05052504001
05052504001
    WERA(维拉)
    WERA - 05052504001 - Bit Holder, Hex Bits, Rapidator, 100 mm, 1/4" Driver - Bit Holder, Hex Bits, Ra...
05052504001 数据手册
889/4 R Rapidaptor Universal Bit Holder, 1/4 inch x 100 mm x 1/4 inch Rapidaptor Bit Holders EAN: 4013288101242 Size: 109x40x40 mm Part number: 05052504001 Weight: 39 g Article number: 889/4 R Country of origin: CZ Customs tariff number: 84661038 Rapidaptor technology for rapid bit change Rapidaptor universal holder for bits with 1/4" hexagon drive, magnetic 1/4" hexagon drive Rapidaptor universal holder for bits with ¼” hexagon head drive as per DIN ISO 1173-C 6.3 and E 6.3 (ISO 1173). The Rapidaptor allows bits to be attached without any need to actuate the sleeve. The removal of the bit is simple, just by pushing the sleeve forward. This enables rapid bit change with just one hand. The strong permanent magnet holds the bits absolutely securely. ¼” hexagonal, suitable for power screwdrivers with take-up as per DIN ISO 1173-F 6.3. Web link http://products.wera.de/en/bits_holders_adaptors_holders_adaptors_connectors_rapidaptor_bit_holders_889_4_r.html Wera - 889/4 R 05052504001 - 4013288101242 Wera Werkzeuge GmbH 02.08.2018 - 1 / 2 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 889/4 R Rapidaptor Universal Bit Holder, 1/4 inch x 100 mm x 1/4 inch Rapidaptor Bit Holders Magnetic Rapidaptor holder Chuck-all Single-hand function Bitholders, magnetic, for easier application of the screw. Rapid bit change without needing any additional tools. One-hand operation with a freely spinning sleeve for simplified guidance of the tool. Also available in a BiTorsion design. The Rapidaptor quick-release chucks hold ¼" DIN ISO 1173-C 6,3 and E 6,3 as well as Wera series 1 and 4 bits. Every function of the Rapidator quick-release chuck, such as inserting or releasing bits, can be carried out with one hand. This is faster, more economical and more ergonomic. There are no unnecessary manoeuvres. Rapid-in and self-lock Rapid-out Rapid-spin The bit can be pushed into the adaptor without moving the sleeve. The lock is activated automatically as soon as the bit is applied to the screw. Bits are held securely and wobble-free. Simply push the sleeve forward to change the bit. The spring mechanism lifts the bit off the magnet and unlocks the tool. The bit can be easily removed. The rapid-out function makes it easy to remove even the smallest bits without extra tools. The free-turning sleeve allows screw steadying at the start of the screwdriving process. This makes it easier to apply the tool to the screw and prevents slipping. It can also be used as a short extension for ¼" applications e.g. in combination with the Wera Zyklop Ratchets. Further versions in this product family: 05052504001 inch mm inch inch mm 1/4" 100 4 1/4" 15.0 Web link http://products.wera.de/en/bits_holders_adaptors_holders_adaptors_connectors_rapidaptor_bit_holders_889_4_r.html Wera - 889/4 R 05052504001 - 4013288101242 Wera Werkzeuge GmbH 02.08.2018 - 2 / 2 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05052504001 价格&库存
很抱歉,暂时无法提供与“05052504001”相匹配的价格&库存,您可以联系我们找货
库存:45
