6004 Joker 4 set 1 self-setting spanner set, 4 pieces
News and Promotional Products Autumn/Winter 2020/2021
EAN:
4013288217516
Size:
265x120x45 mm
Part number:
05020110001
Weight:
981 g
Article number:
6004 Joker 4 Set 1
Country of origin:
CZ
Customs tariff
number:
82041200
The compact folding pouch with four adjustable Joker 6004 spanners covers all metric and imperial dimensions in applications from 7 to 19
mm or 1/4" to ¾"
Automatic and continuous gripping of the hexagon screw or bolt
Lever mechanism when gripping avoids slippage and damage
Fast and consistent screwdriving without removing the wrench thanks to mechanical ratchet function
Return angle of only 30° through placement in the corner-width rectangular prisms in the mouth
Many users wish to have a universal screwdriving tool with the widest possible range of applications. It should be a single tool for multiple metric and
imperial dimensions. It should automatically adjust to the different screw sizes. It should be safe to grab without damaging anything and should allow
for high working speeds. With its continuous and parallel jaws the Joker 6004 replaces several single spanner sizes. The required size is
automatically and continuously set when attaching the tool to the hexagon bolt or screw. The integrated lever mechanism securely clamps the
hexagon screw or bolt between the jaws, which significantly reduces the risk of slippage or damage. The ratchet feature ensures fast and consistent
screwdriving without removing the tool. By using the corner-width rectangular prisms, a return angle of only 30° can be achieved. The single-arm
design, in conjunction with the ratchet feature and the corner-width prism, makes it possible to work even in confined spaces. The adjustable Joker
6004 is the universal screwdriving tool. Self-setting. Gripping. Spanning. 4-piece set for at least 18 different metric and imperial screw drives, comes
in a compact folding bag. The Joker bags are suitable for attachment to walls, shelves, workshop trolleys and the Wera 2go system thanks to the
hook and loop fastener system on the back.
Web link
https://products.wera.de/en/joker_6004_joker_self-setting_adjustable_spanner_6004_joker_4_set_1.html
Wera - 6004 Joker 4 Set 1
05020110001 - 4013288217516
Wera Werkzeuge GmbH
03.09.2020 - 1 / 2
Korzerter Straße 21-25
D-42349 Wuppertal
Tel: +49 (0)2 02 / 40 45-0
E-Mail: info@wera.de
Set contents:
6004 Joker XS
05020099001
1 x 7-10 x 1/4“-3/8“" x 117 mm
6004 Joker S
05020100001
6004 Joker M
05020103001
1 x 13-16 x 1/2-5/8" x 188 mm
6004 Joker L
05020101001
from 7 to 19 mm or 1/4" to ¾"
1 x 10-13 x 7/16“-1/2“" x 154
mm
1 x 16-19 x 5/8“-3/4“" x 224
mm
Automatically and continuously
self-setting
Gentle to the screw
Ratchet mechanism for fast
work
With its automatically and
continuousy gripping parallel jaws
the Joker spanner 6004 covers all
dimensions in the respective field
of
application.
The
tool
automatically finds the required
size when placed on the bolt or
screw, no setting required.
The parallel smooth jaws of the
Joker 6004 allow surface pressure
and can thus prevent rounding of
the bolt or screw head, which can
occur during power transmission
on corners.
The ratchet function in the mouth
sees to fast and consistent
tool.
Small return angle
Thanks to the corner-width
of only 30° can be realized.
Web link
Wera Werkzeuge GmbH
03.09.2020 - 2 / 2
Powered by TCPDF (www.tcpdf.org)
D-42349 Wuppertal
很抱歉,暂时无法提供与“05020110001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2265.71667
- 5+2220.40424
- 国内价格 香港价格
- 1+2089.005881+270.24480
- 3+1958.443013+253.35450
- 5+1762.655535+228.02640
