7440/41/42
7440/41/42
    WERA(维拉)
7440/41/42 数据手册
7440/41/42 Kraftform torque screwdriver set, 27 pieces Series 7400 Kraftform Torque Screwdrivers EAN: 4013288113924 Size: 255x210x62 mm Part number: 05074739001 Weight: 1145 g Article number: 7440/41/42 Country of origin: CZ Customs tariff number: 82079030 Kraftform torque screwdriver set Suitable for bits with 1/4" hex head drive With Hex-Plus, TORX® and TORX PLUS® bits In a stable case Wera torque screwdriver set. Two high precision torque screwdrivers with variable torque settings. One torque screwdriver with Kraftform pistol handle for the transfer of especially high torque; multi-component for high working speeds and particularly ergonomic screwdriving. Simple adjustment of the required torque value without any special tools. Easy-to-read scale value. Rapidaptor quick-release technology for rapid bit change. Unlimited torque to loosen seized screws. Multi-component Kraftform handle with hard and soft zones for high working speeds, whilst being easy on the hand. Includes a bit assortment in a high quality and stable plastic case. Web link http://products.wera.de/en/torque_tools_series_7400_kraftform_torque_screwdrivers_variable_torque_adjustment_models_7440_41_42.html Wera - 7440/41/42 05074739001 - 4013288113924 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 7440/41/42 Kraftform torque screwdriver set, 27 pieces Series 7400 Kraftform Torque Screwdrivers Set contents: 7400 05074700001 05074701001 7400 Pistole 05074702001 1 x 7440x1/4x0.3-1.2 1 x 7441x1/4x1.2-3.0 867/1 TZ TORX® 05066301001 1 x TX 6x25 05066302001 1 x TX 7x25 05066303001 1 x TX 8x25 05066304001 1 x TX 9x25 05066305001 1 x TX 10x25 05066308001 1 x TX 15x25 05066310001 1 x TX 20x25 05066312001 1 x TX 25x25 05066315001 1 x TX 30x25 1 x 7442x3.0-6.0 867/1 IP TORX PLUS® 05066274001 1 x 6 IPx25 05066276001 1 x 7 IPx25 05066278001 1 x 8 IPx25 05066279001 1 x 9 IPx25 05066280001 1 x 10 IPx25 05066282001 1 x 15 IPx25 05066284001 1 x 20 IPx25 05066286001 1 x 25 IPx25 05066288001 1 x 30 IPx25 840/1 Z Hex-Plus 05056305001 1 x 2.0x25 05056310001 1 x 2.5x25 05056315001 1 x 3.0x25 05056320001 1 x 4.0x25 05056325001 1 x 5.0x25 05056330001 1 x 6.0x25 Adjustable Torque Screwdrivers Simple setting Easy-to-read Wera’s adjustable torque screwdrivers allow variable torque settings with maximum precision and ensure that the user gets the very best results in the familiar Wera design with superior ergonomics. Simple setting of the required torque by hand. Easy-to-read scale value. Web link http://products.wera.de/en/torque_tools_series_7400_kraftform_torque_screwdrivers_variable_torque_adjustment_models_7440_41_42.html Wera - 7440/41/42 05074739001 - 4013288113924 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 7440/41/42 Kraftform torque screwdriver set, 27 pieces Series 7400 Kraftform Torque Screwdrivers Measurement accuracy Versatile Rapid-in and self-lock Rapid-out Measurement accuracy is ± 6 % in accordance with the standard DIN EN ISO 6789. Distinctly audible and noticeable excess-load signal when the pre-set torque is reached. Rapidaptor technology makes the tool adaptable since bits and sockets can be exchanged rapidly. The bit can be pushed into the adaptor without moving the sleeve. The lock is activated automatically as soon as the bit is applied to the screw. Bits are held securely and wobble-free. Simply push the sleeve forward to change the bit. The spring mechanism lifts the bit off the magnet and unlocks the tool. The bit can be easily removed. The rapid-out function makes it easy to remove even the smallest bits without extra tools. Web link http://products.wera.de/en/torque_tools_series_7400_kraftform_torque_screwdrivers_variable_torque_adjustment_models_7440_41_42.html Wera - 7440/41/42 05074739001 - 4013288113924 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
7440/41/42 价格&库存
很抱歉,暂时无法提供与“7440/41/42”相匹配的价格&库存,您可以联系我们找货
