05057432001
05057432001
    WERA(维拉)
    WERA - 05057432001 - Bit Set, Phillips, Pozidrive, Torx, 30 Piece
05057432001 数据手册
Bit-Check 30 Wood 2, 30 pieces Bit-Checks Wood EAN: 4013288179845 Size: 135x65x20 mm Part number: 05057432001 Weight: 225 g Article number: Bit-Check 30 Wood 2 Country of origin: CZ Customs tariff number: 82079030 The Bit-Checks by Wera are extremely compact and are therefore the ideal companion for mobile applications. Upright positionable Bit-Checks convince due to their functionality in a minimum of space Particularly for wood applications Universal holder with stainless sleeve Tough viscous bits for universal use Robust Bit-Check by Wera. Bit-Checks provide a quick overview of the tools available. Bits not needed are simply reinserted into the set and do not get lost. Simple transportation e.g. in the shirt pocket. Includes universal holder with strong permanent magnet for the take-up of bits with ¼” hexagon head drive. Can be inserted in the power screwdriver or for use in the chuck of the electric drill. Multi-component Bit-Check that can be positioned upright for permanently secure bit storage. Web link http://products.wera.de/en/bits_holders_adaptors_bit_sets_bit-checks_wood_bit-check_30_wood_2.html Wera - Bit-Check 30 Wood 2 05057432001 - 4013288179845 Wera Werkzeuge GmbH 02.08.2018 - 1 / 2 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Bit-Check 30 Wood 2, 30 pieces Bit-Checks Wood Set contents: 899/4/1 05053457001 1 x 899/4/1 Kx1/4"x50 855/1 Z PZ 05072080001 05072082001 05072084001 2 x PZ 1x25 5 x PZ 2x25 2 x PZ 3x25 851/1 Z PH 05072072001 1 x PH 2x25 867/1 TORX® 05066485001 05066486001 05066487001 05066488001 05066490001 05066491001 3 x TX 10x25 4 x TX 15x25 4 x TX 20x25 4 x TX 25x25 3 x TX 30x25 1 x TX 40x25 At the workplace Universal holder with stainless steel sleeve Bit Ranges The Bit-Checks can be positioned upright at the workplace so the tool is always quickly to hand. The retaining ring and the strong permanent magnet ensure a particularly secure fitting of the bit in the holder. We have had bit ranges in our programme for many years now. In 2016, we put a question mark against everything and came up with a game changer. We wanted bit ranges with bits whose profiles and sizes could be more easily recognised. We wanted bit ranges that were as compact as possible and which were Wera-like at a first glance. We wanted bit ranges with bits that could be removed and reinserted more easily. We wanted bit ranges with as little weight as possible. The new multicomponent Bit-Checks satisfy these requirements; the soft material in the lower section of the Bit-Checks ensures that the bits are firmly held yet easy to remove. Web link http://products.wera.de/en/bits_holders_adaptors_bit_sets_bit-checks_wood_bit-check_30_wood_2.html Wera - Bit-Check 30 Wood 2 05057432001 - 4013288179845 Wera Werkzeuge GmbH 02.08.2018 - 2 / 2 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05057432001 价格&库存
很抱歉,暂时无法提供与“05057432001”相匹配的价格&库存,您可以联系我们找货
    • 1+205.826371+26.73580
    • 5+192.951345+25.06340
    • 10+173.6388110+22.55480
    库存:11
    05057432001
      • 1+221.84597
      库存:36
