030101
030101
    WERA(维拉)
030101 数据手册
1578 A Kraftform Micro screwdriver for slotted screws, 0.23 x 1.5 x 40 mm ESD Series EAN: 4013288039040 Size: 137x13x13 mm Part number: 05030101001 Weight: 11 g Article number: 1578 A Micro Country of origin: CZ Customs tariff number: 82054000 Kraftform Micro screwdriver for slotted screws ESD-safe tool thanks to surface resistance of < 10^9 Ohm Multi-component Kraftform Micro handle for fast and ergonomic screwdriving Anti-roll feature and swivel cap for rapid twisting The Wera Black Point tip offers an exact fit and optimum corrosion protection ESD-safe Micro screwdriver. Dependable protection against electrostatic energy and associated damage. Rapid twisting results from fixing the hand on the head and using the fast-turning zone just below. This makes time-consuming grip adjustments unnecessary. Power zones with integrated soft sections ensure the transfer of high loosening and tightening torque; a precision zone for the right rotation angle during fine adjustment work. The Black Point tip offers optimised corrosion protection and an exact fit. Web link http://products.wera.de/en/tools_for_the_aerospace_segment_screwdrivers_esd_series_1578_a_micro.html Wera - 1578 A Micro 05030101001 - 4013288039040 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 1578 A Kraftform Micro screwdriver for slotted screws, 0.23 x 1.5 x 40 mm ESD Series Wera ESD Tools High protection Kraftform Micro Handle When doing screwdriving jobs on electronic components (like e.g. smartphones and tablet PCs), there should be no electrostatic discharge as this could cause malfunctions and a complete failure. Therefore, tools that are secure against electrostatic discharge are indispensable. The requirements for ESD-safe screwdrivers are specified in the European standard DIN EN 61340-5-1. This standard also includes a handle that has to be out of a defined conductive material. The Wera products in the ESD series satisfy these standards and the even more stringent requirements demanded by some technology companies. The electric surface resistance of the Wera ESD material is ≤ 10^9 ohm. This securely protects components against electrostatic energy and associated damage. Multi-component screwdriver handle for ergonomic working. The precision zone The power zone Rotating cap and fast-turning zone Wera Black Point tip The precision zone directly above the blade gives the user a better feel for the right rotation angle during fine adjustment work. The power zone has integrated soft zones near the blade tip to ensure high torque transfer for loosening or tightening screws without losing contact with the screw. The fast-turning zone just below the rotating cap allow rapid twisting. This makes timeconsuming grip adjustments as with other conventional precision screwdrivers unnecessary. The Wera Black Point tip and a refined hardening process ensure long service life of the tip, improved corrosion protection and an exact fit. Web link http://products.wera.de/en/tools_for_the_aerospace_segment_screwdrivers_esd_series_1578_a_micro.html Wera - 1578 A Micro 05030101001 - 4013288039040 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 1578 A Kraftform Micro screwdriver for slotted screws, 0.23 x 1.5 x 40 mm ESD Series Further versions in this product family: mm mm mm mm mm inch inch 05030101001 0.23 1.5 40 97 2.5 1/16 1 9/16 05030100001 0.25 1.2 40 97 2.5 0.05 1 9/16 05030102001 0.30 1.8 60 97 2.5 0.07 2 3/8 05030108001 0.35 2.5 40 97 2.5 3/32 1 9/16 05030103001 0.40 2.0 60 97 2.5 5/64 2 3/8 05030104001 0.40 2.5 80 97 2.5 3/32 3 1/8 05030105001 0.50 3.0 80 97 3.0 1/8 3 1/8 05030106001 0.60 3.5 80 97 4.0 9/64 3 1/8 05030107001 0.80 4.0 80 97 4.0 5/32 3 1/8 Web link http://products.wera.de/en/tools_for_the_aerospace_segment_screwdrivers_esd_series_1578_a_micro.html Wera - 1578 A Micro 05030101001 - 4013288039040 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
030101 价格&库存
很抱歉,暂时无法提供与“030101”相匹配的价格&库存,您可以联系我们找货
