347108001 - 4013288182401 Wera Werkzeuge GmbH 02.08.2018 - 2 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Kraftform Kompakt VDE 18 Imperial 1, 18 pieces Kraftform Kompakt VDE Why is the right tool so often missing at the workplace? The reason: too many tools and overlyheavy tool bags can make it bothersome to carry keep them with you. So for us it was a clear challenge: to develop a tool that is suitable for a whole host of applications and can be easily taken along to the workplace. Our solution: Kraftform Kompakt tools. A handle into which blades with a range of different profiles can be inserted. Compactly and protectively housed in a light and robust textile pouch – and they are even VDE-tested, too. Individually tested Handle/interchangeable blade system Easy exchange Each Kraftform Kompakt VDE set has been tested individually at 10,000 volts, in accordance with IEC 60900.This ten-times-higher testing load guarantees safe working at their maximum permitted load of 1,000 volts. The handle/interchangeable blade system allows rapid exchange of the blades required for a wide range of applications. Kraftform Kompakt VDE sets come with an insulated handle and insulated inter-changeable blades, that can be exchanged without any special tools. Web link http://products.wera.de/en/vde_tools_kraftform_kompakt_vde_kk_vde_18_imperial_1.html Wera - KK VDE 18 Imperial 1 05347108001 - 4013288182401 Wera Werkzeuge GmbH 02.08.2018 - 3 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Kraftform Kompakt VDE 18 Imperial 1, 18 pieces Kraftform Kompakt VDE Belt pouch Kraftform Prevents hand injuries Multi-component handle The tools can be stored and carried in a robust belt pouch, keeping them always to hand. The basic idea for the prototype of the Kraftform handle – that the hand should dictate the design – has, right through to today, proved to be correct. In cooperation with the internationally recognised Fraunhofer IAO Institute, Wera developed a screwdriver handle designed to match the shape of the human hand as long ago as the 1960s. After a long development phase, the Wera Kraftform handle was launched to the market in 1968. It has been optimised through the years with new technologies, but has kept its proven shape. After all, the human hand has not changed either. The outstanding design of the Kraftform handle that fits perfectly into the hand prevents hand injuries such as blisters and calluses. Wera produces the Kraftform handle out of several materials with different properties. A resistant plastic is used for the core which ensures that the blade is held securely even under high strain. A softer material is used for the coloured soft zones, which provides high frictional resistance and allows the transfer of high forces – resulting in less required screwdriving effort. The red sections with their hard surfaces prevent any “sticking” of the hand to the handle, making rapid repositioning of the hand possible. Web link http://products.wera.de/en/vde_tools_kraftform_kompakt_vde_kk_vde_18_imperial_1.html Wera - KK VDE 18 Imperial 1 05347108001 - 4013288182401 Wera Werkzeuge GmbH 02.08.2018 - 4 / 4 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05347108001 价格&库存
很抱歉,暂时无法提供与“05347108001”相匹配的价格&库存,您可以联系我们找货
