Joker Set of ratcheting combination wrenches SB, 4 pieces
Innovations and Autumn/Winter Campaign 2017/2018
EAN:
4013288164407
Size:
305x95x55 mm
Part number:
05073290001
Weight:
896 g
Article number:
Joker Set 4
Country of origin:
CZ
Customs tariff
number:
82041100
Practical holding function thanks to the metal plate in the jaw
Limit stop prevents any slipping
The double-hex geometry reduces the risk of slipping
Return angle of only 30°
Take it easy tool finder with colour coding according to sizes
High quality combination ratchet wrench set by Wera: everything that a wrench has to be able to do. And a whole lot more. Faster, better, stylish.
Yes, a real Joker. The new generation of combination ratchet wrenches. 4-piece set in a robust pouch. Suitable for hexagon bolt heads or nuts.
Comes with a holding function, thanks to the metal plate in the jaw, which reduces the risk of dropping nuts and bolts. The replaceable metal plate in
the jaw secures nuts and bolts with its extra hard teeth and limits the danger of slipping. The integrated limit stop prevents any slipping down around
the bolt head and allows higher torque to be applied. The double-hex geometry makes for a positive connection with nuts or bolts and reduces the
risk of slipping. A return angle of only 30° at the open end prevents any time consuming flipping of the wrench during fastening jobs. The ratchet
mechanism at the ring end, with an exceptional, fine-tooth mechanism – 80 teeth in all – enables flexibility even in very confined working spaces.
The specially forged geometry provides for high torque transfer and strength. Manufactured out of high performance chrome molybdenum steel with
a nickel-chrome coating for high corrosion protection. "Take it easy" Tool Finder with colour coding according to sizes
Web link
http://products.wera.de/en/innovations_and_spring__summer_campaign_2018_joker_set_4.html
Wera - Joker Set 4
05073290001 - 4013288164407
Wera Werkzeuge GmbH
02.08.2018 - 1 / 3
Korzerter Straße 21-25
D-42349 Wuppertal
Tel: +49 (0)2 02 / 40 45-0
E-Mail: info@wera.de
Set contents:
Joker
05073270001
05073273001
05073277001
05073279001
The ratcheting feature at the ring
end boasts an exceptional, fine
– which provides greater flexibility,
spaces.
1 x 10x159
1 x 13x177
1 x 17x224
1 x 19x246
Joker open-ended wrench
Holding function
Integrated limit-stop
When we began to think about
open-ended wrenches, we asked
ourselves: why does the wrench
always have to be flipped over;
why does it have an offset design;
why does it slip off injuring
fingers? The new design of the
mouth resulted in a real “Joker”
that works even when all other
trumps have been played.
The Joker’s holding function
means that nuts and bolts can be
held in the jaw and easily
positioned where they are needed.
Fastening on to the thread can
then be done quickly and safely,
thanks to the innovative special
stop-plate which holds the
fastener. No more time-wasting
searches for dropped nuts and
bolts!
After
applying
and
positioning the nut or bolt,
fastening can begin immediately –
no additional tools required.
Constant re-positioning of the
wrench?
Difficulty
holding
fasteners in confined spaces?
Easing off to avoid any risks of
injury or fastener damage? That
was yesterday. Today, the Joker
prevents slipping off of the
fastener head with its integrated
limit-stop – no longer is the thumb
needed to act as a depth stop.
This makes applications much
easier and allows signifi cantly
more force to be applied during
fastening jobs.
Web link
Wera - Joker Set 4
Wera Werkzeuge GmbH
02.08.2018 - 2 / 3
D-42349 Wuppertal
Double-hex geometry
Small return angle
Fine tooth mechanism
“Take it easy” tool finder
The Joker’s clever double-hex
geometry delivers a very positive
connection with nuts or bolts – it’s
a
perfect
fit.
And
the
exchangeable, hardened metal
gripping plate in the Joker’s mouth
literally bites itself into the bolt,
with its extremely hard tips. Both
features combine to prevent
slipping, even at higher torque.
Instead of 60°, the Joker only has
a 30° return angle thanks to it’s
unique double-hex design. Along
with the Joker’s straight neck, this
means that flipping the wrench
has become a thing of the past.
With the Joker, you can now
loosen and tighten nuts and bolts,
in situations where conventional
tools fail. Particularly in confined
spaces, where conventional openjawed wrenches cannot be used.
The combination of limit stop and
small return angle enables eff
ective work, even on screw pipe
connections.
even
in
very
confined
workingspaces.
Take it easy tool finder system with profile and size colour-coding
for quick and easy tool selection.
Colour-coded system for hexagon
drive screws (L-Keys, Zyklop bit
sockets), external hex drive screws
and nuts (Joker wrenches, Zyklop
sockets and Zyklop bit sockets
with holding function), and TORX®
sockets).
Web link
Wera - Joker Set 4
Wera Werkzeuge GmbH
02.08.2018 - 3 / 3
Powered by TCPDF (www.tcpdf.org)
D-42349 Wuppertal
很抱歉,暂时无法提供与“05073290001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1057.056091+136.89950
- 2+991.093702+128.35670
- 5+832.557105+107.82460
