950 SPKL/9 SM N MULTICOLOUR SB
    WERA(维拉)
    WERA - 950 SPKL/9 SM N MULTICOLOUR SB - Hex L-Key Set, Colour Coded, Long Arm, Metric, 9 Piece
950 SPKL/9 SM N MULTICOLOUR SB 数据手册
950 SPKL/9 SM N Multicolour L-key set, metric, BlackLaser, 9 pieces L-Keys for Hexagon Socket Screws Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_950_9_hex-plus_multicolour_1_sb.html Wera - 950/9 Hex-Plus Multicolour 1 SB SiS 05073593001 - 4013288165688 Wera Werkzeuge GmbH 02.08.2018 - 1 / 5 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 950 SPKL/9 SM N Multicolour L-key set, metric, BlackLaser, 9 pieces L-Keys for Hexagon Socket Screws Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_950_9_hex-plus_multicolour_1_sb.html Wera - 950/9 Hex-Plus Multicolour 1 SB SiS 05073593001 - 4013288165688 Wera Werkzeuge GmbH 02.08.2018 - 2 / 5 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 950 SPKL/9 SM N Multicolour L-key set, metric, BlackLaser, 9 pieces L-Keys for Hexagon Socket Screws EAN: 4013288165688 Size: 245x95x30 mm Part number: 05073593001 Weight: 655 g Article number: 950/9 Hex-Plus Multicolour Country of origin: 1 SB SiS Customs tariff number: CZ 82054000 Hex-Plus allows socket head screws to live longer Hexagonal ballpoint on the long arm Take it easy tool finder with colour coding according to sizes Colour coded, easy-to-grip plastic sleeve, even at low temperatures Wear-resistant clip material for enhanced durability High quality L-key set with colour coded, convenient plastic sleeve. This ensures that the tool is quickly to hand and the ergonomic and pleasant handle is easy on the hands even at low temperatures. The wear-resistant clip material ensures secure storage of the L-keys as well as simple removal. The Hex-Plus profile offers a greater contact surface in the head of the screw. The notching effect is therefore reduced to a minimum and damage to the screw head more or less eliminated. The ballpoint on the long arm allows dependable working even in difficult installation situations. The BlackLaser surface treatment provides outstanding surface protection, even against corrosion, and a long service life. Laser-engraved and thereby wear-resistant size markings on the L-keys for rapid accessing. Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_950_9_hex-plus_multicolour_1_sb.html Wera - 950/9 Hex-Plus Multicolour 1 SB SiS 05073593001 - 4013288165688 Wera Werkzeuge GmbH 02.08.2018 - 3 / 5 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 950 SPKL/9 SM N Multicolour L-key set, metric, BlackLaser, 9 pieces L-Keys for Hexagon Socket Screws Set contents: 950 SPKL Multicolour 05022600001 1 x 1.5x90 05022602001 1 x 2.0x101 05022606001 1 x 3.0x123 05022608001 1 x 4.0x137 05022610001 1 x 5.0x154 05022612001 1 x 6.0x172 05022614001 1 x 8.0x195 05022616001 1 x 10.0x224 05022604001 1 x 2.5x112 We questioned the classic L-key design, since all too often the screw head recess is rounded out, meaning screws can no longer be tightened or loosened – and so the user finds the L-key slipping out of the recess. Wera Hex-Plus tools have a larger contact surface in the screw head. The notching effects are reduced and thereby the deformation of the screws. At the same time, as much as 20 % more torque can be applied. SPKL L-keys Hex-Plus Ball tip L-keys made from circular material fit into the hand better and allow less strenuous work over a longer period. Additionally, the rubber sleeve provides a pleasant grip, particularly in applications at low temperatures. Colour coding and large stamp enable the desired Lkey to be easily located. Moreover, the round material keys are more robust, particularly where smaller sizes are concerned. Hexagon screws can endure a problem because the contact surfaces delivering the power from the conventional tool, is transferred to the screw via very small surface areas. The consequence: the screw can become damaged (rounding out). Hex-Plus tools have a greater contact surface that prevents this from happening! At the same time, as much as 20 % more torque can be applied. Good to know: HexPlus tools fit into every standard hexagon socket screw! The spherical drive profile means that it is possible to swivel the axis of the tool to that of the screw, and therefore enable angled, “around-the-corner” screwdriving jobs. Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_950_9_hex-plus_multicolour_1_sb.html Wera - 950/9 Hex-Plus Multicolour 1 SB SiS 05073593001 - 4013288165688 Wera Werkzeuge GmbH 02.08.2018 - 4 / 5 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 950 SPKL/9 SM N Multicolour L-key set, metric, BlackLaser, 9 pieces L-Keys for Hexagon Socket Screws Secure hold and easy removal Take it easy tool finder system The wear-resistant clip material ensures that the L-keys are securely held yet are easy to remove. Take it easy tool finder system with profile and size colour-coding for quick and easy tool selection. Colour-coded system for hexagon drive screws (L-Keys, Zyklop bit sockets), external hex drive screws and nuts (Joker wrenches, Zyklop sockets and Zyklop bit sockets with holding function), and TORX® drive screws (L-Keys, Zyklop bit sockets). Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_950_9_hex-plus_multicolour_1_sb.html Wera - 950/9 Hex-Plus Multicolour 1 SB SiS 05073593001 - 4013288165688 Wera Werkzeuge GmbH 02.08.2018 - 5 / 5 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
950 SPKL/9 SM N MULTICOLOUR SB 价格&库存
很抱歉,暂时无法提供与“950 SPKL/9 SM N MULTICOLOUR SB”相匹配的价格&库存,您可以联系我们找货
