05030182001
05030182001
    WERA(维拉)
    WERA - 05030182001 - Screwdriver Set, 1550 Phillips ESD Micro, 1572/1529 ESD, 1567 Torx PLUS IPR ESD...
05030182001 数据手册
Kraftform Micro 6 ESD Smartphone repair kit 1, 6 pieces ESD Series EAN: 4013288219411 Size: 250x200x50 mm Part number: 05030182001 Weight: 340 g Article number: Kraftform Micro 6 ESD Country of origin: Smartphone-Reparaturset 1 Customs tariff number: CZ 82054000 ESD-safe tool thanks to surface resistance of ≤ 10^9 Ohm The fast-turning zone just below the rotating cap allows rapid twisting The Wera Black Point tip offers an exact fit and optimum corrosion protection Multi-component Kraftform Micro handles for fast and ergonomic screwdriving Included profiles especially suitable for servicing mobile phones and tablets Electrostatically secured Wera Micro screwdriver 6-piece set. The included screw profiles are especially suitable for use on mobile phones and tablets. Safe protection against electrostatic energy and associated damage. By supporting the hand on the rotating cap, and by the fast rotating zone below the rotating cap, lightning fast turning is possible. Time-consuming hand switching is eliminated. The power zone with integrated soft zones ensures the transmission of high tightening and loosening moments. Precision zone for correct rotation angles whilst adjusting. The Black Point tip provides fitting accuracy and optimum corrosion protection. Take it easy tool finder with size stamping and colour coding by profile to find the required tool quickly and easily. Web link https://products.wera.de/en/screwdrivers_esd_series_kraftform_micro_6_esd_smartphone-reparaturset_1.html Wera - Kraftform Micro 6 ESD Smartphone-Reparaturset 1 05030182001 - 4013288219411 Wera Werkzeuge GmbH 01.03.2021 - 1 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Kraftform Micro 6 ESD Smartphone repair kit 1, 6 pieces ESD Series Set contents: 1550 PH ESD Micro 050301180011),2) 1 x PH 00 x 40 mm 050301190013) 1 x PH 0 x 40 mm 1567 TORX PLUS® IPR ESD 050301350011) 1 x 1 IPR x 40 mm 1) Without bore hole 1) Optimised for Asian PH screws 2) On the output side, the blade is turned to a nominal length of 10 mm 3) Size 0 modificated according to JCIS 0 (Japanese Camera Industrial Standard) 1572 ESD 05030080001 1 x m x 40 mm 1529 ESD 05027450001 1 x 1 x 3.5 x 50 mm For mobile phones and tablets 1550 PH S ESD Micro 05030109001 1 x # 1 x 40 mm For mobile phones and tablets High protection Kraftform Micro handle The screwdriver profiles included in this set are especially suitable for servicing mobile phones and tablets. The electric surface resistance of the Wera ESD material is ≤ 10^9 ohm. This securely protects components against electrostatic energy and associated damage. Multi-component screwdriver handle for ergonomic working. Web link https://products.wera.de/en/screwdrivers_esd_series_kraftform_micro_6_esd_smartphone-reparaturset_1.html Wera - Kraftform Micro 6 ESD Smartphone-Reparaturset 1 05030182001 - 4013288219411 Wera Werkzeuge GmbH 01.03.2021 - 2 / 3 Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de Kraftform Micro 6 ESD Smartphone repair kit 1, 6 pieces ESD Series The precision zone The power zone The fast-turning zone Rotating cap and fast-turning zone The precision zone directly above the blade gives the user a better feel for the right rotation angle during fine adjustment work. The power zone has integrated soft zones near the blade tip to ensure high torque transfer for loosening or tightening screws without losing contact with the screw. The fast-turning zone just below the rotating cap allows rapid twisting The fast-turning zone just below the rotating cap allow rapid twisting. This makes timeconsuming grip adjustments as with other conventional precision screwdrivers unnecessary. Web link https://products.wera.de/en/screwdrivers_esd_series_kraftform_micro_6_esd_smartphone-reparaturset_1.html Wera - Kraftform Micro 6 ESD Smartphone-Reparaturset 1 05030182001 - 4013288219411 Wera Werkzeuge GmbH 01.03.2021 - 3 / 3 Powered by TCPDF (www.tcpdf.org) Korzerter Straße 21-25 D-42349 Wuppertal Tel: +49 (0)2 02 / 40 45-0 E-Mail: info@wera.de
05030182001 价格&库存
很抱歉,暂时无法提供与“05030182001”相匹配的价格&库存,您可以联系我们找货
