8100 SA 12 HF
8100 SA 12 HF
    WERA(维拉)
    WERA - 8100 SA 12 HF - METAL RATCHET SET W/SWITCH LEVER, 1/4"
8100 SA 12 HF 数据手册
8100 SA 12 HF Zyklop Metal Ratchet Set with switch lever, 1/4" drive, metric, 13 pieces The Zyklop Metal Ratchets Switch, 1/4" EAN: 4013288190987 Size: 196x93x48 mm Part number: 05003756001 Weight: 557 g Article number: 8100 SA 12 HF Country of origin: CZ Customs tariff number: 82041100 Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_8100_sa_12_hf.html Wera - 8100 SA 12 HF 05003756001 - 4013288190987 Wera Werkzeuge GmbH 02.08.2018 - 1 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 8100 SA 12 HF Zyklop Metal Ratchet Set with switch lever, 1/4" drive, metric, 13 pieces The Zyklop Metal Ratchets Switch, 1/4" 13-piece ratchet set in robust textile box Extremely slim ratchet with long lever Sockets with holding function for screws/bolts/nuts Take it easy tool finder with colour coding according to sizes Suitable for docking with the Wera 2go system Incredibly compact set arrangement with many tools in a minimum of space. A completely new ratchet set feeling thanks to the unique textile boxes that are very robust and durable. They can be positioned upright for tidy storage on the workshop shelf. Additional surface protection due to textile outer material. Low weight and volume for simpler mobility. "Take it easy" Tool Finder with colour coding according to sizes. Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_8100_sa_12_hf.html Wera - 8100 SA 12 HF 05003756001 - 4013288190987 Wera Werkzeuge GmbH 02.08.2018 - 2 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 8100 SA 12 HF Zyklop Metal Ratchet Set with switch lever, 1/4" drive, metric, 13 pieces The Zyklop Metal Ratchets Switch, 1/4" Set contents: 8004 A 05004004001 1 x 1/4"x141.0 8794 A 05003527001 1 x 1/4"x56.0 8794 LA 05003526001 1 x 1/4"x150.0 8790 HMA HF 05003719001 05003720001 05003721001 05003722001 05003723001 05003725001 05003726001 05003727001 05003728001 1 x 5.0x23.0 1 x 5.5x23.0 1 x 6.0x23.0 1 x 7.0x23.0 1 x 8.0x23.0 1 x 10.0x23.0 1 x 11.0x23.0 1 x 12.0x23.0 1 x 13.0x23.0 Mutterentnahme-Werkzeug 05050005001 1 x 43.0x14.0 Due to the ever-more confined working environment, space is becoming more and more an issue for the application of ratchets. Our product developers therefore intensively occupied themselves with the issue of confined working spaces, and Wera has now solved this problem. The extremely slim and robust Zyklop Metal ratchet with a long lever was what emerged. When the socket must not get lost and a coincidental change of direction has to be avoided at all cost, the Zyklop Metal Push is the correct choice. Zyklop Metal Switch Reversible Small return angle Due to the ever-more confined working environment, space is becoming more and more an issue for the application of ratchets. Our product developers therefore intensively occupied themselves with the issue of confined working spaces, and Wera has now solved this problem. The extremely slim and robust Zyklop Metal ratchet with a long lever was what emerged. When the change in direction needs to be quick, the Zyklop Metal Switch ratchet is the right tool. When the socket must not get lost and a coincidental change of direction has to be avoided at all cost, the Zyklop Metal Push is the correct choice. Switch lever for convenient change of direction. Fine-pitched with 72 teeth for a return angle of only 5° Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_8100_sa_12_hf.html Wera - 8100 SA 12 HF 05003756001 - 4013288190987 Wera Werkzeuge GmbH 02.08.2018 - 3 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 8100 SA 12 HF Zyklop Metal Ratchet Set with switch lever, 1/4" drive, metric, 13 pieces The Zyklop Metal Ratchets Switch, 1/4" Sockets with retaining function for hexagon headed bolts, screws and nuts Secure hold and easy removal Take it easy tool finder system The Zyklop Ratchet Metal Switch The clamping of the screw is achieved by a twin spring loaded ball retention system. The tubing is effectively protected against mechanical wear and tear by a steel ring. The holding function is especially helpful in confined, hardto-reach spaces, where there is no room for a second hand to secure the screw. The all new smooth turning mechanism guarantees both secure and rattle-free storage, yet allows easy removal of the tool. Take it easy tool finder system with profile and size colour-coding for quick and easy tool selection. Colour-coded system for hexagon drive screws (L-Keys, Zyklop bit sockets), external hex drive screws and nuts (Joker wrenches, Zyklop sockets and Zyklop bit sockets with holding function), and TORX® drive screws (L-Keys, Zyklop bit sockets). Extremely slim. Long leverage. With switch lever. Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_8100_sa_12_hf.html Wera - 8100 SA 12 HF 05003756001 - 4013288190987 Wera Werkzeuge GmbH 02.08.2018 - 4 / 4 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
8100 SA 12 HF 价格&库存
很抱歉,暂时无法提供与“8100 SA 12 HF”相匹配的价格&库存,您可以联系我们找货
