950 SPKL/9 SM HF Multicolour L-key set, metric, BlackLaser, with holding function,
9 pieces
Innovations and Autumn/Winter Campaign 2017/2018
EAN:
4013288188403
Size:
241x95x31 mm
Part number:
05022210001
Weight:
655 g
Article number:
950/9 Hex-Plus Multicolour Country of origin:
HF 1
Customs tariff
number:
CZ
82054000
Hex-Plus allows socket head screws to live longer
L-keys with retaining function for hexagon socket screws
Hexagonal ballpoint on the long arm
Take it easy tool finder with colour coding according to sizes
Colour coded, easy-to-grip plastic sleeve, even at low temperatures
High quality L-key set with colour coded, convenient plastic sleeve. This ensures that the tool is quickly to hand and the ergonomic and pleasant
handle is easy on the hands even at low temperatures. The wear-resistant clip material ensures secure storage of the L-keys as well as simple
removal. The Hex-Plus profile offers a greater contact surface in the head of the screw. The notching effect is therefore reduced to a minimum and
damage to the screw head more or less eliminated. The ballpoint on the long arm allows dependable working even in difficult installation situations.
The holding function holds screws securely on the tool. The BlackLaser surface treatment provides outstanding surface protection, even against
corrosion, and a long service life. Laser-engraved and thereby wear-resistant size markings on the L-keys for rapid accessing.
Web link
http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_950_9_hex-plus_multicolour_hf_1.html
Wera - 950/9 Hex-Plus Multicolour HF 1
05022210001 - 4013288188403
Wera Werkzeuge GmbH
02.08.2018 - 1 / 3
Korzerter Straße 21-25
D-42349 Wuppertal
Tel: +49 (0)2 02 / 40 45-0
E-Mail: info@wera.de
9 pieces
Set contents:
950 SPKL Multicolour
05022600001 1 x 1.5x90
05022602001 1 x 2.0x101
05022604001 1 x 2.5x112
We questioned the classic L-key
design, since all too often the
screw head recess is rounded out,
meaning screws can no longer be
tightened or loosened – and so the
user finds the L-key slipping out of
the recess. Wera Hex-Plus tools
have a larger contact surface in
the screw head. The notching
effects are reduced and thereby
the deformation of the screws. At
the same time, as much as 20 %
more torque can be applied.
950 SPKL HF Multicolour
05022200001 1 x 3.0x123
05022201001 1 x 4.0x137
05022202001 1 x 5.0x154
05022203001 1 x 6.0x172
05022204001 1 x 8.0x195
05022205001 1 x 10.0x224
Hex-Plus
Ball tip
The clamping of the screw is
achieved by a flexible locking ball.
The holding function is especially
helpful in confined, hard-to-reach
spaces, where there is no room for
a second hand to sec
Hexagon screws can endure a
problem because the contact
surfaces delivering the power from
the
conventional
tool,
is
transferred to the screw via very
small surface areas. The
consequence: the screw can
become damaged (rounding out).
Hex-Plus tools have a greater
contact surface that prevents this
from happening! At the same time,
as much as 20 % more torque can
be applied. Good to know: HexPlus tools fit into every standard
hexagon socket screw!
The spherical drive profile means
that it is possible to swivel the axis
of the tool to that of the screw,
and therefore enable angled,
“around-the-corner” screwdriving
jobs.
Web link
Wera Werkzeuge GmbH
02.08.2018 - 2 / 3
D-42349 Wuppertal
9 pieces
SPKL L-keys
Secure hold and easy removal
Take it easy tool finder system
L-keys made from circular material
fit into the hand better and allow
less strenuous work over a longer
period. Additionally, the rubber
sleeve provides a pleasant grip,
particularly in applications at low
temperatures. Colour coding and
large stamp enable the desired Lkey to be easily located. Moreover,
the round material keys are more
robust, particularly where smaller
sizes are concerned.
ensures that the L-keys are
securely held yet are easy to
remove.
Take it easy tool finder system with profile and size colour-coding
for quick and easy tool selection.
Colour-coded system for hexagon
drive screws (L-Keys, Zyklop bit
sockets), external hex drive screws
and nuts (Joker wrenches, Zyklop
sockets and Zyklop bit sockets
with holding function), and TORX®
sockets).
Web link
Wera Werkzeuge GmbH
02.08.2018 - 3 / 3
Powered by TCPDF (www.tcpdf.org)
D-42349 Wuppertal
很抱歉,暂时无法提供与“05022210001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+413.600211+53.50550
- 3+387.744733+50.16070
- 5+349.048885+45.15480
- 国内价格
- 1+413.76803
- 3+387.90753
- 5+349.17068
