05004310001
05004310001
    WERA(维拉)
    WERA - 05004310001 - Screwdriver Set, Pozidrive, Torx, Slotted, Kraftform Plus, Quiver, Hook&Loop St...
05004310001 数据手册
Wera 2go 100, 11 pieces Innovations and Autumn/Winter Campaign 2017/2018 EAN: 4013288187826 Size: 185x115x240 mm Part number: 05004310001 Weight: 1198 g Article number: Kraftform 2go 100 Country of origin: CZ Customs tariff number: 82054000 Insulated VDE blades for secure work at 1,000 volts Multi-component Kraftform Micro handle for fast and ergonomic screwdriving Lasertip tips for more secure fit in the screw head Hexagonal anti-roll feature against rolling away Suitable for docking with the Wera 2go system. Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_kraftform_2go_100.html Wera - Kraftform 2go 100 05004310001 - 4013288187826 Wera Werkzeuge GmbH 02.08.2018 - 1 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Wera 2go 100, 11 pieces Innovations and Autumn/Winter Campaign 2017/2018 11 VDE-insulated, Kraftform screwdrivers; with "Take it easy" Toolfinder; in the Wera 2go 4 quiver; comes with an adjustable partition element for individual sectioning. Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_kraftform_2go_100.html Wera - Kraftform 2go 100 05004310001 - 4013288187826 Wera Werkzeuge GmbH 02.08.2018 - 2 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Wera 2go 100, 11 pieces Innovations and Autumn/Winter Campaign 2017/2018 Set contents: Wera 2go 4 05004353001 1 x 105x165.0 162 i PH VDE 05006152001 05006154001 165 i PZ VDE 05006162001 05006164001 1 x PZ 1x80 1 x PZ 2x100 167 i TORX® VDE 05006170001 1 x TX 10x80 05006172001 1 x TX 15x80 05006174001 1 x TX 20x80 160 i VDE 050061000011) 05006116001 05006121001 1 x 0.4x2.5x80 1 x 0.8x4.0x150 1 x 1.0x5.5x200 160 iS 05006440001 1 x PH 1x80 1 x PH 2x100 1 x 0.6x3.5x100 1) without Lasertip Klettstreifen 120 11990177 1 x 50.0x120.0 11990177 1 x 50.0x120.0 11990177 1 x 50.0x120.0 Wera 2go 4 Tool Quiver At the workplace and when out and about Robust and dimensionally stable Clever organisation The large set-down area improves the stability of the Tool Quiver. Its large handle means that the quiver can be easily transported or simply hung up at the workplace. The robust and dimensionally stable material is very resistant against cuts and stabs. The tools carried are protected against damage and moisture. This enhances the service life of the tool box. The variably adjustable hook and loop fastener partition in the Tool Quiver ensures neat and tidy arrangement of the tools. Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_kraftform_2go_100.html Wera - Kraftform 2go 100 05004310001 - 4013288187826 Wera Werkzeuge GmbH 02.08.2018 - 3 / 4 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Wera 2go 100, 11 pieces Innovations and Autumn/Winter Campaign 2017/2018 Perfect system supplement Lasertip prevents slipping out Individually tested “Take it easy” Toolfinder Thanks to its hook and loop fastener zone, the Tool Quiver can be docked with the Wera 2go 1 tool carrier and with the Wera 2go 2 tool container. It happens time and time again that the tip slips out of the screw head when screwdriving, sometimes damaging valuable surfaces or even causing injury. The tips of the Wera Lasertip screwdrivers are microscopically roughened by means of a laser. This rough surface literally “bites” itself firmly into the screw head. Slipping out becomes a thing of the past. The individual testing at 10,000 volts, in accordance with IEC 60900, ensures safe working with loads up to 1,000 volts. Colour-coded output drive (red = Phillips; black = Pozidriv; green = TORX®; yellow = slotted) and size stamp on the handle to enable the required screwdriver to be easily identified. Web link http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_kraftform_2go_100.html Wera - Kraftform 2go 100 05004310001 - 4013288187826 Wera Werkzeuge GmbH 02.08.2018 - 4 / 4 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05004310001 价格&库存
很抱歉,暂时无法提供与“05004310001”相匹配的价格&库存,您可以联系我们找货
  • 1+801.63635
库存:25
