190I 3K SW 5,5 X 125 MM
    WERA(维拉)
    WERA - 190I 3K SW 5,5 X 125 MM - 5.5mm VDE Insulated Nutspinner with Non-roll Feature
190I 3K SW 5,5 X 125 MM 数据手册
190 i VDE Insulated nutdriver, 5.5 x 125 mm Kraftform Plus – Series 100 VDE EAN: 4013288032485 Size: 223x26x26 mm Part number: 05005300001 Weight: 92 g Article number: 190 i VDE Country of origin: CZ Customs tariff number: 82054000 Insulated VDE blades for secure work at 1,000 volts Smooth hard zones for high speed turning, soft grip zones for high torque transfer Handle markings simplify finding and sorting of tools Hexagonal anti-roll feature against rolling away Zinc phosphate plated Wera VDE socket wrenches with multi-component Kraftform for fast and low-fatigue working: hard gripping zones for high working speeds whereas soft zones ensure high torque transfer. Individually tested in water bath at 10,000 volts for secure work at the permissible voltage of 1,000 volts. The hexagonal anti-roll feature prevents any bothersome rolling away at the workplace. Web link http://products.wera.de/en/vde_tools_kraftform_plus__series_100_vde_190_i_vde.html Wera - 190 i VDE 05005300001 - 4013288032485 Wera Werkzeuge GmbH 02.08.2018 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 190 i VDE Insulated nutdriver, 5.5 x 125 mm Kraftform Plus – Series 100 VDE Individually tested Impact strength test Multicomponent Kraftform handle Our screwdrivers are tested for dielectric strength under a 10,000 volt load to make sure that their most important property, their insulation, has been exhaustively tested. Each individual Wera VDE screwdriver is subjected to this test to guarantee safe working up to 1,000 volts. The individual testing at 10,000 volts, in accordance with IEC 60900, ensures safe working with loads up to 1,000 volts. Impact strength tested at −40°C, guaranteeing safety even under extreme conditions. Wera produces the Kraftform handle out of several materials with different properties. A resistant plastic is used for the core which ensures that the blade is held securely even under high strain. A softer material is used for the coloured soft zones, which provides high frictional resistance and allows the transfer of high forces – resulting in less required screwdriving effort. The red sections with their hard surfaces prevent any “sticking” of the hand to the handle, making rapid repositioning of the hand possible. Prevents hand injuries Rapid hand repositioning Identification marking Non-roll feature The outstanding design of the Kraftform handle that fits perfectly into the hand prevents hand injuries such as blisters and calluses. The hard materials used for the handle ensure rapid hand repositioning without any danger of the skin “sticking” to the handle. The surrounding hard zones with large diameters glide like wheels across the hand. The screw symbol and tip size identification markings on the handle make it easier to find the right screwdriver in the tool case or at the workplace. The hexagonal non-roll feature prevents any rolling away at the workplace. Web link http://products.wera.de/en/vde_tools_kraftform_plus__series_100_vde_190_i_vde.html Wera - 190 i VDE 05005300001 - 4013288032485 Wera Werkzeuge GmbH 02.08.2018 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de 190 i VDE Insulated nutdriver, 5.5 x 125 mm Kraftform Plus – Series 100 VDE Further versions in this product family: mm mm mm mm 05005300001 5.5 - 125 98 11.0 5 05005305001 6.0 - 125 98 12.0 5 05005310001 7.0 - 125 105 14.0 5 05005315001 8.0 - 125 105 15.0 5 05005320001 9.0 - 125 105 16.0 5 05005325001 10.0 - 125 112 17.0 5 05005330001 11.0 - 125 112 19.0 5 05005335001 12.0 - 125 112 20.0 5 05005340001 13.0 - 125 112 21.0 5 05104900001 - 3/16" 125 98 11.0 5 05345280001 - 7/32" 125 98 12.0 5 05104905001 - 1/4" 125 98 13.0 5 05104901001 - 5/16" 125 105 15.0 5 05104906001 - 3/8" 125 105 17.0 5 05104902001 - 7/16" 125 112 19.0 5 05104904001 - 1/2" 125 112 21.0 5 05104903001 - 9/16" 125 112 23.0 5 05104907001 - 5/8" 125 112 25.0 5 Web link http://products.wera.de/en/vde_tools_kraftform_plus__series_100_vde_190_i_vde.html Wera - 190 i VDE 05005300001 - 4013288032485 Wera Werkzeuge GmbH 02.08.2018 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
190I 3K SW 5,5 X 125 MM 价格&库存
很抱歉,暂时无法提供与“190I 3K SW 5,5 X 125 MM”相匹配的价格&库存,您可以联系我们找货
