950 PKL/9 BM N L-key set, metric, BlackLaser, 9 pieces
L-Keys for Hexagon Socket Screws
EAN:
4013288104809
Size:
229x83x25 mm
Part number:
05022086001
Weight:
411 g
Article number:
950/9 Hex-Plus 6
Country of origin:
CZ
Customs tariff
number:
82054000
L-keys for hexagonal socket screws
Hex-Plus allows socket head screws to live longer
BlackLaser for high corrosion protection and long service life
L-keys are quickly to hand thanks to their size markings
Wear-resistant clip material for enhanced durability
High quality L-key set for hexagonal socket screws in a practical clip fastener out of wear-resistant material, enabling secure storage of the L-keys as
well as simple removal. L-keys with Hex-Plus profile: offers a larger contact surface within the screw head. This reduces the notching effects to a
minimum and almost completely eliminates the risk of destroying the screw recess. The ball-end on the long arm allows for reliable working even in
difficult installation situations. The BlackLaser surface treatment provides outstanding surface protection, even against corrosion, and a long service
life. The tools are quickly to hand thanks to the laser-engraved and thereby wear-resistant size markings on the L-keys.
Web link
http://products.wera.de/en/l-keys_l-keys_for_hexagon_socket_screws_950_9_hex-plus_6.html
Wera - 950/9 Hex-Plus 6
05022086001 - 4013288104809
Wera Werkzeuge GmbH
02.08.2018 - 1 / 3
Korzerter Straße 21-25
D-42349 Wuppertal
Tel: +49 (0)2 02 / 40 45-0
E-Mail: info@wera.de
Set contents:
950 PKL BM
050271010011)
05027102001
05027103001
05027104001
05027105001
05027106001
05027107001
05027108001
05027109001
1 x 1.5x90
1 x 2.0x100
1 x 2.5x112
1 x 3.0x126
1 x 4.0x140
1 x 5.0x160
1 x 6.0x180
1 x 8.0x200
1 x 10.0x219
1) Regular hexagon
L-Keys
Hex-Plus
Ball tip
Surface protection
We questioned the classic L-key
design, since all too often the
screw head recess is rounded out,
meaning screws can no longer be
tightened or loosened – and so the
user finds the L-key slipping out of
the recess. Wera Hex-Plus tools
have a larger contact surface in
the screw head. The notching
effects are reduced and thereby
the deformation of the screws. At
the same time, as much as 20 %
more torque can be applied.
Hexagon screws can endure a
problem because the contact
surfaces delivering the power from
the
conventional
tool,
is
transferred to the screw via very
small surface areas. The
consequence: the screw can
become damaged (rounding out).
Hex-Plus tools have a greater
contact surface that prevents this
from happening! At the same time,
as much as 20 % more torque can
be applied. Good to know: HexPlus tools fit into every standard
hexagon socket screw!
The spherical drive profile means
that it is possible to swivel the axis
of the tool to that of the screw,
and therefore enable angled,
“around-the-corner” screwdriving
jobs.
L-keys with BlackLaser surface
treatment for outstanding surface
protection and long service life.
High corrosion protection.
Web link
Wera Werkzeuge GmbH
02.08.2018 - 2 / 3
D-42349 Wuppertal
Size identification
Secure hold and easy removal
The size of each L-keys has been
engraved by a laser. In addition
SPKL L-keys have a colour coding
according to sizes – for simple and
rapid accessing of the required
tool. Making it easy to find the
right tool.
The wear-resistant clip material
ensures that the L-keys are
securely held yet are easy to
remove.
Web link
Wera Werkzeuge GmbH
02.08.2018 - 3 / 3
Powered by TCPDF (www.tcpdf.org)
D-42349 Wuppertal
很抱歉,暂时无法提供与“05022086001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+184.812881+23.92210
- 3+173.202053+22.41920
- 10+155.9167710+20.18180
- 国内价格
- 1+184.97625
- 3+173.41748
- 10+156.07334
